Transmission Shaking To/From 1st Gear - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-17-2012, 07:20 PM   #41
noahsfocus
noahsfocus's Avatar
Fan#: 90974
Points 493, Level 9
Level Up 86% Completed
Originally Posted by Nickrand View Post
Wanted to add to this topic by saying that my 2012 Focus with dual-clutch transmission (build date December 2012) also started to shudder and hesitate upon acceleration while going into 2nd gear. This started after 10,000 miles. It only did this on a warm engine (after several starts and stops). It was fine when shifting into higher gears.
Turns out that the clutch was defective. It wasn't releasing correctly. My Ford dealer called the Ford service hotline and they confirmed that this is an identified problem on some Focuses. Replacing the clutch was the only solution. They got a new clutch kit from Ford and completed the repairs in a day.
Just got my Focus back today and the problem is resolved.
Glad it was fixed! Looking like this will need to be done sooner or later to mine as well. It still works pretty good and sometimes doesn't even slip, usually under really light or really heavy acceleration it works fine. But from a stop with medium acceleration; about half way thru 1st gear it will start slipping and I will feel the shudder again right before shifting into 2nd and occasionally it will have a strong lurch or harsh shift into 2nd. I havn't noticed if it's worse after warm up ... seems like it happens randomly all the time regardless of hot or cold. The rest of the gears shift normal but I get a random lurch once in awhile in the upper gears as well but no slippage that I can tell.
I will have it looked at by the dealer to see if they can confirm there is a problem.
noahsfocus is offline
Old 08-17-2012, 08:32 PM   #42
Points 10,038, Level 66
Points: 10,038, Level: 66 Points: 10,038, Level: 66 Points: 10,038, Level: 66
Level Up 97% Completed
Forum Activity 24%
Yes, the shudder only happened from 1st to 2nd I believe. I'm not a car expert. It happened between 20-30 mph when accelerating from a stop. I'm assuming this is 2nd, but could be 1st. No shuddering at higher gears.
Not sure about TSB 11-12-13, but I had the latest TSB performed a month ago, so I'm pretty sure I was updated on everything before I took it in for the shudder problem. Before they replaced the clutch, they also did a DCT reset/re-learn thing which they confirmed didn't fix the problem. It was a bad clutch that wasn't releasing properly at that specific gear.
You can be in fourth gear down to 20 mph, so it could have been between 3rd and fourth at least if it was at low rpm on light throttle, but unless you were at higher rpm when it happens how are you sure that you were in first or second at 20-30 mph?
suss6052 is offline
Old 08-17-2012, 10:26 PM   #43
Nickrand
Fan#: 91960
What I Drive: 2012 Sterling Grey Titanium Hatch
FF Reputation: 1 Nickrand Good Standing Member
It always happened 5-10 seconds after normal takeoff from a stop. I don't think I'd be in third or fourth gear that quickly. Assuming I'd be in first gear immediately after acceleration from idle, it was the release into second gear that the clutch had problems with.
Nickrand is offline
Old 08-19-2012, 08:29 AM   #44
BPEW584
BPEW584's Avatar
Fan#: 101933
What I Drive: 2012 Titanium Hatchback
FF Reputation: 1 BPEW584 Good Standing Member
I will try the battery reset today. Does anyone know what other data/information will be lost (MFT settings, trip etc.)???
BPEW584 is offline
Old 08-20-2012, 10:41 AM   #45
FordService
FordService's Avatar
Points 3,364, Level 36
Points: 3,364, Level: 36 Points: 3,364, Level: 36 Points: 3,364, Level: 36
Level Up 10% Completed
Forum Activity 20%
...Turns out that the clutch was defective. It wasn't releasing correctly. My Ford dealer called the Ford service hotline and they confirmed that this is an identified problem on some Focuses. Replacing the clutch was the only solution. They got a new clutch kit from Ford and completed the repairs in a day.
Excellent; thanks for keeping us in the loop. It sounds like you're referring to the 12B37 Customer Satisfaction Program (DCT reset), which was performed a little while ago. Keep it a well-oiled machine with these: http://owner.ford.com/servlet/Conten...iceCouponsPage.
Do you know if TSB 11-12-13 was performed?...
Thanks for the report. So was it fine in first from a stop, and only shuddered from 1st to 2nd?
Hey guys -
Thanks for showing your support! When do you plan on visiting the dealer, noahsfocus?
Your radio settings will be affected. Please take a look at the Owner Guide, 5th Printing for more info: https://owner.ford.com/servlet/Conte...e&ord=68123768. Your dealer is the best party to go over all of this with you too.
Thomas
FordService is offline
Old 08-20-2012, 01:26 PM   #46
ridin440snopro
ridin440snopro's Avatar
Fan#: 37919
What I Drive: 2012 OxFord white Focus
FF Reputation: 1 ridin440snopro Good Standing Member
Add me to the list of shuddering in first gear..... Another problem to add to the list. Have 27k miles. Ill be taking it in soon.....
2003 ZX3
Focus sport header
SVT suspension
Powerworks Supercharger
2012 Oxford White Focus SEL
ridin440snopro is offline
Old 08-20-2012, 01:47 PM   #47
noahsfocus
noahsfocus's Avatar
Fan#: 90974
Points 493, Level 9
Hello Thomas ...
Hoping to get it looked at this week or next week. I have noticed after paying more attention to it that it does become more noticeable after the clutches warm up. I also felt it happen in second gear just once last wknd.
I will post back the results from the service dept when I bring it in.
Old 08-21-2012, 01:49 PM   #48
FordService
Forum Activity 20%
If you'd like, please PM me your VIN, phone number, and dealer info; I'll have your Customer Service Manager look into it.
Hello Thomas ...Hoping to get it looked at this week or next week. I have noticed after paying more attention to it that it does become more noticeable after the clutches warm up. I also felt it happen in second gear just once last wknd. I will post back the results from the service dept when I bring it in.
Excellent! Please remember The Works if you need other services performed as well: http://owner.ford.com/servlet/Conten...iceCouponsPage.
Thomas
Old 08-21-2012, 08:37 PM   #49
nick625
Fan#: 102649
What I Drive: 2012 Focus
FF Reputation: 1 nick625 Good Standing Member
Ford Customer Service or Anyone
Can you tell from the VIN whether the car has the latest trnasmission update? Mine was built 6/12.
nick625 is offline
Old 08-21-2012, 08:47 PM   #50
Forum Activity 24%
fordowner.com or www.etis.ford.com and look for fsas, tsbs et al.
suss6052 is offline
