Cranking But No Start Issues - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-25-2012, 12:46 PM   #1
DNoda
Fan#: 98185
What I Drive: 2002 Charcoal Sedan
Points 72, Level 1
Points: 72, Level: 1 Points: 72, Level: 1 Points: 72, Level: 1
Level Up 44% Completed
FF Reputation: 1 DNoda Good Standing Member
I believe my fuel pump is on its way out. I was driving the car earlier, everything was fine, I went in the store maybe 20 minutes. When I came out the car would crank, but not start unless I kept my foot on the gas, it would stay running this way. I am not getting a CEL or any codes. I could not afford to tow it, I was 23 miles from home, so I used some duct tape I had and taped down the clutch switch so I could start it easier, and off I went. I made it all the way home and now the issue has stopped it will start and idle just fine. Am I correct in thinking the pump is on its way out? I still have nearly a full tank of gas and would like to use most of it now that it is running before I tackle the pump.
Sent from my DROID X2 using FF Mobile
DNoda is offline
Old 09-25-2012, 03:25 PM   #2
grayzx35speed
grayzx35speed's Avatar
Fan#: 94839
What I Drive: 2006 Gray ZX3
FF Reputation: 0 grayzx35speed Newbie
Could be the pump or its an electrical issue perhaps, like the TPS.
North East Honda Killer
OBX Header, Hi flo cat, dremled throttle body/intake manifold, k&n cold air intake, eibach 1.5" springs with Ford Racing gas strutsand Toms tune with PZEV delete and 91 octane
grayzx35speed is offline
Old 09-25-2012, 03:51 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Level Up 4% Completed
Forum Activity 13%
I'm wondering what other afro-engineering you've done to the car?
Very good possibility some of it is what's causing your issue.
121,000 members and still no sponsored racing.
iminhell is offline
Old 09-25-2012, 04:00 PM   #4
DNoda
Fan#: 98185
Points 72, Level 1
The car is completely stock, I just taped that button down so I could start it if it were to die without having to push the clutch in.
DNoda is offline
Old 09-25-2012, 11:37 PM   #5
my_beautious_ZX3
Fan#: 32386
Points 1,374, Level 20
Level Up 74% Completed
ten year old Focus...IAC valve is another possibility.
my_beautious_ZX3 is offline
Old 09-26-2012, 12:38 AM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
Does the car idle?
Yes. Not IAC.
No. IAC is possible.
My thought is Throttle Position Sensor right now.
iminhell is offline
Old 09-26-2012, 05:54 AM   #7
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
That's usually a cause of no-crank, no start issues, so I don't think you need the tape on the CPS.
When is the last time you changed the fuel filter?
How long does the fuel pump run when you turn the key from Off to On? If it runs for more than 3 seconds, then you have a fuel pump that is on it's way out.
Vacuum loss can prevent starting when the engine is cold because the fuel mix will be too lean.
Old 09-26-2012, 10:41 AM   #8
grayzx35speed
Fan#: 94839
I still lean towards the tps. But it could be a fuel filter.xD
Old 09-26-2012, 11:17 AM   #9
DNoda
Fan#: 98185
Points 72, Level 1
I will see about changing the filter out this weekend, is there a write up on testing the TPS?
DNoda is offline
