How can i get around 200 hp - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-06-2012, 08:08 PM   #21
Black&Tan
Black&Tan's Avatar
Fan#: 9971
What I Drive: '06 Liquid Grey SES hatch
Points 5,976, Level 50
Points: 5,976, Level: 50 Points: 5,976, Level: 50 Points: 5,976, Level: 50
Level Up 13% Completed
FF Reputation: 8 Black&Tan Good Standing Member
Buy-Sell-Trade Rating: (9)
Originally Posted by King785 View Post
U dont have to sell ur car if i dont want to...if i dont then they won't let me run the next race.all the cars that make it to tech shead have alot more than that in there cars too.so far they haven't had anyone put up a fuss or try to pull anyone or buy them out yet.u can't win with a stock carout there.im going to Anderson speedway tomorrow night to race.i haven't raced that track yet
So basically it's a "stock" class where everyone cheats and no one is stock?
Wow.
HN #171
Black&Tan is offline
Old 09-06-2012, 10:09 PM   #22
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,780, Level 100
Points: 51,780, Level: 100 Points: 51,780, Level: 100 Points: 51,780, Level: 100
Forum Activity 33%
Buy-Sell-Trade Rating: (28)
It isnt cheating till you get cought , the rules are there as a guide line to all the things they dont talk about
I have been on both sides of this with being a Tech guy and reading the rules and building the cars
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 09-06-2012, 10:29 PM   #23
Black&Tan
Black&Tan's Avatar
Fan#: 9971
Tom
Heh. Sounds a lot like steroids and performance enhancing drugs in sports.
In that case I say go with all the svt bolt-on stuff in addition to the cams and shaving the head down. It will all look bone stock to the untrained eye.
HN #171
Old 09-07-2012, 11:42 AM   #24
n00btard
Fan#: 101317
What I Drive: 2013 VW Golf 2.5 3 door
FF Reputation: 1 n00btard Good Standing Member
Originally Posted by BigRed03 View Post
15s and low profile tires will help you gear you down further for better acceleration
Wait...wait..wait...(sorry for a mini TJ)
This is new information to me. Lightweight wheels makes perfect sense to me ---but how does a smaller diameter do anything but aid in cornering?
n00btard is offline
Old 09-07-2012, 12:39 PM   #25
GrndZero
GrndZero's Avatar
Fan#: 9630
What I Drive: 2002 Silver ZX5
FF Reputation: 3 GrndZero Good Standing Member
The smaller diameter of the wheels helps in extending speed in lower gears. To use an example. This is what a friend found back a couple years ago. He used to race his SVT at the track.
With the stock size 17's he would have to shift out of 4th towards the end of the track because he was no longer gaining any more speed out of the run for a short period before the end of the 1/4mile.
By switching to 15's drag wheels he was able to stay in 4th to the end without loosing any power.
It has been awhile and I do not know the specifics off the top of my head but it all has to do with the diameter in which wheel has to cover to make a complete rotation.
I am sure someone will post a better example/definition.
2002.5 Silver Euro ZX5
GrndZero is offline
Old 09-07-2012, 02:15 PM   #26
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
the 15s have a smaller circumference and less weight. tire circumference, final drive, and gear ratio all play into acceleration. Since changing gear ratios is expensive and time consuming (or not possible with the getrag in the SVT, swapping to 15s is easier and relatively cheap. SVTs that autocross frequently do this because 1, 2, and 3 are all tall gears, and having the 15s helps get better times.
in the turbo car world, people tend to put not only wider (for traction) but taller wheels/tires on to make a larger circumference, effectively making the gearing longer, meaning I can now get up to 40 instead of 35 in 1st (not a real example, just throwing numbers out).
BigRed03 is offline
Old 09-08-2012, 05:01 AM   #27
n00btard
Fan#: 101317
I completely failed to think about the effects of tire size on gear stepping. Thanks!
Posted via FF Mobile
n00btard is offline
Old 09-10-2012, 08:32 PM   #28
steeda423
Fan#: 58410
What I Drive: 2002 Yellow STEEDA Zx3
FF Reputation: 1 steeda423 Good Standing Member
It's gonna take some work to get to 200hp
2.0 Litre ZETEC
  • Block - .085 over
  • Custom Wiseco Pistons 86mm IIRC
  • Crower Rods
  • Hardened Oil Pump Gear
  • ARP Head / Main / Flywheel bolts
  • Compression - 13.5:1
  • Race Fuel - 110 Octane
Head:
  • Massive Ultimate Head
  • Crower Stage 2 Cams
Intake:
  • Jenvey Individual Throttle Bodies from UK
  • Custom Air box
  • Cold Air Intake - Piped from Driver Headlight
Bolt Ons:
  • Underdrive Pulleys
  • Focus Central Adjustable Cam Gears
  • VCF Motor Mounts
  • SCT Xcal 2 Tuning Module
  • SunPro Digital Tach w/Shift Light
Motor by Massive Speed Systems, Spring Grove, IL
Tuning by Kurgan Motorsport
189hp 166 ft.lbs torque in 105 degree air temperature
Red Line - 8500 rpm
Ignition:
  • MSD DIS Dual Ignition Box
  • MSD Tach Adapter
  • MSD Coil
  • Massive 10mm wires
Exhaust:
  • JBA full Race Header
  • MSRB Exhaust
'02 Yellow Steeda 2002-023 - SCCA Chicago - Salt Creek Sports Car Club #423 EP
steeda423 is offline
Old 09-11-2012, 08:01 AM   #29
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,132, Level 100
Points: 138,132, Level: 100 Points: 138,132, Level: 100 Points: 138,132, Level: 100
Forum Activity 54%
Buy-Sell-Trade Rating: (11)
^Badass ITB's and custom intake box to use the MAF fuel injection!
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 09-11-2012, 11:08 AM   #30
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 33%
You should be much higher power then that I would think , On the Caterham guys I do the engines and tuning for at 10.8 to 11.2 compression with ITB , stg2 cams were making mid 182-186 HP
The ones ITB with 12.5 are at the 195 to 200 mark , why are you at 190 with 13.5 ?
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
