pop/clunk when starting from a stop - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-11-2012, 04:02 PM   #1
AliasJerk
Fan#: 52711
What I Drive: 2003 Screaming Yellow FSVT EAP
FF Reputation: 1 AliasJerk Good Standing Member
2003 SVT, just passed 100k.
I have been battling this issue for the past few thousand miles, it is sort of weird how the car responds to the things I have tried. When starting from a stand still as soon as I start to let the clutch out and the car starts to roll I get a "pop" or a "clack" noise from what feels like the drivers side front, sometimes the passenger side but not as often.
I have also noticed that at lower speeds over rougher roads I get these same noises while holding speed, be it in gear or in neutral, tends to be louder if I am making a right hand turn.
Here is what I have done...
new dogbone, new driver side trans mount, both are straight from Ford. I have new SVT Struts/shocks, new Motorcraft strut mounts, new Roush springs, new Moog sway bar endlinks, driver side inner tie rod was replaced about 2 years ago. I have checked both the inner and outer tie rods and can't feel any play in them. I also just had both front axles replaced due to having ripped CV joint boots.
When I remove the sway bar links and drive sway-bar-less in the front, the noise still persists just as loud. When I am up at cruising speed the noise is entirely gone over any kind of bump. Recently I also started getting a shake up front over 70 miles an hour.
My thought is the control arms are causing this issue, I just was looking for some reassurance before I go and order new control arms and have it not be the issue. Also, I checked rock auto for control arms and there are quite a few options as far as makes, Dorman seems to be the cheapest but I have had poor experiences with their control arms in the past on another car I have owned. I am looking at doing the MOOG control arms, if anybody has used them I would also appreciate if anybody could share their experience with how reliable they are.
Thanks for any help guys!
AliasJerk is offline
Old 09-11-2012, 04:57 PM   #2
Elder
Points 13,380, Level 75
Points: 13,380, Level: 75 Points: 13,380, Level: 75 Points: 13,380, Level: 75
Level Up 33% Completed
Was wondering about ball joints, especially considering all the other things you've replaced already....
sailor is online now
Old 09-11-2012, 06:13 PM   #3
tupic310
Fan#: 102319
What I Drive: 2002 silver focus
FF Reputation: 1 tupic310 Good Standing Member
i have the same problem, but on the passenger side. i changed the control arm, sway bar link, axle, and inner and outer tie rod. nothing. i will be checking the engine mounts and my shock as soon as i get a day off from work. hope you get it fix, and let me know if you found the problem.
tupic310 is offline
Old 09-11-2012, 10:57 PM   #4
AliasJerk
Fan#: 52711
This isn't reassuring.
guess I am going to order the control arms this friday, hopefully this resolves my problem.
Old 09-11-2012, 11:31 PM   #5
Minchkin
Minchkin's Avatar
Fan#: 92792
Points 948, Level 16
Points: 948, Level: 16 Points: 948, Level: 16 Points: 948, Level: 16
Level Up 48% Completed
FF Reputation: 3 Minchkin Good Standing Member
I would say have those axles checked out. How long ago were they replaced?
Originally Posted by Fact Core from Portal 2
Before the Wright Brothers invented the airplane, anyone wanting to fly anywhere was required to eat 200 pounds of helium.
SES #032
Minchkin is offline
Old 09-12-2012, 12:01 AM   #6
SilverST05
SilverST05's Avatar
Fan#: 103209
What I Drive: 2005 Silver Frost ST
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
FF Reputation: 1 SilverST05 Good Standing Member
I would say motor mounts or axles or both. Either one can cause the other to go bad.
2005 ZX4 ST, Stealth CAI (so far)
Used to have, and will always regret selling, 1970 Mach 1.
"Everday is a good day, just try missing one."
"As soon as we're born we start dying, so you might as well have a good time."
SilverST05 is offline
Old 09-12-2012, 02:11 AM   #7
oshoguno
Fan#: 45853
What I Drive: 2012 Focus SE Hatchback
Points 661, Level 13
Points: 661, Level: 13 Points: 661, Level: 13 Points: 661, Level: 13
Level Up 22% Completed
FF Reputation: 1 oshoguno Good Standing Member
Is it possible that your brake caliper is sticking?
oshoguno is offline
Old 09-12-2012, 10:20 AM   #8
AliasJerk
Fan#: 52711
a week ago, and I had the exact same noise before and after the axles were replaced.
I thought both of these originally as well.
I have pulled all of the mounts, replaced the dogbone twice with Ford replacements, and the drivers transmission mount twice with Ford replacements, the only one I haven't done is the passenger mount, and when I pulled it to inspect it there isn't a thing wrong with it. I also tried a pry bar on the motor to attempt to move it and it hardly budges. As mentioned above, axles are brand new and the same noise persisted before and afterward.
The only thing that does make it go away for a short amount of time is if I put the front of the car in the air and put it back down, it goes away for about 5-10 minutes of driving then comes right back to how it was all over again.
Old 09-18-2012, 10:43 AM   #9
AliasJerk
Fan#: 52711
Quick update. Issue was with control arms, all fixed ^.^
