SYNC Update Available on Focus!!! - Page 26 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-25-2012, 04:48 PM   #251
HillbillyInBC
Fan#: 85169
What I Drive: 2012 Blue Candy Ti Hatch
Points 491, Level 9
Points: 491, Level: 9 Points: 491, Level: 9 Points: 491, Level: 9
Level Up 82% Completed
FF Reputation: 1 HillbillyInBC Good Standing Member
Originally Posted by Faygo Focus View Post
Okay, thanks, yeah... had to make sure I had Java installed and Applets in the Browser enabled.
Java? SMH.
Hey Ford, 1999 called. It wants its security-hole-masquerading-as-a-browser-plugin back.
Blue Candy Ti Hatch
Charcoal Leather 401A Parking Luxury Handling Nav
HillbillyInBC is offline
Old 09-25-2012, 06:28 PM   #252
dbenney
Fan#: 1195
Points 953, Level 16
Points: 953, Level: 16 Points: 953, Level: 16 Points: 953, Level: 16
Level Up 53% Completed
well i decided to update omw to work this morning. I was hesitant with all the climate issues and no apparent pattern. I have a 7/12 build date(dont remember exact day). I have Nav and was upgrading from gen2 V3.0.2. my install was done with no master reset or fuse pull. Install went without a hitch. I also DO NOT have the climate issue most are reporting. here are a couple issues i had:
1. had to repair phone(knew this was gonna happen... no biggie)
2. all radio presets were wiped (no biggie)
3. Sync initially had trouble understanding what i was saying(got better) while i was trying to reprogram my Sirius presets i was using voice commands and when saying "Boneyard"(my favorite station) it would jsut give the bad command tone. When I would say "Octane"(second favorite station) it would go to some Elvis station. I called them up by channel number and saved the presets. after that i had NO issues with it recognizing voice commands.
I saw some talk in an earlier post in this thread about people being unsure of how many files were in this upgrade. As I was OMW to work I saw the entire update progress. It went through 3 different phases the first phase said 1 of 15... after a while it restarted... the next phase it said 1 of 9 files... again after a while it restarted... then finally it said 1 of 4 files and finished out the install and restarted a final time.
I wish you all had as much success with you update as I did.
dbenney is offline
Old 09-25-2012, 06:36 PM   #253
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 1 bsp_53 Good Standing Member
I'm glad your install went well. Some of us opted to not install and many more did with less than desirable results.
Interestingly, Sync My Ride has pulled the update off the updates page.
Gold Nugget: '12, 400A, Wintr Pckg, Yellow Blaze HB
Mods: Llumar Tint:35 / 20; K&N fltr + Snrkl Del.; Splashgrds; Grill Pinstripes
Hatch Nation #174
bsp_53 is offline
Old 09-25-2012, 06:40 PM   #254
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,019, Level 33
Points: 3,019, Level: 33 Points: 3,019, Level: 33 Points: 3,019, Level: 33
Level Up 80% Completed
Forum Activity 12%
...It went through 3 different phases the first phase said 1 of 15... after a while it restarted... the next phase it said 1 of 9 files... again after a while it restarted... then finally it said 1 of 4 files and finished out the install and restarted a final time.
Same here - except I don't have working climate.
PratoN is offline
Old 09-25-2012, 06:43 PM   #255
dbenney
Fan#: 1195
hmmmm when they replace it I wonder if i should reflash it with the newer one? or leave it be because its working.
dbenney is offline
Old 09-25-2012, 06:45 PM   #256
bsp_53
bsp_53's Avatar
Fan#: 87580
I was wondering the same. My guess is that they'll have instructions specific to or that include those that have already performed the update. For all those that did with frustrating results, I hope that it is soon.
Hatch Nation #174
bsp_53 is offline
Old 09-25-2012, 06:49 PM   #257
oritpro
oritpro's Avatar
Fan#: 96148
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
I dissected the update package last night. The files in the SyncMyRide folder are so named based on the part number they are designed to update. These files are applied in a specific order according to a manifest in the root folder. What gets installed and the exact order depends on version level of the system when the update is applied.
The point of all this is there are several factors at play here and it's likely that not everybody's system received the same files in the same order; which is why some of us are having trouble and others are not.
oritpro is offline
Old 09-25-2012, 07:19 PM   #258
Gigi12
Fan#: 104208
What I Drive: 2012, Grey Sterling, Focus SEL
FF Reputation: 1 Gigi12 Good Standing Member
The update is still up for me on the Sync my ride... Sometimes it says I've successfully updated, and other times, it says I'm still with v.3.0.2... Pffffff !!!
At least, everything is running smooth with 3.2.2 !
Gigi12 is offline
Old 09-25-2012, 07:27 PM   #259
Kabigon
Fan#: 88299
Points 4,402, Level 42
Points: 4,402, Level: 42 Points: 4,402, Level: 42 Points: 4,402, Level: 42
Level Up 26% Completed
Forum Activity 15%
I already investigated that possibility but that doesn't seem to be the case.
People that have upgraded from 3.0.2 (12023) have had mixed results.
Other possibilities include a communication problem between the APIM and HVAC module which may indicate different firmware in the HVAC module or the IPC (Instrument Panel Cluster), which acts as a gateway between the HVAC module (MS-CAN bus) and the APIM (I-CAN bus).
Kabigon is offline
Old 09-25-2012, 07:27 PM   #260
dbenney
Fan#: 1195
mine does the same thing.
dbenney is offline
