Steering Wheel Controls + Aux Input?? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-23-2012, 06:09 PM   #11
Shempi
Shempi's Avatar
Fan#: 94961
What I Drive: 2002 Sonic Blue SVTF
Points 1,809, Level 25
Points: 1,809, Level: 25 Points: 1,809, Level: 25 Points: 1,809, Level: 25
Level Up 9% Completed
FF Reputation: 1 Shempi Good Standing Member
Honestly I did not like the stock radio and steering wheel controls in my svt at all. I recently pulled out the OEM system and installed a Sony Xplod deck which I absolutely love! I also think it looks more sleek. I picked up the Deck, the dash kit and the harness from best buy and it only cost just under $100 with a 2 year warranty.
Here is a pic I took after the install.
image hosting
Ima Ninjaw!
2002 Sonic Blue SVTF #661
2013 Tangerine Scream ST3
Shempi is offline
Old 07-24-2012, 01:02 PM   #12
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,879, Level 59
Points: 7,879, Level: 59 Points: 7,879, Level: 59 Points: 7,879, Level: 59
Level Up 65% Completed
Forum Activity 16%
FF Reputation: 34 FocusedSlayer Great Standing Member
Originally Posted by keith4594 View Post
ughh it arrived today but i have no clue what to do
heres a picture http://tinypic.com/r/6ptcma/6
heres the what is says on the website :The white 12 way connector plugs into the back of the Ford Quadlock connector in the vehicle harness. This is the big connector with a latch that plugs into the back of the car radio
This is what I had before doing a DVD player ,
And then this is what connections I had on it to use .
Connection on the right is for the Factory harness and the small connection in the middle is what I had as Auxillary, and the round connection is for the antenae
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is offline
Old 07-25-2012, 03:29 PM   #13
Milton
Fan#: 89715
Points 328, Level 6
Points: 328, Level: 6 Points: 328, Level: 6 Points: 328, Level: 6
Level Up 56% Completed
FF Reputation: 10 Milton Great Standing Member
Installing AUX Input AND IPOD Interface
So I have a 2007 Ford Focus 4 door. Stock radio with buttons for satellite radio. I went to http://www.installer.com/ and installed:
* USASPEC PATFORD1
--- DISPLAYS TEXT, ARTIST, PLAYLIST, ALBUM and SONG TITLE INFORMATION
--- Charges your ipod
--- hide the ipod in your glove box, control it from your stock head
--- provides a aux input in addition to the ipod interface
* IS335 Isimple dash panel mount audio input kit
--- Drill a small hole in the stock radio bezel
--- female connector slides into the hole and the attached cable connects to the aux input jack on the PATFORD1
The result is the radio looks completely stock except for the AUX input jack.
Milton is offline
Old 07-25-2012, 04:04 PM   #14
Milton
Fan#: 89715
Points 328, Level 6
Installing an AUX Input - Option 2
This method works with just about any radio, any car:
First create an aux input to your radio:
This is an "IN-LINE" fm transmitter, meaning your radio antenna plugs into it, and then it plugs into your radio. The sound quality is as good as a strong FM radio signal. It does not interfere with your FM reception, it just "adds" a new station. The frequency of the new station has two options. I got mine from www.installer.com
Second, make that Aux input a dash mounted 3.5 MM stereo jack. Use an IS335 Isimple aux input dash panel kit:
The FM Transmitter provides you RCA input jacks. This accessory lets you convert those RCA jacks to a dash mounted 3.5mm stereo jack. Just requires drilling one small hole for the jack. I got this from www.installer.com
At this point you have an aux input, but you want to connect up that IPOD. Just add a Monster Cable Ultra-Low Profile iPod iCharger (AICHG2 IP)
* Add a 12volt cigarette lighter socket that is powered only when your radio is powered.
* Plug this charger into the above socket
* This charger provides a true "Line Out" that you connect to the Isimple Aux Input you installed above.
* What's neat about this charger is not only does it charge the iPod and provide a line out for the aux input, but when you turn off the ignition the radio and the iCharger loses power, the iCharger signals the iPod to go to pause. You go into the store, come back out, start the car and then press the play on the iPod. The iPod picks up right where you left off. I got this from Amazon.
And no, I do not work for www.installer.com, just a very satisfied customer. I have used them for 4 different installs and never been steered wrong.
Milton is offline
Old 07-28-2012, 11:19 AM   #15
Davis4ever
Fan#: 101881
What I Drive: 2005 Sage Green ZX4
Points 25, Level 1
Points: 25, Level: 1 Points: 25, Level: 1 Points: 25, Level: 1
Level Up 49% Completed
FF Reputation: 1 Davis4ever Good Standing Member
Sony
If you want an idea of what is out there for 3rd party steering wheel remotes, put this into a google image search:
sony car steering wheel remote control
Sony has been making these for years, so if you follow the advice above and go for a Sony deck, make sure its compatible with a control unit and pick one up!
Davis4ever is offline
