Installed FRPP kit. Now hearing a noise - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-03-2012, 12:52 AM   #11
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Points 7,594, Level 58
Points: 7,594, Level: 58 Points: 7,594, Level: 58 Points: 7,594, Level: 58
Level Up 22% Completed
Forum Activity 17%
The whole setup is brand new from Tousley including the strut mount. I did however notice that the top cap on the spring of the frpp kit is different than my stock one and I believe so is the strut mount.
Instagram: 5_POINTOH
RAF_S197 is offline
Old 09-06-2012, 01:12 PM   #12
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Forum Activity 17%
Also, here is a pic of the top strut bolt. Does it look right to you guys?
RAF_S197 is offline
Old 09-11-2012, 05:47 PM   #13
gregm5s7
gregm5s7's Avatar
Fan#: 97075
What I Drive: 2008 Ice Blue SE
FF Reputation: 2 gregm5s7 Good Standing Member
Look fine to me, I would just check the torque on them real quick
There are a few threads on this being a common problem on several years of Foci, with the Sway Bar End Links being the solution. IIRC the stock design wears out quickly, and switching to a nicer aftermarket one like Moog's (with a grease fitting) usually fixes it. I've got my Moog's from Rock Auto, just waiting to install in the next week or two. I think it is was under $50 for both
edit: Just re-read your reply, you have already replace your end links! I also saw the thread where you said you used the replacement Ford ones, I don't know if these are better or worse than the Moog's. The main noise I'm experiencing with my FRPP is almost like a squeaking/ somewhat metallic sound, and I think from the rear. Happens at low speeds and on relatively flat roads. I'm probably going to take off the wheels and re-torque everything.
My endlink problem is a distinctive pop/clunk sound, usually happens when I'm pulling into an inclined house driveway, and reversing out to park my car.
FRPP Kit
Papa Smurf II
gregm5s7 is offline
Old 09-11-2012, 06:07 PM   #14
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Forum Activity 17%
My noise sounds similar. How sure are you it's you'r end links?
Also, I never had this noise with the stock suspension
RAF_S197 is offline
Old 09-11-2012, 06:21 PM   #15
Black&Tan
Black&Tan's Avatar
Fan#: 9971
What I Drive: '06 Liquid Grey SES hatch
Points 6,024, Level 50
Points: 6,024, Level: 50 Points: 6,024, Level: 50 Points: 6,024, Level: 50
Level Up 37% Completed
FF Reputation: 8 Black&Tan Good Standing Member
Buy-Sell-Trade Rating: (9)
Which frpp kit did you buy? What model number? What springs did you use?
HN #171
Black&Tan is offline
Old 09-11-2012, 08:41 PM   #16
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Forum Activity 17%
I can't rember the part numbers off hand but I ordered them through Steve @ Tousley Ford. I know they are 2006-2007 FRPP shocks and struts aswell as springs. There was 2 options for the springs. The first ones were discontinued so he got me the second option which were just supposed to be slightly stiffer
RAF_S197 is offline
Old 09-11-2012, 10:01 PM   #17
Black&Tan
Black&Tan's Avatar
Fan#: 9971
I would try to isolate the side that is making noise. Find a pothole or other road obstruction and drive just one wheel over it.
How did you assemble the strut?
HN #171
Old 09-11-2012, 10:13 PM   #18
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Forum Activity 17%
Both are doing it but the right one is worse and louder.
I compressed the spring, put it on the strut, put on the top hat, bearing and strut mount. I got the strut nut on fairly right and released the spring compressor. I then tightened down the strut nut real tight and installed it on the car. I then was able to get the nut to tighten another 1/4 turn on each side once in the car.
RAF_S197 is offline
Old 09-11-2012, 10:18 PM   #19
Black&Tan
Black&Tan's Avatar
Fan#: 9971
Did you set the strut nut to the correct torque?
HN #171
Old 09-11-2012, 10:24 PM   #20
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Forum Activity 17%
I didn't use an actual torque wrench but its on Really tight. I'd be willing to bet its on tighter than it is lose
RAF_S197 is offline
