Old 07-12-2012, 08:09 PM   #41
SaleenT121
SaleenT121's Avatar
Fan#: 57997
What I Drive: 05 Saleen Focus
FF Reputation: 3 SaleenT121 Good Standing Member
The spool time could be up because the GT is a ball bearing turbo vs that journal bearing.
Saleen Focus #74
-Carbon Hood and trunk
-SVT rear Disc brake conversion
-Custom fab turbo kit
-Built 2.0L by Turbo Turtle
SaleenT121 is offline
Old 07-13-2012, 03:40 PM   #42
sporadic
sporadic's Avatar
Fan#: 12724
FF Reputation: 60 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I'm heavily considering mounting my boost controller in the car, in a console I've literally never used.
The distance of hose to it would be somewhere around 4-6 feet. Is this too far? I know my boost gauge line is further than that and it certainly seems instantaneous in its readings.
It would be far more convenient to be able to adjust the knobs in the car.
Thoughts?
sporadic is offline
Old 07-13-2012, 04:58 PM   #43
bringler26
Brokus
bringler26's Avatar
Fan#: 59705
FF Reputation: 26 bringler26 Great Standing Member
This build makes me want a turbo focus.
2003 Ford Focus ZX3(Brokus) - old and busted
bringler26 is offline
Old 07-13-2012, 08:48 PM   #44
sporadic
sporadic's Avatar
Fan#: 12724
Go for it.
I went ahead and mounted the boost controller. I'm still waiting on the silicone hose so nothing is hooked up yet.
While looking for a good place to drill a hole in the firewall for the vacuum line I found a small miracle: a factory-plugged hole right where I wanted one!
It's behind the glove box near where the A/C lines come through. I twisted a screw through to see where it popped out.
See screw in the center of the photo:
I also wrapped the turbo to help the underhood temp. I'll wrap the downpipe later. I hate to because I love the gloss black.
sporadic is offline
Old 07-13-2012, 10:10 PM   #45
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Wow, looks good man. I seen laser heat reading with no blanket, and with blanket on the turbo, and it really helps.
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
ctfocusfans.proboards.com
Djzx3 is offline
Old 07-24-2012, 10:27 PM   #46
sporadic
sporadic's Avatar
Fan#: 12724
Now THIS is more like it! Boost controller is now hooked up. I'm only running the stage 1 of the 2-stage boost controller until I drop in a built motor. Basically I didn't bother wiring up the switch yet that opens the second bleed-off valve.
I installed a 6-port vacuum block even though I only hooked up the boost controller tonight. I wanted to make sure I had enough 4mm silicone hose to route the boost controller before re-routing the BOV and boost gauge. Eventually the BOV, meth injection, boost gauge and boost controller will be routed off the same vac block.
The boost is now set around 9psi (vs. 6-ish psi previously). Just moving the boost source from the compressor housing to the vac block bumped it to ~8psi. A couple clockwise clicks of the boost controller set it to 9psi.
Tomorrow I'll do some datalogging to dial in the AF and timing more carefully. AF looked good tonight but I also didn't really run it hard. I just wanted to check peak boost.
Vac block (bought from Amazon)
Boost controller T. This contains a spring and ball to decrease spool time, but it also causes a momentary 1psi boost spike. So far I consider it a fair tradeoff.
The port behind the glovebox that Ford so kindly put there for me
4mm silicone hose routed to boost controller
sporadic is offline
Old 07-25-2012, 02:53 AM   #47
King Hoonigan
King Hoonigan's Avatar
Fan#: 100769
What I Drive: 2011 Sterling Grey SES
FF Reputation: 1 King Hoonigan Good Standing Member
Well i think Ive just found my new favorite thread. Wish i had the time and money to finally get my kit set up
Fswerks Race exhaust-Fswerks CAI-Eibach Pro's-Eagle Eye Projectors-Fswerks stage 2 turbo coming this summer
King Hoonigan is offline
Old 07-25-2012, 09:57 AM   #48
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
My opinion is you should never hook the WG PSI Ref from the turbo always from the intake manifold ,
9 feels much better doesnt it LOL
Tom
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 07-25-2012, 10:02 AM   #49
sporadic
sporadic's Avatar
Fan#: 12724
Thanks!
Tom
Yes! I can't wait to get out and do some runs and data log later today.
sporadic is offline
Old 07-25-2012, 09:27 PM   #50
sporadic
sporadic's Avatar
Fan#: 12724
I turned the boost up to 10-11psi and tuned it tonight then turned the boost down one click. This type of boost controller doesn't hold rock steady; it slowly floats +/- .5psi at peak boost. I knew that might be the case when I went with the bleed-off type boost controller. It doesn't particularly seem to be a problem. This might be the result of the ball/spring setup in the "T".
MAF counts are peaking out around 900 at 6500 RPM at 10psi. That's 20 counts up vs. the 12psi of the IHI turbo. It's safe to say this flows a higher CFM.
sporadic is offline
