Rough idle on 2008 2.0 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Second Generation > DURATEC Performance (2008-2011)
Old 09-25-2012, 03:17 PM   #1
willreid86
Fan#: 89319
What I Drive: 2008 Focus SE
FF Reputation: 1 willreid86 Good Standing Member
Hi all,
I have been having trouble for the past week with a rough idle. It only happens at idle and as soon as gas is pressed it seems to go away. It doesn't feel like it's losing any power at the high end. It fluctuates around 200rpms. It gets to the point where it is about to stall but it doesn't actually do it. I have checked the vacuum lines, cleaned the TB and am now stuck. the car isn't throwing any codes. I am wondering if it could be the IMRC. Any thoughts?
willreid86 is offline
Old 09-26-2012, 09:44 AM   #2
grayzx35speed
grayzx35speed's Avatar
Fan#: 94839
What I Drive: 2006 Gray ZX3
FF Reputation: 0 grayzx35speed Newbie
MAF sensor
North East Honda Killer
OBX Header, Hi flo cat, dremled throttle body/intake manifold, k&n cold air intake, eibach 1.5" springs with Ford Racing gas strutsand Toms tune with PZEV delete and 91 octane
grayzx35speed is offline
Old 09-26-2012, 03:48 PM   #3
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
Buy-Sell-Trade Rating: (13)
Changed spark plugs? Cleaned MAF? New fuel filter? Reset ECU (unhooking battery for a few minutes)?
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
D23 Crew: #07
Jgrove998 is offline
Old 09-26-2012, 04:51 PM   #4
willreid86
Fan#: 89319
I changed the spark plugs and air filter. One thing I noticed last night was inside the air intake hose that connects to the throttle body, there was some oil that was coming from the vacuum hose on the valve cover. Also, when I took the duct off and cranked the car with just the throttle body, the car ran fine. Is it normal for there to be oil in the air duct? Seems like that's what's making it run rich dumping it down the TB causing it to sputter.
Old 09-27-2012, 02:41 PM   #5
grayzx35speed
Fan#: 94839
There should never be oil anywhere on the intake system. Sounds like you have a bad gasket/seat somewhere honestly. And yes oil entering the combustion chamber could cause a rough idle.
Old 09-28-2012, 11:14 AM   #6
willreid86
Fan#: 89319
Could it be the pcv valve or system? I'm gonna dig into that next.
Old 09-28-2012, 11:19 AM   #7
solarboy
Fan#: 104327
What I Drive: 2004 Focus SE - Wagon with SPI
FF Reputation: 1 solarboy Good Standing Member
Same problem .... l cleaned MAF sensor and all is good. Easy to do.
solarboy is offline
Old 09-28-2012, 11:27 AM   #8
willreid86
Fan#: 89319
Solar boy, you had the oil issue too?
Old 09-28-2012, 11:32 AM   #9
solarboy
Fan#: 104327
No, just the rough idling when breaking at slow speed.
Should not be oil in there .... unless it was light oil from lubing....but that would not cause issues.
Eric
solarboy is offline
