POLL: K&N Intake - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: Have you had problems with the MAF housing?
No problems, whatsoever 12 85.71%
I was very careful, but still broke my MAF housing 0 0%
I wasn't very careful and broke my MAF housing 2 14.29%
Voters: 14. You may not vote on this poll
Old 09-04-2012, 06:21 AM   #11
2kwik4u
Fan#: 102523
What I Drive: '12-Sonic Blue-5dr/5spd/203A/Roof
Points 1,642, Level 23
Points: 1,642, Level: 23 Points: 1,642, Level: 23 Points: 1,642, Level: 23
Level Up 43% Completed
FF Reputation: 1 2kwik4u Good Standing Member
Have you guys verified the reported MPG vs actual measured MPG? I know I'm only 3 fill ups into the car (less than 1k miles currently), but the computer has reported everything from 28.9 to 29.5, with measured ranging from 28.5 to 28.7. I know in tracking previous vehicles (Current A4, and old Yukon) in consitency between reported and measured I found that there is a very small window where the reported is accurate. The A4 is around 22mpg, and gets further off the further away you get from that number, the Yukon was around 16mpg, again with the error getting greater the further you moved away from that.
Point being, do we know that the K&N ACTUALLY lost mileage, or did it only REPORT worse mileage? Just curious, as it's also on my radar for future purchase, and all of my financial justifications for the new car purchase (that I didn't really want to make) are based on 30mpg, and $3.50/gal. So if it indeed drops the measured mileage 3mpg, I'll steer clear. I'm already hoping the mileage comes up a little to that 30mpg mark that seems to be the Fuelly average mpg numbers.
BTW, here's a link to the data I've collected on the Focus so far.
2kwik4u Fuelly - Focus Page
2kwik4u is offline
Old 09-04-2012, 08:46 AM   #12
vluc
Fan#: 10803
What I Drive: 2012 Focus Titanium, Ebony
FF Reputation: 1 vluc Good Standing Member
With no change in driving habits, it dropped MINE. Can't say what it will do for others based on terrain, driving commute, etc. What works/doesn't work in Western PA may be the opposite in Oklahoma, for instance. I did see increases with the drop-in, so assuming all other variables remained the same, the only difference was the SRI/CAI.
Hand calcs were quite close, so I have confidence in the numbers. I'm at around 16.7K mileage wise since February when I bought the car.
vluc is offline
Old 09-04-2012, 08:52 AM   #13
2kwik4u
Fan#: 102523
Originally Posted by vluc View Post
......Hand calcs were quite close, so I have confidence in the numbers.....
Thats what I was looking for. Some verification of the reported numbers to the actual numbers.
2kwik4u is offline
Old 09-04-2012, 10:50 AM   #14
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
The reason my MAF housing cracked and broke was not due to overtightening the filter, as it was with others. The "hump" hose that connects the aluminum intake tube to the MAF was VERY tight, and I applied pressure to the filter-end MAF flange with my hand while trying to fit the two pieces together. This weakend the flange, and eventually it cracked after the filter was fitted.
Since I've replaced the MAF housing (more carefully), I have had zero issues--no damage to the MAF housing and no loosening of the filter.
Hatch Nation #90
TboneZX3 is offline
Old 09-04-2012, 11:34 AM   #15
vluc
Fan#: 10803
When dyno85 and I exchanged messages, he indicated that he was close as well with hand calcs.
vluc is offline
Old 09-16-2012, 03:51 PM   #16
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,283, Level 95
Points: 25,283, Level: 95 Points: 25,283, Level: 95 Points: 25,283, Level: 95
Level Up 94% Completed
Yeah, my fuel mileage computer average mpg stays pretty close to my hand calc mpg (within .5 mpg, give or take). I have noticed that if you take your car outside of the norm of the last tank (i.e.-take a long highway trip when your last tank was all in town, etc.) that your average mpg readout will go way out of whack. I believed, during the one trip that I took, that a couple of tanks were around 5 mpg off.
As for the intake, I've seen and heard people on both sides of the mpg question. I don't know full details behind every situation, so I cannot verify in either direction. Speaking directly from the what I've seen on the graphs, I can see where the Typhoon could cause a loss in mileage. In non-RACECAR driving (below 3200 rpm), the Typhoon was showing roughly 5 hp less, with up to 8 ft lbs less tq.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 09-16-2012, 04:57 PM   #17
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
Buy-Sell-Trade Rating: (17)
I've used a k&n filter on my cai for about 90k and have never had any problems with the maf sensor. Just follow the directions when cleaning/re-oiling and you'll be fine. No changes in mpg's either.
I now drive a Japanese Ford.
macdiesel is offline
Old 09-17-2012, 12:21 PM   #18
Brabs_Weather
Fan#: 93741
Just ordered the rx-4870, gonna use the end of the stock filter the make the support ring.
What it will look like when I am done....http://www.pumaspeed.co.uk/product-K...5609.jsp&pic=4
2012 Ford Focus Titanium
K&N X-4870. Steeda RSB
Brabs_Weather is offline
Old 09-26-2012, 01:17 PM   #19
VOLDAR
VOLDAR's Avatar
Fan#: 90444
...I can see where the Typhoon could cause a loss in mileage. In non-RACECAR driving (below 3200 rpm), the Typhoon was showing roughly 5 hp less, with up to 8 ft lbs less tq.
Is it pertinent to say that the loss you saw was between your setup with the snorkel delete+K&N drop in and not from the stock? Because everywhere I look on the net I didn't see the loss you are talking about when compared to a stock car. Or am I wrong ?
---replaced by---
VOLDAR is offline
Old 09-26-2012, 01:48 PM   #20
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Yes, the loss is seen in comparison to my previous set-up with Newmission and all. I have the files on my car separately for my completely-stock run, I just don't have the actual program in order to do a direct overlay. I've been meaning to do that for a while, I should see about getting his laptop this weekend...
Sent from my stupid phone.
September '13 ROTM
2014 FiST-
