need re-tune after battery disconnect? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-14-2012, 04:27 PM   #1
dirtbikeman2012
Fan#: 102843
What I Drive: 03 Silver SVT
FF Reputation: 1 dirtbikeman2012 Good Standing Member
I just got a focus svt and my tranny and clutch up from the previous owner and when the garage had to disconnect the battery. I got it back and the custom tune that was on it isn't loading or something. I dont have the programmer that should have came with it and I was just wondering that if it I needed the handheld or if I ran it for an amount of time, it would go back on?
dirtbikeman2012 is offline
Old 09-14-2012, 07:23 PM   #2
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 917, Level 16
Points: 917, Level: 16 Points: 917, Level: 16 Points: 917, Level: 16
Level Up 17% Completed
FF Reputation: 3 forddorf Good Standing Member
Your tune was installed by flashing your ecu. The custom tune stays in your cars computer and should not be affected by disconnecting the battery.
forddorf is offline
Old 09-14-2012, 08:10 PM   #3
dirtbikeman2012
Fan#: 102843
Can you explain why it isn't idling correctly? Or why it is boggy at the begining of some gears? The other thing I was told was that the idle gets screwy after the battery is disconnected, is it just that? I got 30 miles on it or so and I did notice its running better
Old 09-14-2012, 08:23 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,132, Level 100
Points: 138,132, Level: 100 Points: 138,132, Level: 100 Points: 138,132, Level: 100
Forum Activity 54%
Buy-Sell-Trade Rating: (11)
Disconnecting the battery should have no effect on what tune was on the car already. Sounds like the shop you took it too didn't hook something back up right? Check for vacuum leaks maybe a hose isn't connected or something?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 09-14-2012, 08:56 PM   #5
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,605, Level 43
Points: 4,605, Level: 43 Points: 4,605, Level: 43 Points: 4,605, Level: 43
Level Up 28% Completed
FF Reputation: 28 ah1f39 Great Standing Member
The computer has to re-learn after the battery is disconected. It could take several hours of run time.
The cutsom tune is flashed and is safe untill reflashed with the stock tune or an adjusted custom tune.
ah1f39 is offline
Old 09-14-2012, 09:08 PM   #6
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 7,994, Level 60
Points: 7,994, Level: 60 Points: 7,994, Level: 60 Points: 7,994, Level: 60
Level Up 22% Completed
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
These cars are finicky after reconnecting the battery. It seems to be a Focus-proclivity!
Mile30 is online now
Old 09-14-2012, 09:11 PM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 54%
Disconnect it again, then wait about 10mins or just turn on all the light and stuff with the battery disconnected. Then connect and let the car sit there and idle for roughly 5-10mins. If it's cold let it warm up all the way. If you still have a problem then something is not right.
Moderator for
Technical Chat
Old 09-15-2012, 12:54 AM   #8
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,787, Level 100
Points: 51,787, Level: 100 Points: 51,787, Level: 100 Points: 51,787, Level: 100
Forum Activity 32%
Buy-Sell-Trade Rating: (28)
The Batt loose has no effect on idle or any bogging , if this is what happening I would check Vac leaks , IMRC unhooked , cam sensor unhooked etc
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 09-15-2012, 01:02 AM   #9
dirtbikeman2012
Fan#: 102843
Tom, since you are on here, I seen you around on all the forums. I took my car out to show my Buddy.how it runs right now and when.i.shifted the shifter went into 2nd gear but when I left out the clutch it sounded like it was still in first. I pulled over and my shifter was stuck in 2nd gear. I can't get it out of second. Any ideas?
P.S. I am gonna try the battery disconnect method and if that dont work ill check for a vac leak. My friend said that could be an issue after the ride.
Old 09-15-2012, 01:07 AM   #10
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,629, Level 94
Points: 23,629, Level: 94 Points: 23,629, Level: 94 Points: 23,629, Level: 94
Forum Activity 17%
that part sounds related to the clutch install.
your weird running deal is characteristic of these cars when the battery is disconnected. It needs to go through the relearn procedure sleepy mentioned. It will not erase your tune.
mikebontoft is offline
