Strut/Shock question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-25-2012, 08:53 PM   #1
BlueFlik
Fan#: 103620
What I Drive: 2009 Vista Blue SE Coupe
FF Reputation: 1 BlueFlik Good Standing Member
Hi all;
First, I had a look for something like this - if I missed it, please point me in the right direction.
Now, on to my question. I have H&R lowering springs for my 09 SE Coupe. I've heard it's a very good idea to replace the struts with the springs. I know a lot of people recommend Koni Yellows for performance, but if I'm looking for something more economical, would a set of Monroe Sensa-Tracs (or equivalent) be suitable? If not, what is the least expensive set of struts you would recommend with lowering springs? I'm basically looking for the cheapest option without "doing it wrong."
Any advice would be appreciated, cheers!
FSWerks CAI, H&R Springs, FSWerks ECU, Sound Ordnance P-57 speakers, remote start
BlueFlik is offline
Old 09-25-2012, 09:35 PM   #2
1hotfocus
1hotfocus's Avatar
Fan#: 82813
What I Drive: 00' sedan
FF Reputation: 7 1hotfocus Good Standing Member
Buy-Sell-Trade Rating: (21)
No. Monroe is an OEM replacement. You don't want that. Consider kyb agxs, koni SRT.t's, or eibach pro dampers. Koni yellows are the best in the market for lowering springs but you have to pay to play. Also, for good shocks your going to need the omni kit, as the struts mentioned above are made for 00-05.
Sent from my SAMSUNG-SGH-I717 using FF Mobile
Give rep if youve been helped :)
1hotfocus is offline
Old 09-25-2012, 09:44 PM   #3
BlueFlik
Fan#: 103620
Thanks! This is exactly the info I was looking for.
This, however, brings up another question - if I get the Omni kit, will my H&R springs be useless? Or will I be able to use 08-11-style springs with 00-05-style struts on an omni?
Thanks again
BlueFlik is offline
Old 09-25-2012, 10:06 PM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,810, Level 76
Points: 13,810, Level: 76 Points: 13,810, Level: 76 Points: 13,810, Level: 76
Level Up 40% Completed
Forum Activity 100%
Omni kit get you far
Thanks again
Model yr '00-''05's use one type of spring & strut & '06-'11 use a bigger diameter strut & a spring w/ a pigtail at the bottom. So no you can't interchange the two types. So if you have a later='06+ spring you will need the later strut. The earlier '00-'05 struts & springs are more popular w/ the aftermarket then the later cars. Have OMNI kit & your wide open to all suspension kit made. If your going to mix & match= make sure the strut can handle the spring pressure. All lowering springs are going to have more spring pressure to handle the reduced suspesion travel. So you need a strut to handle the increased pressure. Makes sense doesn't? Shorter travel means somethings got to give, huh?
felixthecat is offline
Old 09-25-2012, 10:42 PM   #5
BlueFlik
Fan#: 103620
Got it, thanks!
BlueFlik is offline
Old 09-25-2012, 11:28 PM   #6
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Got it, thanks!
No problem. So which way are you going?
Old 09-26-2012, 10:59 AM   #7
BlueFlik
Fan#: 103620
I'm going to keep an eye out for a good deal on suitable struts for the later years. If nothing turns up in the next few weeks, I imagine I'll be getting the Omni, and then one of the older suspension types (perhaps SVT kit).
Cheers
BlueFlik is offline
Old 09-26-2012, 12:28 PM   #8
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Cheers
Massive performance has the Omni kit, by the way
Old 09-26-2012, 02:06 PM   #9
BlueFlik
Fan#: 103620
Thanks!
BlueFlik is offline
