Scheduled 30K DCT maintenance? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-23-2012, 06:49 PM   #31
FGLLMX
Fan#: 98526
What I Drive: 2013 Audi A1 Ego 1.4TSFI S-Tronic
FF Reputation: 1 FGLLMX Good Standing Member
Our DTC is a dry clutch system, VW/Audiīs DSG as used in the GTi/GLI is a wet clutch system where the clutches are oil bathed for operation and cooling. In Fordīs DTC, oil is not used for continuous clutch operation and is only used for gears and actuators, so its oil does not degrades as fast and does not requires to be changed as often as VWīs.
I used to own a 2007 VW GLI with the wet clutch DSG and as per VW requirements its DSG oil was to be changed every 40,000 miles.
However, neither Fordīs DTC or VW/Audi's dry clutch DSG require such frequent changes since they use their oil only for internal lubrication like a manual transmission and not for the clutches operation.
FGLLMX is offline
Old 09-23-2012, 07:25 PM   #32
Kabigon
Fan#: 88299
Points 4,414, Level 42
Points: 4,414, Level: 42 Points: 4,414, Level: 42 Points: 4,414, Level: 42
Level Up 32% Completed
Forum Activity 15%
I would like to add that the Ford transmission oil is fully synthetic.
Synthetic oil in a manual transmission (or dry DCT) has a very long life.
Kabigon is offline
Old 09-23-2012, 07:27 PM   #33
Kabigon
Fan#: 88299
Forum Activity 15%
Originally Posted by jamnesta View Post
To me this is the most sensible post. With all the concerns about this transmission, not the least of which includes "grinding noises" (usually resulting in metal shavings ) there would seem to be little room for debate...?
The "grinding noise" reported by some people is actually a noise made by the clutch assembly (which does not use any lubrication).
Kabigon is offline
Old 09-23-2012, 07:42 PM   #34
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,022, Level 33
Level Up 82% Completed
Forum Activity 12%
True, but it's been happening when they have seal leaking issues... I'm not quite sure how they're related, though. Does the leaking fluid get into/on the clutch and ruin it that way? Whatever it is, the TSB calls for new seals and clutches (as well as the adaptive learning cycle) when there is transmission fluid leaking from the seal.
PratoN is offline
Old 09-23-2012, 09:09 PM   #35
dbenney
Fan#: 1195
Points 953, Level 16
Points: 953, Level: 16 Points: 953, Level: 16 Points: 953, Level: 16
Level Up 53% Completed
Originally Posted by Tiger-Heli View Post
Actually, with the splash-shield, under cover, most budget oil change shops probably lose money on a Focus oil change.
i wouldnt bet on it. If you go to a quick oil change place, make sure you check the splash shields and make sure they didnt just break or lose the fastners. this is known to happen. always have some spares in the garage jsut in case.
dbenney is offline
Old 09-23-2012, 09:58 PM   #36
sjdwales
Wales!!
sjdwales's Avatar
Fan#: 46854
What I Drive: 11 mustang
FF Reputation: 13 sjdwales Great Standing Member
Buy-Sell-Trade Rating: (26)
u will find it hard to find a place to touch/change your transmission fluid at 100k miles, let alone 150k miles. its 150k miles at normal driving conditions, what is normal driving? if you change the maintenance program to excessive idling/real driving conditions im guessing its showing it about every 30k miles. on my own vehicle i would do it every 50k miles.
No longer drives a focus, WTF?
sjdwales is offline
Old 09-23-2012, 10:07 PM   #37
Points 10,064, Level 67
Points: 10,064, Level: 67 Points: 10,064, Level: 67 Points: 10,064, Level: 67
Level Up 4% Completed
Forum Activity 22%
If your car is a traditional planetary automatic transmission with a torque converter then yes you likely need to change the fluid every 30k or less. However the DCT is essentially a manual transmission form a lubrication stand point and no one usually changes the transmission fluid in a manual at 30k as it isn't broken down at that point the DCT should be fine following the same intervals. The old transmission uses a lot more fluid and also runs hotter due to the torque converter and oil pump, but the DCT is more akin to a manual transmission with less than 3 quarts of Dual Clutch fluid which is similar to MTX fluid.
suss6052 is online now
Old 09-24-2012, 12:07 AM   #38
Kabigon
Fan#: 88299
Forum Activity 15%
Every so often (at low speeds and low engine RPM) I hear the noise from the clutches that I believe people are referring to as the "grinding noise". Otherwise, I have no problems whatsoever.
I'm not sure if a leaking oil seal makes it worse but I have read posts from some folks that have had their clutches replaced and they say that the grinding noise is gone.
The point of my previous reply is that the "grinding noise" is not something related to the transmission "box" itself so changing the oil more frequently is probably not necessary or helpful.
Kabigon is offline
Old 09-24-2012, 11:44 AM   #39
Tiger-Heli
Fan#: 12379
Points 913, Level 16
Points: 913, Level: 16 Points: 913, Level: 16 Points: 913, Level: 16
Level Up 13% Completed
Forum Activity 8%
FWIW - it was previously pointed out the the Focus manual under severe conditions specifies "30K fluid change - (except Focus)", which implies the severe limit for the Focus is 150K also (and make you wonder why the Fiesta isn't excluded also, but ...)
Tiger-Heli is offline
Old 09-24-2012, 11:46 AM   #40
bball40dtw
Fan#: 85847
What I Drive: 2012 Focus Ti and 2013 C-Max SE
FF Reputation: 1 bball40dtw Good Standing Member
$200 @ 30K is ridiculous. VW doesn't even recommend changing DSG fluid until 40K miles. Rates for that service at a VW dealership range anywhere from $250 to $500. Parts alone cost $135 for the DSG fluid change.
Ford has cheaper parts, less fluid in the transmission, and cheaper labor rates. The VW fluid costs about $20 a liter, and you need six liters. They also recommend a specialized tool for changing the fluid (It costs over $100). I was able to make a tool from $15 worth of hardware store parts and do the maintinence for under $150, plus the cost of pizza and beer for a friend.
bball40dtw is offline
