Old 07-26-2012, 06:44 PM   #1
Kyllgore
Fan#: 1506
What I Drive: '03 ZX3 MTX pitch black,
FF Reputation: 1 Kyllgore Good Standing Member
loss of power at lower engine speedss
I've spent the last 4 days going through the forums, and I am stumped
I have severe loss of power below 3k, over 3k runs fine and normal.
So I figure it's not lack of fuel, I just replaces the PCV hose, it was
slightly better, happens after the engine warms up a bit too most times.
Having to over rev to start from a standstill is killing my MPG.
I'm going to start looking at the egr and dpfe sensor this weekend.
I had a check engine light last time, my car was in limp home mode
i replaced plug wires and coil and it was good, that was 3 years ago.
So what to look at next, vacuum lines all look and feel good.
My few engine mods are SRI and my TB.
Is there any sensors that need to be checked at 110k miles.
if only this modding stuff didn't take so much money
Mac SRI, FC 65mm TB, SVT 5 spokes
SVT brake kit, SS lines up front, it's getting there slowly
1984 Celica GT, it's got better options than my focus
Kyllgore is offline
Old 07-26-2012, 06:58 PM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
Moved your thread to the Technical Chat area so you can get more help with your problem.
I wouldn't worry about a problem that happened 3 yrs ago though it may be time to replace that stuff again depending on the mileage it has. Sounds like you would have a bad vacuum leak to cause severe loss of power below 3k rpm's. Have you ever changed the fuel filter? How does it idle?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 07-26-2012, 07:02 PM   #3
Kyllgore
Fan#: 1506
idle is normal, and the fuel filter was a week ago, I just replaced the wires and stuff 3 years back the original stock was what i had before, i still had the stock battery till 2 years ago it lasted over 6 years, I've replaced tail lights too but my head lights are still original. Not that that matters anyways. but it does sound like vacuum? I'll give it a more extensive look this weekend
Kyllgore is offline
Old 07-26-2012, 07:04 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
That or a sensor is acting funky. Hopefully someone else will chime in with better answers, I don't have my thinking cap on right now.
Moderator for
Technical Chat
Old 07-26-2012, 07:34 PM   #5
Tytanis
Fan#: 101586
What I Drive: 2004 Ford Focus Zetec-E
FF Reputation: 1 Tytanis Good Standing Member
Get a smoke test for $40-60 at your local shop. Sounds like a vacuum leak to me.
Tytanis is offline
Old 07-26-2012, 07:38 PM   #6
Kyllgore
Fan#: 1506
I'll check the vacuum system really well this weekend.
I don't like taking it anywhere if I can do it myself.
Kyllgore is offline
Old 07-26-2012, 07:52 PM   #7
Tytanis
Fan#: 101586
Smoke test is the fool-proof way...
Tytanis is offline
Old 07-29-2012, 03:10 PM   #8
Kyllgore
Fan#: 1506
ok I'm gonna try to dpfe sensor and plug up the egr valve first
Kyllgore is offline
Old 07-29-2012, 05:21 PM   #9
lomita
Fan#: 40561
FF Reputation: 1 lomita Good Standing Member
What year and engine?
There's a big fat rubber hose I found today between the firewall and engine. Routed from engine manifold port, then routed from passenger side to driver side and forward near thermostat housing to a metal vacuum line system on bracket.
The car was bogging cause the vacuum was collapsing the soft rubber hose. I put some stiff rubber fuel hose in in place of the thin rubber oem part and car runs great again.
lomita is offline
Old 07-30-2012, 10:13 AM   #10
aaronmach1
Fan#: 88535
What I Drive: 2001 zx3
FF Reputation: 1 aaronmach1 Good Standing Member
is he talking about the pcv line?
aaronmach1 is offline
