SVT Swap Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-19-2012, 01:22 AM   #1
racnfirecapn
Fan#: 92527
What I Drive: 2002 Sonic Blue & Pitch Black SVT's
Points 67, Level 1
Points: 67, Level: 1 Points: 67, Level: 1 Points: 67, Level: 1
Level Up 34% Completed
FF Reputation: 1 racnfirecapn Good Standing Member
SVT Swap Question
Hey Guys and Gals,
I posted this here because I wanted the expert opinion of the SVT crowd.
I'm getting ready to swap the motor in one of the 3 SVT's I picked up last December. Bought it (severely neglected, one owner, 2002 Sonic Blue) with a spun rod bearing and picked up a pretty clean, wrecked 2004 Sonic blue with right side, sideswipe damage, and good motor. I plan to replace the usual stuff (timing belt kit, serpentine belt, tensioner and idler, water pump, thermostat housing, clutch, and plugs). Just wondering if you very knowledgeable Foci owners know of anything else I should be concerned with during the swap. I also am under the impresssion that it is a direct swap 04 into the 02. Are there any sensor's that were changed between 02 and 04? Anything from the 04 that was updated and would be a better part to run.
I also have a Pitch Black 2002 SVT that has been driven daily since last December and I really have enjoyed the car whenever I get the chance to drive it. I have owned a lot of cars (over 30) over the years (everything from mach 1, GTO, Charger, trucks, SHO, etc...) and this is one of my favorites for its nimbleness and interior package in such a low budget platform. Funny thing is when my daughter was about to get her license a few years ago she advised me she would not be caught dead in a focus especially the ZX3 body style. And she ended up with an Explorer. Now whenever she can, she jumps in the SVT and has a ball driving it. That's why I bought the second SVT to repair, because now it's a battle to get to drive the car between my daughter and wife.
I look forward to hearing from the experts on here so I can get started with the swap in the next few weeks.
Thanks again,
Lester Cragan
Racnfirecapn
racnfirecapn is offline
Old 09-19-2012, 03:56 PM   #2
drostedrummer89
I <3 my SVT
drostedrummer89's Avatar
Fan#: 69059
What I Drive: 2002 Sonic SVT
Points 5,199, Level 46
Points: 5,199, Level: 46 Points: 5,199, Level: 46 Points: 5,199, Level: 46
Level Up 25% Completed
FF Reputation: 8 drostedrummer89 Good Standing Member
Buy-Sell-Trade Rating: (10)
whats the mileage on the donor motor? depending on mileage I'd go all through it and replace gaskets, valve seals, deck head, maybe even crack the bottom end open and replace bearings and rings. but all that depends on mileage, as well as the results of a leakdown/compression test.
All sensors should remain the same for the svts.
Matt
Droste Drummer. Droste like Frosty.
00" Red ZX3: Volant, ported throttle body, titanium wrapped SVT header, 2.5" exhaust, Magnaflow res/muffler, FR UDP, Mac cam gears, Lowered 2", Koni's.
drostedrummer89 is offline
Old 09-21-2012, 09:00 PM   #3
racnfirecapn
Fan#: 92527
Points 67, Level 1
SVT motor swap
Thanks Matt for the reply,
(Mileage on the donor motor is just over 75,000)
The Compression test showed between 110 - 116 PSI on all four cylinders. From what I have read that's pretty near the best you can get from the stock SVT. I have not performed a leak down test yet but I will do that after I pull the motor. Me personally I'm not interested in decking/milling the head unless it had damage/warping and was in need of it. I actually want to keep the car in stock trim. I might consider a rebuild if the consensus leans that way. I was actually thinking that I would go through and rebuild the motor with the spun rod bearing after the replacement is completed. The motor in the neglected SVT (approximately 128,000 miles) had the head rebuilt about 4 months before the spun bearing problem surfaced. (Resulted from a, believe it or not, broken timing belt no less. Imagine that!!)
All sensors should remain the same for the svts. Thanks for the info here!!
Matt
Lester
Old 09-22-2012, 02:03 AM   #4
drostedrummer89
I <3 my SVT
Fan#: 69059
I meant just deck it flat if doing a head gasket. I like doing things like pressure testing cyl heads and lapping valves, I like the thought of near 100% cylinder pressure.
I like overkill. Refreshing everything while its out of the car, and doing it right the first time.
Posted via FF Mobile
Old 09-30-2012, 05:45 PM   #5
whichdoctorbilly?
Fan#: 76039
What I Drive: 2002 svt
FF Reputation: 1 whichdoctorbilly? Good Standing Member
iffy
whichdoctorbilly? is offline
Old 09-30-2012, 11:45 PM   #6
racnfirecapn
Fan#: 92527
Points 67, Level 1
What's iffy?
Originally Posted by whichdoctorbilly? View Post
iffy
Old 10-10-2012, 08:14 AM   #7
vms305
Fan#: 104670
What I Drive: black
FF Reputation: 1 vms305 Good Standing Member
do you got a good uable svt head
vms305 is offline
