Where are the 5-speeds???? - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-18-2012, 06:20 AM   #91
2kwik4u
Fan#: 102523
What I Drive: '12-Sonic Blue-5dr/5spd/203A/Roof
Points 1,642, Level 23
Points: 1,642, Level: 23 Points: 1,642, Level: 23 Points: 1,642, Level: 23
Level Up 43% Completed
FF Reputation: 1 2kwik4u Good Standing Member
Thats wierd.....your console is different than mine. Mine has the cup holders in the front of the coin tray/power outlet.
Also, Anyone know where those little insert things came from in the cupholders?
2kwik4u is offline
Old 09-18-2012, 08:16 AM   #92
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
S, SE have the pictured setup. SEL and Titanium have the cupholder setup you have. Those inserts came from Ebay. I'm not sure they will fit the SEL and Ti cupholders, but don't you already have a rubber insert?
Hatch Nation #90
TboneZX3 is offline
Old 09-18-2012, 08:21 AM   #93
2kwik4u
Fan#: 102523
Mine is only an SE (with 203A), and I don't think there are any inserts in there. I'll double check.
2kwik4u is offline
Old 09-18-2012, 12:02 PM   #94
RonMaiden
RonMaiden's Avatar
Fan#: 99230
Points 4,216, Level 41
Points: 4,216, Level: 41 Points: 4,216, Level: 41 Points: 4,216, Level: 41
Level Up 33% Completed
Forum Activity 11%
My SE Sport has the different center console with one small and one larger cupholder and the coin holder and outlet are behind them.
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is online now
Old 09-18-2012, 12:12 PM   #95
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
Same here.
BetaDnB is online now
Old 09-18-2012, 01:33 PM   #96
zolemite
zolemite's Avatar
Fan#: 36933
What I Drive: 2012 Focus S 2.0 5mt
Points 1,527, Level 22
Points: 1,527, Level: 22 Points: 1,527, Level: 22 Points: 1,527, Level: 22
Level Up 27% Completed
FF Reputation: 1 zolemite Good Standing Member
Be thankful you don't have these cup holders as they are pretty much worthless. The rubber inserts helped some. I'd also like a armrest :(
zolemite is offline
Old 09-18-2012, 04:43 PM   #97
gsrcrxsi
Fan#: 103577
What I Drive: not a Focus
FF Reputation: 1 gsrcrxsi Good Standing Member
gf picked up an SE (not sport AFAIK,but has the sync and 6 speaker audio package, not sure exactly which package that is) a few weeks ago, new, 50mi, for $15,000. in a manual. she wanted a manual and enjoys it.
im not too impressed with the manual trans in this car personally. the clutch is too light for my tastes, feels like you are barely doing anything and reduces the feel when trying to feather the clutch, which is necessary when setting off in first gear due to the lack of power. but maybe im just used to the heavy clutch in my car (2010WRX). the gearing is also relatively long for a lower powered car. shorter gears would definitely help that i think.
also, the shifter is sloppy as all hell, with very little feedback. but maybe that can be remedied with some stiffer shifter bushings (is this a cable shifter? or mechanical linkage?)
gsrcrxsi is offline
Old 09-18-2012, 05:06 PM   #98
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
Points 126,755, Level 100
Points: 126,755, Level: 100 Points: 126,755, Level: 100 Points: 126,755, Level: 100
MS3 RMM and Steeda STS... All fixed!
Sonic_HedgeHog is offline
Old 09-18-2012, 05:17 PM   #99
gsrcrxsi
Fan#: 103577
not sure how a motor mount will fix the light and bland clutch pedal feel? thats almost totally dependent on the clutch master/slave cylinders and the pressure plate. im sure it would improve the vague shifter feel a little though, by reducing motor movement. im going to assume you mean a urethane aftermarket MS3 mount? unless the stock MS3 mount is not rubber like most OEM motor mounts are.
also wont fix the long gears. but i digress.
so does this car have a cable shift linkage? or a mechanical linkage?
gsrcrxsi is offline
Old 09-18-2012, 05:35 PM   #100
Sonic_HedgeHog
Sonic Mk3 Crew #00
Fan#: 50003
How does she feel about the clutch? I personally prefer the Ford unit to the Subie. It is nice and light, I can tell exactly where I am and I think the shifter is great and nearly perfect with listed mods.
Cables for the shifter
Stock MS3 Rear Motormount, most have found truly aftermarket ones to be too stiff with high duros...
MS3 vs Stock
Peruse the forum and see what other people are saying and doing...
I send my congrats to your GF... Why isn't she posting?
