intake manifold butterfly flap issues - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-28-2012, 11:42 PM   #1
WSkobra
Fan#: 93397
What I Drive: 2007 Focus SE 4dr Dark Shadow Gray
Points 675, Level 13
Points: 675, Level: 13 Points: 675, Level: 13 Points: 675, Level: 13
FF Reputation: 1 WSkobra Good Standing Member
I did some research on the dtec focus about compression ratios and came across an article that stated that there is a major fault in the materials of the plastic manifold. Apparently the butterfly flaps will eventually break out and get sucked into the motor and destroy the motor. Was wondering if anyone has had this issue. I am trying to find a way to stick this issue on Ford if this is a known problem on our motors. Mazda had the same issue with the manifold on their Mazda 3. Yet Mazda and Ford shared the same technology on these motors which included the manifold and Mazda put a recall out for it but Ford won't. If you had this issue let's hear what you have to say about it.
WSkobra is offline
Old 08-28-2012, 11:52 PM   #2
leemerlord
Fan#: 82872
What I Drive: 2013 Race Red Focus SE Hatch
Points 150, Level 2
Points: 150, Level: 2 Points: 150, Level: 2 Points: 150, Level: 2
FF Reputation: 1 leemerlord Good Standing Member
ive had something quite similar in a way, on the passenger side of the manifold there was a small plastic cap holding the rod in place, long story short cap fell out causing air leak. went to the dealer for replacement and the new one ended up not having those flaps. not sure if it is because of the flaps coming loose and causing failure.
leemerlord is online now
Old 08-29-2012, 03:25 AM   #3
WSkobra
Fan#: 93397
These flaps I am talking about are inside each runner of the intake manifold. You can't visually see them one bit. These flaps control your air/fuel ratio. Dealer says I have to buy the whole intake manifold assembly in order to fix this small problem. I don't see the need of replacing the manifold if these flaps were designed to be removed if damaged. This tells me they knew about the problem with the cheapness of the manifold. I believe its just their way of trying to make more money off these cheaply made cars.
WSkobra is offline
Old 08-29-2012, 09:45 AM   #4
KCaudill
Fan#: 46826
What I Drive: 2006 Tredour Red ZX3 SE
Points 334, Level 6
Points: 334, Level: 6 Points: 334, Level: 6 Points: 334, Level: 6
Level Up 68% Completed
FF Reputation: 1 KCaudill Good Standing Member
These are tumble flaps, there are threads here about these, and let us know if u get a recall on it.
KCaudill is offline
Old 08-29-2012, 11:06 AM   #5
VEGAS
VEGAS's Avatar
Fan#: 75680
not mentioned here but just so you know it is just in the 2.3L, so 2.0L does not have the Flaps
VEGAS is offline
Old 08-29-2012, 10:22 PM   #6
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,954, Level 74
Points: 12,954, Level: 74 Points: 12,954, Level: 74 Points: 12,954, Level: 74
Level Up 26% Completed
Both the 20 & 23 use imrc= aka Tumble flaps. The 23 also has imrc similar to SVT's, but is vacum controlled instead of electric motor controlled as SVT's. The only manifold that doesn't have tumble flaps are the escape manifolds. Why I have no idea. There are threads all 'bout this, hit up the search. Lots & lots of great info.
felixthecat is offline
Old 08-29-2012, 10:42 PM   #7
Drumr90
Drumr90's Avatar
Fan#: 99659
What I Drive: 2006 Black ZX5 auto
Points 3,816, Level 39
Points: 3,816, Level: 39 Points: 3,816, Level: 39 Points: 3,816, Level: 39
Level Up 11% Completed
FF Reputation: 3 Drumr90 Good Standing Member
Posted via FF Mobile
So basicly if i go to ford and buy new intake then the flaps arent there
Drumr90 is offline
Old 08-30-2012, 12:11 AM   #8
VEGAS
VEGAS's Avatar
Fan#: 75680
i didnt see tumble flaps in my 2.0L.. they different then the 2.3L?
are some 2.0L different? ::NVM:: EDIT**
I looked up what you told me not to long ago..
The 23 has imtv= intake manifold tuning valve. Wheres the 20's only have imrc= intake manifold runner control- aka tumble flaps. It would be a lot easier for you since your going to change out the manifold anyhow w/ the cossie style, to leave it the way it is now. You would have to figure out how & where to hook up the imtv system & w/ that you'd need a tune, since the 20's don't have imtv's. A tune for that would probably cost you more than one for the cossie style manifold. I'd put your cashola else where= like a torsen or CFM's lower control arms, a set of cams, etc. Your cars got to run pretty strong now, huh.
Does the OP have a 2.3L or 2.0L? since he owns a 2007 Focus SE I will assume a 2.0L ?
and to the OP, if you seriously need to repair the intake I would buy the intake off ebay for $230 if you have a turbo tom tune...
http://www.ebay.com/itm/NEW-FORD-FOC...0a632f&vxp=mtr
VEGAS is offline
Old 08-30-2012, 02:19 PM   #9
mrdeath2000
Fan#: 91996
What I Drive: 2014 White SE 5spd
Points 1,331, Level 20
Points: 1,331, Level: 20 Points: 1,331, Level: 20 Points: 1,331, Level: 20
Level Up 31% Completed
FF Reputation: 3 mrdeath2000 Good Standing Member
You can remove the flaps and have your car tuned to run without them. I had that done in my 06 Mustang GT (see CMDP plates, charge motion delete plates)
The 2.0 has the tumble flaps and there was a change between 06 to 07 in the factory tune of them that actually bumped up the mpg in 07.
2014 Focus SE Manual -
2006 Focus ZX4 SE Auto -commuter 110k /traded
mrdeath2000 is offline
Old 08-30-2012, 10:41 PM   #10
felixthecat
w/ my magic bag
Fan#: 80663
I 2nd that ^^^^. Runs better w/o them. For the Mustangs you can buy oem charge motion plates w/o the flaps or you can get alloy plates, then you'd need a tune.
