SYNC Update Available on Focus!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-23-2012, 12:15 PM   #1
treoless
Fan#: 96715
Points 5,481, Level 47
Points: 5,481, Level: 47 Points: 5,481, Level: 47 Points: 5,481, Level: 47
Level Up 66% Completed
FF Reputation: 1 treoless Good Standing Member
Thumbs up SYNC MFT V3.2.2 Update Available on Focus!!!
I had nothing better to do this morning so I checked SMR. It's showing the update is available!
DA5T-14D544-AH Version Gen2 - V3.2.2
--------------Update 1---------------
The update took 37 minutes. Did a master reset and fuse pull prior to the install. Climate works fine. I'm having a rather odd issue - the system crashes every time I click "Rearview Camera Setting". A master reset and fuse pull didn't help. I'll just let the car sit overnight. If it doesn't fix itself, I'm taking it to the dealer
--------------Update 2---------------
Took my car to the dealership yesterday and they couldn't re-flash the software after 6 tries. They were told by Ford that the update on SMR was corrupted. They finally fixed it by taking the MFT unit (APIM?) out and forced the update.
treoless is offline
Old 09-23-2012, 12:28 PM   #2
Points 10,052, Level 67
Points: 10,052, Level: 67 Points: 10,052, Level: 67 Points: 10,052, Level: 67
Level Up 1% Completed
Forum Activity 23%
Still no update available for sync G1 from v 3.1.1 (although there are apparently different versions through out the 2012 MY, as well as a new version for 2013). Grr.
suss6052 is online now
Old 09-23-2012, 12:55 PM   #3
thosw
Fan#: 92594
What I Drive: 2012 Sterling Grey Focus Ti 5 Door
FF Reputation: 1 thosw Good Standing Member
Just installed mine. The Climate System Temperature Display on the Home Screen does not work. Nothing there but a Power Button. Climate system does work though.
thosw is offline
Old 09-23-2012, 12:58 PM   #4
dberezin
dberezin's Avatar
Fan#: 96949
What I Drive: 2012 Tuxedo Black SEL 303A
FF Reputation: 1 dberezin Good Standing Member
I just did mine. It's version 3.2.2. It successfully installed, but the one issue I found is the climate control. The on-screen buttons will work the A/C, etc, but it doesn't show the temperature and it doesn't show the system is turned on. On the 4-squares it shows the "power button" even though it's on and running.
The outside temperature is showing next to the clock at the top now and the FM seems to keep the channel when I go from FM to Sirius and back to FM (it used to go to some random FM station before).
dberezin is offline
Old 09-23-2012, 01:25 PM   #5
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,019, Level 33
Points: 3,019, Level: 33 Points: 3,019, Level: 33 Points: 3,019, Level: 33
Level Up 80% Completed
Forum Activity 12%
So... what's the consensus? Should I install this? Or wait half a year for the next update?
PratoN is online now
Old 09-23-2012, 02:04 PM   #6
PBF199
Fan#: 100551
What I Drive: 2012, TBD, Focus SEL
FF Reputation: 1 PBF199 Good Standing Member
Newb question: how'd you install it?
Sent from my iPhone using FF Mobile
PBF199 is offline
Old 09-23-2012, 02:07 PM   #7
Forum Activity 23%
Usually it involves downloading it, then expanding it on an empty and cleanly formatted FAT32 Flash drive of sufficient size. Then you plug the usb stick into the car and it should run. Usually you need to be running the car for about an hour or until it finishes so that the battery minder doesn't cut in and turn the system off mid update.
Old 09-23-2012, 02:10 PM   #8
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 12%
You're so pretty...
But seriously, go to syncmyride.com and set up an account if you don't already have one. You'll need an empty/formatted 2GB flash drive (though, I believe SD cards also work). Also, I think MFT prefers FAT32 over NTFS. Anyway, log in, click on updates, it'll be at the top. follow the on-screen instructions. Once it's done, start your car, pop it in. If doesn't start installing automatically, go into the settings / APPs (I think?) section and it should start from there. Keep your car running while it installs (you'll not want to do this in a closed garage and but you will want at least 2 gallons of gas and some free time). You can also do the install while driving the car.
Have fun.
Old 09-23-2012, 02:19 PM   #9
HillbillyInBC
Fan#: 85169
What I Drive: 2012 Blue Candy Ti Hatch
Points 491, Level 9
Points: 491, Level: 9 Points: 491, Level: 9 Points: 491, Level: 9
Level Up 82% Completed
FF Reputation: 1 HillbillyInBC Good Standing Member
No joy. I've still never been able to confirm the previous "upgrade" on syncmyride.com. Small wonder that the "upgrade" is such a dog's breakfast, given that they can't even manage to transfer an XML file through a browser.
Blue Candy Ti Hatch
Charcoal Leather 401A Parking Luxury Handling Nav
HillbillyInBC is offline
Old 09-23-2012, 02:21 PM   #10
Tempusthales
Tempusthales's Avatar
Fan#: 104155
What I Drive: 2012, Candy Blue, Focus SEL
FF Reputation: 1 Tempusthales Good Standing Member
I have the same issue with the climate. Called Ford and they didn't have any info on it so I think people are just starting to install the update. They said I would have to go to the dealer to get it fixed.
Tempusthales is offline
