Snorkel Delete - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-16-2012, 06:56 PM   #1
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,222, Level 96
Points: 26,222, Level: 96 Points: 26,222, Level: 96 Points: 26,222, Level: 96
Level Up 88% Completed
Forum Activity 54%
Snorkel Delete
Edit: This thread started based on other dyno work I was doing at the time. Let me clarify the fact that this will not increase power if you have the OEM filter installed. You MUST have an aftermarket filter in order to see power gains! Also, if you have a closed-end filter then you need to do this for power gains as well!
Edit: In the following posts/pages you will see how to cut and/or remove the shroud that directs air to the radiator. There is no data to confirm or deny possible gains by doing that work. It is something that I had initially done on my vehicle prior to having created this thread. You do NOT have to do this to achieve the gains from the snorkel delete/drop-in filter!
A few people have asked for a quick how-to for this, so I'll try to post up something visual. I don't have my snorkel anymore to show you, but when you pull back the black plastic you will see the difference between my pics and stock.
First you must pull the four push-pins out of the plastic where it attaches to the radiator support (just forward of the two intake runners) Also, I would slide the hood release out of it's holder where it makes the 90 bend. This will help you pull back the shroud.
After you pull back the shroud, you will see the snorkel on your car that is not in this pic. There are two push-pins on the drivers side and another push-pin on the passenger side. They are a little difficult if it's just you, fyi.
After you remove the snorkel you will see the plastic piece that keeps air directed to the radiator from under the whiskers. I only cut my drivers side (evidenced by the fingers), though others have cut both sides and some have even cut the whole top section. The only way I know to remove this (so far) without cutting is to remove the entire bumper cover.
Hopefully this helps. I would've set my snorkel in to show, but it went the way of the circular file. This is a mod that would never need to be reversed because incoming water would have to travel vertically 1-2" to get in the plenum, and dealerships won't be popping the top cover to verify it is installed. At a minimum, the snorkel must be removed for the additional hp/tq of an aftermarket drop-in air filter.
Edit: All of these pics are with the front of the car on the bottom. Sorry, that's just how it came out.
Sent from my stupid phone.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 09-16-2012, 08:12 PM   #2
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Points 2,419, Level 29
Points: 2,419, Level: 29 Points: 2,419, Level: 29 Points: 2,419, Level: 29
Level Up 80% Completed
Forum Activity 11%
Now I get it! Thank dyn085!
BetaDnB is online now
Old 09-16-2012, 08:18 PM   #3
ChrisRyan
Fan#: 97815
What I Drive: '12 SE Sterling Grey(5door) 5M 203A
Points 769, Level 14
Points: 769, Level: 14 Points: 769, Level: 14 Points: 769, Level: 14
Level Up 69% Completed
FF Reputation: 2 ChrisRyan Good Standing Member
I just removed this tonight. The car is smoother at idle and off idle for sure. Havent had a chance to test it in real world conditions yet as we have gotten ~8inches of rain in 3 days. Thank you Jesus for the rain tho. Not sure if fabricating any sort of apparatus to redirect the air to the inlet left behind would yield any appreciable gains vs the hassle of fabing up and install.
ChrisRyan is offline
Old 09-16-2012, 08:35 PM   #4
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
Points 9,452, Level 65
Points: 9,452, Level: 65 Points: 9,452, Level: 65 Points: 9,452, Level: 65
Level Up 34% Completed
Buy-Sell-Trade Rating: (12)
Good write up bro. This is definitely on the list of things to do as in...next weekend. Rep added.
jdubhack is offline
Old 09-16-2012, 08:43 PM   #5
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 54%
No prob, glad it helps I've been meaning to do it for a while and just been slacking.
I've had the intent of fabbing up a fiberglass scoop to collect the width of the whisker and give it a better path to the radiator support, but I've also been slacking with that too. I don't think there would be an appreciable gain in anything other than possibly getting better mpg's, but don't quote me on it. In hindsight, I would have much rather done a scoop there than Newmissioned my airbox...
September '13 ROTM
2014 FiST-
Old 09-16-2012, 11:01 PM   #6
Trav-E2.0
Thread Killer
Trav-E2.0's Avatar
Fan#: 8331
What I Drive: 2014 Fiesta ST
Points 14,853, Level 79
Points: 14,853, Level: 79 Points: 14,853, Level: 79 Points: 14,853, Level: 79
Level Up 1% Completed
FF Reputation: 6 Trav-E2.0 Good Standing Member
Buy-Sell-Trade Rating: (13)
Whats funny is that when I read snorkel delete, I thought yall ment to take this out:
LOL! Makes alot more sense ...good job as always dyn085
I has FiST
Trav-E2.0 is offline
Old 09-16-2012, 11:09 PM   #7
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
That would have been a tragic mistake to make!!
jdubhack is offline
Old 09-17-2012, 03:15 PM   #8
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 11%
So I got as far as getting it all apart. I only lost one clip! How necessary do we suppose it is to cut that flap for any kind of gain?
Old 09-17-2012, 03:31 PM   #9
vluc
Fan#: 10803
What I Drive: 2012 Focus Titanium, Ebony
FF Reputation: 1 vluc Good Standing Member
I cut both the drivers side and passenger side. If you want some gains, cut. If not, don't - but you went through enough effort to get that far you may as well cut. In for a penny, in for a pound.
vluc is offline
Old 09-17-2012, 05:34 PM   #10
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 54%
Cutting the flap allows air to accumulate behind the grill and be readily available for the intake.
September '13 ROTM
2014 FiST-
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
