Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Sponsored By:
Tire Rack
Old 09-19-2012, 09:56 AM   #1
towlawrian
Fan#: 103988
What I Drive: 2007, black focus zetec tdci
FF Reputation: 1 towlawrian Good Standing Member
New Pads/ Disc's Grinding
I have recently had new pads and disc's fitted. After a few miles I can hear a grinding noise at low speeds and when I pull away from a stop it then stop as I increase speed. Could this be because they haven't bedded in right yet?
towlawrian is offline
Old 09-19-2012, 11:08 AM   #2
Geezer
Fan#: 1427
FF Reputation: 141 Geezer Excellent Standing MemberGeezer Excellent Standing Member
The new brakes are probably dragging a little. Double check that all the springs were installed correctly. These are what keep the pads from continously rubbing on the rotor.
Also the drag could be caused by caliper pins not be cleaned and relubed.
Geezer is offline
Old 09-19-2012, 11:37 AM   #3
bugman
bugman's Avatar
Fan#: 98366
What I Drive: 2010 Sangria Red SES
FF Reputation: 1 bugman Good Standing Member
Sounds to me that the caliper pins, what the caliper rides on, are sticking. Pull them and if they aren't smooth you'll need to clena them up and re-lube with caliper grease. Re-check them every 4-6 mo's to get the most life out of your new pads.
2010 Sangria Red SES #051 Sedan
Autolite AR 103 Sparkplugs, Ram-Air AIRAID CAI, LED Tails
bugman is offline
Old 09-19-2012, 11:39 AM   #4
towlawrian
Fan#: 103988
Thanks.
Are the springs the metal clip that sits on the side of the caliper?
Old 09-19-2012, 05:50 PM   #5
Geezer
Fan#: 1427
Thanks.
It looks kind of like a giant convoluted paper clip. Another area that's often overlooked is the tabs on the ends of the pads. These sit in slots on the caliper/caliper bracket. If these slots are rusty etc. they can also prevent the proper movement (release) of the pads.
Geezer is offline
