How to: Headlight housing removal w/ sidelight bulb change (European) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-07-2012, 07:25 PM   #1
Chickenmuffn
Fan#: 103458
What I Drive: 2011 Focus Zetec 1.6
FF Reputation: 9 Chickenmuffn Good Standing Member
NOTE: This was done on European 2011 Ford Focus MK3.
This process took me about 30 minutes. I changed the stocked halogen sidelights to LEDs.
Before: Stock sidelights
Pop the hood, remove two screws as indicated. Gently wiggle the headlight housing up and out. Take care as there is still a wiring harness attached
There is one wiring hardness at the centre of the housing. Detach it, and the headlight housing can be pulled out of the car completely
Headlight is out of the car (left headlight)
Remove the indicated rubber grommet from the back of the headlight (this is the right headlight)
This is what it looks like behind the grommet
Get some needle nose pliers or use your fingers (difficult) to pull the bulb holder and bulb
Pull out the stock halogen and insert the LED
Before you reinsert the bulb assembly into the headlight housing, plug the headlight wiring harness back in and test the light. These bulbs can go in two ways but only one way works.
After: LED side lights
The picture makes them look a lot brighter and blue'r than what they are in person.
Hope this is helpful to someone.
Chickenmuffn is offline
Old 09-07-2012, 07:38 PM   #2
Altis
Fan#: 89540
What I Drive: 2012 Sterling Grey SEL Hatch 5MT
FF Reputation: 1 Altis Good Standing Member
Nice DIY with high quality photos. Thanks for sharing!
Altis is offline
Old 09-07-2012, 07:41 PM   #3
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
Points 22,454, Level 93
Points: 22,454, Level: 93 Points: 22,454, Level: 93 Points: 22,454, Level: 93
Level Up 11% Completed
Forum Activity 11%
You forgot a step:
-Send Euro lights to a North American owner.
I kid. Maybe. But thanks for the write up, we do have the small lights over here and some like to change them out.
officialTHREETWENTY
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 09-07-2012, 07:53 PM   #4
Chickenmuffn
Fan#: 103458
Ahh if only mine were projectors... I'm thinking retrofit soon :D
Old 09-08-2012, 12:37 AM   #5
VectorZ
VectorZ's Avatar
Fan#: 100457
What I Drive: 12' Focus Titanium Sport Hatch
Points 659, Level 13
Points: 659, Level: 13 Points: 659, Level: 13 Points: 659, Level: 13
Level Up 18% Completed
FF Reputation: 3 VectorZ Good Standing Member
Ours do have the sidelights, one of mine is burned out already. Where did you find the LEDs?
VectorZ is offline
Old 09-08-2012, 02:17 AM   #6
Chickenmuffn
Fan#: 103458
I found mine on Amazon. They are 501 bulbs. (also called T10/W5W/168/194) They are really inexpensive too, I got mind for under $4 shipped.
http://www.amazon.com/5-SMD-White-Hi...ywords=T10+LED
Old 09-08-2012, 02:48 AM   #7
unida767
Sonic Mk3 Crew #08
unida767's Avatar
Fan#: 95574
What I Drive: 2012 Black Titanium Powershift SEP
Points 4,452, Level 42
Points: 4,452, Level: 42 Points: 4,452, Level: 42 Points: 4,452, Level: 42
Level Up 51% Completed
Forum Activity 22%
FF Reputation: 11 unida767 Great Standing Member
Hey Chickenmuffn nice write up and pics man thanks for sharing.
I might just go and do this now.
Same bulbs go in your puddle lights too.
unida767 is offline
Old 09-14-2012, 02:50 PM   #8
VectorZ
VectorZ's Avatar
Fan#: 100457
I got the headlight out with no problem, but I simply cannot get the little marker bulb out of there! Any secret to removing it??
VectorZ is offline
Old 09-14-2012, 03:23 PM   #9
Touring05
Fan#: 96695
What I Drive: 2012 ISM SEL Hatchback
Points 253, Level 5
Points: 253, Level: 5 Points: 253, Level: 5 Points: 253, Level: 5
Level Up 6% Completed
FF Reputation: 2 Touring05 Good Standing Member
Using a long nose needle plier is one way as stated above but you could get a small wrench to fit through the hole and turn the bulb holder counter clockwise. The rest is trying to fiddle it out of the housing. That is how I did it.
2012 OEM+ Ingot Silver Metallic Hatchback w/ Premium Package & Sunroof
Touring05 is offline
Old 09-14-2012, 03:54 PM   #10
VectorZ
VectorZ's Avatar
Fan#: 100457
Yeah I finally got it out, but of course the LED bulb had 3 of the 7 burned out. Tried to get the old bulb back in and I could NOT get it back into the housing. I just took the bulb out, put a piece of tape over it and put it back in the car. I'll just have the dealer swap it out next week. I don't have the time to *&^% around with it.
VectorZ is offline
