Door Creak Dilemma - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-06-2012, 10:20 AM   #11
smartly
Fan#: 92537
What I Drive: 2011, Candy Red, Titanium 1.6TDCi +
FF Reputation: 1 smartly Good Standing Member
You need to take it to another dealer for a second opinion, is the piece they are cutting out part of the body shell? If not they should be able to strip panels back and then replace the panel that is creaking.
2011 Ford Focus 1.6TDCi in Candy Red
smartly is offline
Old 09-06-2012, 10:25 AM   #12
revhigh
Fan#: 98516
What I Drive: 2012 Mazda 3 SkyActiv 6A Touring
FF Reputation: 1 revhigh Good Standing Member
If it bothers you (as it would me) ... I'd have them do it and then make them work on it until it was perfect if need be. You have every right to a car that works properly without any self inflicted visible defects.
Good luck and I hope they fix it for you perfectly the first time !
Also, as another poster mentioned ... I'd think they could replace the whole door frame (or whatever was needed) with all new parts far cheaper than doing the kind of 'surgery' they're talking about.
REV
revhigh is offline
Old 09-06-2012, 11:15 AM   #13
Blizzard35
Fan#: 88463
What I Drive: 2012 Lincoln MKZ AWD Ingot Silver
FF Reputation: 2 Blizzard35 Good Standing Member
My car has had the "exact" same problem since the day I took ownership of it back in July of 2011. The dealer told me there was nothing that could be done to fix it, so if indeed the problem has been identified as a manufacturing defect then the new car warranty would apply. I would be more concerned that if the door was replaced, the paint would not match the rest of the car!
Blizzard35 is offline
Old 09-06-2012, 04:27 PM   #14
Altis
Fan#: 89540
What I Drive: 2012 Sterling Grey SEL Hatch 5MT
FF Reputation: 1 Altis Good Standing Member
Blizzard35, it's not a problem at all with the door. It's the metal piece of the frame on the car. It's also a tough place to do partial paint work, so I imagine it won't look quite original.
Altis is offline
Old 09-06-2012, 04:38 PM   #15
FordService
FordService's Avatar
Points 3,492, Level 36
Points: 3,492, Level: 36 Points: 3,492, Level: 36 Points: 3,492, Level: 36
Level Up 95% Completed
Forum Activity 27%
Originally Posted by Altis View Post
...My driver's door has made a metallic creaking noise when you open it. It isn't that loud, but it's pretty irritating on such a nice new car. I've had it in to be fixed a few times already (my car has been in the shop probably 10 times for warranty stuff over the past year), yet it is no better.
The dealer sent it over to the body shop, and apparently the problem is within the sheet metal that the door mount attaches to. The solution is basically to hack out that bit and weld new stuff in (in short). I think it's around a $3000 job to do, even.
I just can't seem to think that this is a good idea... Am I wrong to be hesitant? It seems like it would open the door to new problems and never be the same again. It's some pretty major surgery, to say the least. Any thoughts on how I should proceed?
I almost feel like I should not have it done and see if Ford will somehow compensate a different way...
...It is covered under warranty, but the issue is that the car won't be the same coming out the other end. They aren't just replacing a part, but sawing into the sheet metal and welding a new piece within it, repainting, etc. You'll be able to look at it and see the spot where it was reconstructed. Once you've spot welded new sheet metal in the door frame, it opens up potential for a world of new problems, such as door alignment issues...
You're welcome to get second opinions if you'd like. Please contact our Canadian Customer Relationship Centre at 800-565-3673 for further assistance.
Originally Posted by Some Guy From NY View Post
Wait what...this isn't covered under the warranty?
If it is...let them do it. Anything that goes wrong will be on them to fix.
Originally Posted by NickCornell View Post
Do not let them perform that kind of surgery. Get a second opinion!
Originally Posted by forceflow2 View Post
Maybe I am way off, but it seems like you can get an entirely new door for far less than $3000. If it's in the sheet metal itself, it sounds like a manufacturing defect. I'd make them replace it instead of trying to fix it...
Originally Posted by smartly View Post
You need to take it to another dealer for a second opinion...
Good luck and I hope they fix it for you perfectly the first time!...
Thanks for jumping in and giving advice; you guys are awesome!
Thomas
FordService is online now
Old 09-06-2012, 07:04 PM   #16
Altis
Fan#: 89540
I did suspect this piece to be the culprit all along, and it's pretty confirmed now. It's a matter of whether or not to have it done.
Altis is offline
Old 09-06-2012, 08:26 PM   #17
elwood125
elwood125's Avatar
Fan#: 17784
What I Drive: Mk 3 Blue Candy SE Sport 5spd Hatch
Points 1,197, Level 18
Points: 1,197, Level: 18 Points: 1,197, Level: 18 Points: 1,197, Level: 18
Level Up 97% Completed
Forum Activity 11%
FF Reputation: 4 elwood125 Good Standing Member
My car has the same issue... after we replaced the door check and the noise was still there, tech found out the same things you guys have. No clue what the right thing to have done is.
'12 Blue Candy 5spd SE Sport- On Eibach Pros, Fusion Dark Chrome 18's, Steeda STS/CAI/RSB/RMM RL hood struts, Ecoboost rear muffler
elwood125 is offline
Old 09-07-2012, 05:07 AM   #18
GhiaFan
GhiaFan's Avatar
Fan#: 50498
What I Drive: 2007 Panther Black Focus 1.6 Ti-VCT
Points 15,423, Level 80
Points: 15,423, Level: 80 Points: 15,423, Level: 80 Points: 15,423, Level: 80
Level Up 15% Completed
Forum Activity 9%
FF Reputation: 13 GhiaFan Great Standing Member
Ford Canada has finally come out of the closet and is now conversing with their customers on Facebook http://www.facebook.com/FordCanada And Ford Canada is really, actually replying to their customers who have issues with getting their vehicles serviced properly.
Much better then calling the help line IMO
GhiaFan is online now
Old 12-20-2013, 12:17 PM   #19
drsmith30
Fan#: 129522
What I Drive: 2013 Ford Escape
FF Reputation: 1 drsmith30 Good Standing Member
Did you ever have the work done? If so, did it resolved the problem?
drsmith30 is offline
Old 12-20-2013, 01:44 PM   #20
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Points 2,415, Level 29
Points: 2,415, Level: 29 Points: 2,415, Level: 29 Points: 2,415, Level: 29
Level Up 77% Completed
Forum Activity 11%
Mine has also turned up with this problem. It reminds me of my wife's old 04 Neon. Try a wax based motorcycle chain lubricant. It's only a temporary fix, but should last quite a while.
BetaDnB is online now
