Klutch noise Focus 2012 standard - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-16-2012, 08:19 AM   #1
klotche
klotche's Avatar
Fan#: 91834
What I Drive: 2012, Oxford white, Focus
Points 4,348, Level 41
Points: 4,348, Level: 41 Points: 4,348, Level: 41 Points: 4,348, Level: 41
Level Up 99% Completed
FF Reputation: 3 klotche Good Standing Member
Exclamation Klutch noise Focus 2012 standard
Okay.... I would like to know if anyone had or has this issue...
I have a ford focus 2012 SE sedan with cruise control package
From now on, what i noticed is that when I push the klutch pedal and engage the next gear, At the moment I release the Klutch pedal I hear this annoying noise, like a loud "KLOK" everytime I go from 1st to 2nd speed, and from 2nd to 3rd....
Could anyone help me on that...
Looks like the problem isn't always present also....
By the way, I never go over 3500 RPM..... -_-'
I love my car, but this is the only thing that is getting on my nervs somehow..
I have to raise the volume of my radio to cover it, or else I rage after it....
When you drive near pedestrian and shift next to them... they hear this annoying sound, and I feel like my car worth crap...
klotche is offline
Old 07-16-2012, 08:25 AM   #2
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Points 2,305, Level 29
Points: 2,305, Level: 29 Points: 2,305, Level: 29 Points: 2,305, Level: 29
Level Up 4% Completed
Sounds like you're dropping the clutch.
BetaDnB is offline
Old 07-16-2012, 08:43 AM   #3
klotche
klotche's Avatar
Fan#: 91834
I am not.... even when I take 20 seconds to release the Klutch... it gives the same problem
klotche is offline
Old 07-16-2012, 09:52 AM   #4
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,376, Level 77
Points: 14,376, Level: 77 Points: 14,376, Level: 77 Points: 14,376, Level: 77
Level Up 82% Completed
Forum Activity 19%
Does the car 'lurch' or jerk when you hear the noise?
IF not then:
My first thought is your bottom rear engine mount is gone or failed. (i am not certain those words are the exact right combination of words offically used, but it IS the engine mount, and it is at the bottom)
So the engine is 'loose' enough to clunk around.
(If the mount is broken or loose, the engine WILL move around no matter how easy or hard you shift/clutch.
((If it IS the mount, you should be able to hear the issue if in say first gear (stay in gear), running at say 15mph then let off gas for two seconds, then hit gas hard. CLUNK should follow. ))
So IMO your bottom/rear engine mount is loose or broken.
This is a known issue (so i have read, anyway)
It will not harm your car at all if you get it fixed.
So do not worry about if it caused some 'other' permanent damage.
But it should be looked at.
Elizabeth is online now
Old 07-16-2012, 01:42 PM   #5
klotche
klotche's Avatar
Fan#: 91834
IF not then:
Very usefull, More than thank you !
I'll give you news as soon as I have some (17500 kilometers.. have to set a visit to the dealer for maintenance... I'll tell them about the problem)
klotche is offline
Old 07-24-2012, 08:32 PM   #6
klotche
klotche's Avatar
Fan#: 91834
Bump
klotche is offline
Old 07-25-2012, 06:28 PM   #7
jpolk84
jpolk84's Avatar
Fan#: 97415
What I Drive: 2012 Focus SE w/ Sport Package 5-sp
FF Reputation: 1 jpolk84 Good Standing Member
Do you hear this up front or the rear? I get a bit of a klunk in the rear when going from 1-2 and 2-3 on occasion. The dealer couldn't duplicate it, though.
jpolk84 is offline
Old 07-25-2012, 08:07 PM   #8
klotche
klotche's Avatar
Fan#: 91834
This noise comes from the front for me ... it really looks like a metal part is moving somewhere (maybe the engine mount like said up there)
but I really believe it's a kluth or gear problem ..
help please
klotche is offline
Old 07-25-2012, 10:14 PM   #9
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
help please
If your car drives normally and all you hear is a clunk when you release the clutch pedal, it's most likely your rear motor mount (or RMM as you may have seen it written around here). You have a few alternatives, you can either get Ford's replacement, or if you want a more stiff mount (you'll have some vibrations with it, but no more clunking for sure) you can always buy a solid RMM for a Mazdaspeed 3, or the stock Mazdaspeed 3 mount will be more sturdy than the stock Focus mount as well.
Just a few options for you to consider. If you're still having the problem and haven't had it looked at yet... GO GET IT LOOKED AT, it's a new car with a WARRANTY so use it!!!
Sonic Crew #28
feta_mgp is offline
Old 08-13-2012, 02:34 PM   #10
klotche
klotche's Avatar
Fan#: 91834
I realise that i can hear this noise also when I brake (sometimes...)
I found a way to hear that noise at all time:
staying in first gear, i release the klutch pedal to the friction point, than I push back on the pedal... you do this like 4-5 times, and at all time you release klutch pedal I hear a "clunk"
klotche is offline
