Optimizing Accel and Decel - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-05-2012, 01:58 PM   #11
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Points 7,361, Level 57
Points: 7,361, Level: 57 Points: 7,361, Level: 57 Points: 7,361, Level: 57
Level Up 6% Completed
Forum Activity 11%
Originally Posted by darkangelism View Post
So it all depends on how far you can coast, longer coasts are better in neutral but potentially shorter ones are better in gear
Oh yeah I mean honestly I'll still coast in gear to most lights because I don't want to be stuck in neutral if the light turns green. But on more rural roads with a known stop sign way up ahead, neutral is the way to go.
Originally Posted by VectorZ View Post
Cool stuff! One thing I noticed about this car is that even in gear on a flat surface it coasts a much longer distance than any other car I've owned, and I use that frequently now to boost my mileage.
Makes sense, given the LRR tires (assuming you don't have the Ti handling package) and slippery form.
kam327 is offline
Old 09-05-2012, 02:12 PM   #12
Points 10,060, Level 67
Points: 10,060, Level: 67 Points: 10,060, Level: 67 Points: 10,060, Level: 67
Level Up 3% Completed
Forum Activity 22%
The Pilot Sport 3 tire is a Green-X lrr summer performance tire though. The standard Conti procontact tires are not lrr, only the 18" PS3s and the 16" SFE specific tires.
suss6052 is online now
Old 09-05-2012, 02:23 PM   #13
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 11%
Maybe not in the marketing, but Consumer Reports gave it a "very good" rolling resistance rating. Only 2 other tires in its class received a higher "excellent" rating.
kam327 is offline
Old 09-05-2012, 02:25 PM   #14
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
Points 28,213, Level 98
Points: 28,213, Level: 98 Points: 28,213, Level: 98 Points: 28,213, Level: 98
Level Up 87% Completed
Buy-Sell-Trade Rating: (29)
great data! happy to see that coasting in neutral is the way to go (as i thought)
==2012 Kona Blue Mustang V6==
==1972 Skylark==
Buickboy is online now
Old 09-05-2012, 02:27 PM   #15
Borski
Borski's Avatar
Fan#: 100013
What I Drive: 2012 Focus - Black - SE
Points 1,361, Level 20
Points: 1,361, Level: 20 Points: 1,361, Level: 20 Points: 1,361, Level: 20
Level Up 61% Completed
FF Reputation: 1 Borski Good Standing Member
Good work OP.
Just wondering, you doing this on a manual or auto?
Sent from my Motorola Atrix via FF Mobile
| 2012 BLACK SE | DD & AutoX |
| 5 SPEED | SPORT PACKAGE |
| EIBACH SPORTLINE SPRINGS | SUMMER RUBBER: BF GOODRICH SPORT-COMP 2. ALL SEASON RUBBER: KUMHO ECSTA 4X |
Borski is offline
Old 09-05-2012, 02:31 PM   #16
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 11%
Also tirerack indicates the ProContacts in the sizes that fit the Focus 16" and 17" wheels "feature low rolling resistance technology." Didn't know certain sizes of a tire line could be LRR while other sizes aren't, but..... there you go.
Originally Posted by Borski View Post
Good work OP.
Thanks. Sorry, should've specified - auto and 17" ContiProContacts.
kam327 is offline
Old 09-05-2012, 02:39 PM   #17
Forum Activity 22%
If they were not different in the 16" size why were they charging $495 in 2012, and $95 in 2013, the most important of the other changes were actually made standard on the other models including the active grille shutter system. Tire rack also listed two different 16" contiprocontact tires in the o.e. fitment, one is lrr, one is not afaik.
Old 09-05-2012, 02:49 PM   #18
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 11%
I've got two words for you. Rip. Off.
Seriously, I was just on tirerack and there's no OEM tire listed for the SE w SFE package, even though that option is in the dropdown menu. And only one OEM tire is listed for the regular SE, the CPC.
kam327 is offline
Old 09-05-2012, 03:11 PM   #19
Forum Activity 22%
There are two seperate continental procontact tires listed on tire rack in the o.e. size, although they only code one as an O.E. tire for some reason.
http://www.tirerack.com/tires/tires....nomy%20Package
These are LRR and are $133 a piece, they are not listed as O.E. fitment to the SE-SFE, but since they are the only LRR continentals listed in this fitment it kind of has to be these, they also have a poorer wear rating of 400 AA A.
The offical O.E. contiprocontact tires are $118 each from tire rack, and are not rated as lrr at all. They have a wear rating of 500 AA A
http://www.tirerack.com/tires/tires....conomy Package
Now the question is why are they using two seperate tires where one would do?
Old 09-05-2012, 03:31 PM   #20
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 11%
Well you're right it's very strange. Actually there's 3 CPC tires listed in that size. Two are listed as LRR. I know Consumer Reports lists a ContiProContact with Ecoplus Tech and gives it an excellent LRR rating. But I don't see that one on tirerack. It's a bit of a mystery.
kam327 is offline
