#1 | ||||
replacement 50,000 mile engine now ticks...
So I finally got my engine installed after 3 months of searching for one .I found one on Automotix.com with 50,000 miles on it for $1500. So I go pick my car up the shop says everything was fine so I pay them the install fee. I drive not even half a mile and I hear a slight tick...I call them and they say it wasnt doint that when they tested it the whole .5 miles they drove it. they said its probably a stuck lifter most likely from the engine sitting so long at a junkyard. it has now gotten louder .I will take it back to the shop in the morning but would like some imput on what it could be. thanks
| Sponsored Links | |||
Advertisement | |||
#2 | ||||
i <3 my ST
Was fresh oil and filter installed as well?
2012 Fusion SE 3.0L V6 '86 XR4Ti ; 2.3L Turbo, 15psi '07 ST ; formally bewst'd - R.I.P D23 Crew: #07 |
#3 | ||||
By the way these motors have solid lifters. I guess you checked the oil level & whether it is new oil. When its running can you hear where its ticking= above or under neath the car? I'd also check to see what kind of warranty there is. Like a 90 day or whatever & if they cover swapping out the motor cost's. I'd help if you were closer = Seattle area. Checkout the n/w section 4/22 I helped Bertst change out his motor= g2g motor swap day. What was wrong w/ the original motor? Low oil level perhaps?
#4 | ||||
I had a similar issue and sound on my replacement engine--right after it was put in--inmy case--the ticking was most noticeable only on first start/cold--so I had to keep the car overnight with them for them to diagnose-- the ford dealer then also told me it was lifters sticking--people here at the time seemed to disagree since they are solid as felix mentioned. Possibly a valve guide?
In any case--the dealer at the time put in some sort of additive to prevent valve/lifter sticking. I was sceptical that it would work--but it cured the problem--and 50K miles on--no issues or recurrence yet...
D23 Crew #29 |
#7 | ||||
I went thru this with LKQ, a 2.3L, it ticked from day one, I then bought a reman engine, died in 3 weeks, under warrenty they replaced it and now I am 3K miles and 1 month into a new motor and no issues.. cost about double your $1500 and then some but I am happy now, however I was told from LKQ that the warrenty was void if i accept a 2.3L motor since my car came with a 2.0L and will not replace it again if it went out. so if you get one, avoid LKQ
Car #1 2007 Focus ZX3 SE - Blue 2.3L, Automatic, Toms Tune, OBX headers, FSWERKS Cold Air Intake and Exaust, Loaded Car #2 2007 Focus ZX3 S - Silver 2.0L, Manual,TOTALED!!!! (Half Rebuilt) Car#3 Mustang GT 2007 LOADED! |
#8 | ||||
Thats a bummer. Sorry to here that. Its Critical that you keep your oil level up= only holds 4.5qtrs. Thats what I see often when a motor goes= low oil level.
#9 | ||||
On 23's a great upgrade is to remove the balance shafts & install a plug in the oil feed hole to the balancer's. It removes 'bout 18-19lbs & 12-14lbs of rotating weight & on top of that you will found your motor now holds 6qtrs of oil. I just used a plug= freeze plug style & staked it into the feed hole & add a windage tray. Don't nick the pan or block w/ the razor blade when scraping off the rtv from the pan & block= take your time on that. You don't want come backs do you= In your case you don't want to redo your work do you? I don't think so. Enjoy the mod too.
#10 | ||||
I think i saw a LKQ sticker on the valve cover.. Ive been searching for awhile and found a website called www.automotix.net and got it from there. I was planning on removing the balance shaft but wasnt sure if that would have voided my warrenty.
