Timing belt questions.... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-15-2012, 01:03 AM   #1
GBPackFan
GBPackFan's Avatar
Fan#: 84314
What I Drive: 2004 Sonic Blue SVT
Points 1,795, Level 24
Points: 1,795, Level: 24 Points: 1,795, Level: 24 Points: 1,795, Level: 24
Level Up 95% Completed
FF Reputation: 3 GBPackFan Good Standing Member
Buy-Sell-Trade Rating: (8)
OK, first off I had the original t-belt changed around 85K miles, I currently have 136K. I don't remember having the pulleys changed out or not, but nearly 50K miles is hard on my memory. Fast forward to now, I have a terrible chirping sound coming from the engine area. It starts when I turn the car on, and is significantly more noticeable when the car is at a lower operating temperature. The sound seems to be coming from the left side of the motor, in the general area of the timing and serp assembly. The sound is definitely rpm dependent, and not wheel rotation dependent. The sound is present while driving the car and continues to be audible until the car has been running at proper operating temp for about 5 minutes, then subsides slightly. I do know for a fact that this sound is NOT a wheel bearing or wheel hub going bad. As I noted, the chirping starts when I turn the car on in my driveway, gear in neutral, e-brake engaged, not rolling or moving in any way. When I increase the rpm's the chirping gets faster. I am thinking that one of my pulley's is going bad, I don't know which one. Since the t-belt has proven to be problematic for some, and prone to premature failure, I will be replacing the t-belt assembly if the cause of this chirping is determined to be a bad pulley.
Now, my biggest question is this, I changed the water pump with an OEM unit when I did the t-belt @ 85k. The gasket on the pump was real bad and leaking fluid bad, so it got changed. Since I did it @ 85k, do I HAVE to change it again? My funds on this are extremely limited, and will be doing the install myself to save money, so any cost savings will go a long way.
Also, what parts exactly should I be ordering to do the t-belt & serp-belt? Timing belt, timing idler, timing tensioner, serpentine belt, serp idler, serp tensioner, and valve cover gasket?
Current love affair: 2004 SVTF #953 (Josephina - pronounced hoe-se-fin-a)
RIP: 2002 SVTF #2358, Sent to graveyard on June 11, 2013. I will always remember the good times we had!!
This car made my hair go gray, and did not care.
GBPackFan is offline
Old 09-15-2012, 07:31 AM   #2
Dads03SVT
Dads03SVT's Avatar
Fan#: 58979
What I Drive: 2003 Red SVT
FF Reputation: 1 Dads03SVT Good Standing Member
Yep....make sure water pump is not weeping it has a hole where it leaks when the bearing goes out. Ohh and check your hoses my power steering line rubbed a place in mine.
I just got all my parts in yesterday from Steve to do my 2nd one....My first one was at 86,000, just turned up 146,000 & this time i got those new grommets for the valve cover they are nearly $5 a piece.
I will also add probably 15,000 after my last tensioner was done it started a squealing on cold mornings....and would come and go...got a new one from NAPA & a Dayco belt .
Tensioner had a wobble in the pulley.
Dads03SVT is offline
Old 09-17-2012, 12:41 PM   #3
birdman_a15
birdman_a15's Avatar
Fan#: 75473
What I Drive: 2003 Red SVT Focus ZX5
FF Reputation: 1 birdman_a15 Good Standing Member
Rockauto sells the timing belt kit all in one. Pullies, belt, tensioner.
I would use a stethoscope first to localize the issue. They can be had for cheap at most auto parts stores and harbor freight.
birdman_a15 is offline
Old 09-17-2012, 10:56 PM   #4
z28forlife
Fan#: 67288
What I Drive: 2010 335I M-sport
Points 541, Level 10
Points: 541, Level: 10 Points: 541, Level: 10 Points: 541, Level: 10
Level Up 82% Completed
FF Reputation: 1 z28forlife Good Standing Member
Sounds like the timing belt idler pulley. But you won't know till you change it.
z28forlife is offline
