Any interest in headlight modifications? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-11-2012, 03:00 PM   #11
me.awesome
Fan#: 96215
What I Drive: 2012 Candy Blue Titanium hatchback
FF Reputation: 1 me.awesome Good Standing Member
Hopefully you use the standard headlight activation from the car so if I do it I can avoid adding switches to the dash just to turn them on. The bi-xenon part i can understand the switch.
me.awesome is offline
Old 07-11-2012, 03:05 PM   #12
craigsfocus
craigsfocus's Avatar
Fan#: 97985
I do plan on this operating like factory equipment. I really want to make it plug and play. The wiring part is usually the easiest to me.
craigsfocus is offline
Old 07-11-2012, 03:15 PM   #13
MyThIc3LiTe
MyThIc3LiTe's Avatar
Fan#: 95163
Umm...hell yes?
4 grand on Ford's HIDs (front only, backs 1k more for LEDs...) is a BIT steep I think.
MyThIc3LiTe is offline
Old 07-11-2012, 03:50 PM   #14
hand-filer
hand-filer's Avatar
Fan#: 90895
What I Drive: One less Ford
I think there will be a lot of interest in your project Craig. I"ll be monitoring your progress with keen interest.
hand-filer is offline
Old 07-11-2012, 04:05 PM   #15
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,735, Level 76
Points: 13,735, Level: 76 Points: 13,735, Level: 76 Points: 13,735, Level: 76
Level Up 22% Completed
Forum Activity 15%
Buy-Sell-Trade Rating: (18)
DUH! did you really have to ask?
Good Luck!
SkyPilot is offline
Old 07-11-2012, 04:24 PM   #16
JL330
Fan#: 99616
I wish I had a cheap spare set to play with. I'd love to come up with something cool, these cars really deserve better headlights considering the way they look and the fact that it's 2012.
JL330 is offline
Old 07-11-2012, 04:31 PM   #17
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,022, Level 33
Level Up 82% Completed
Forum Activity 12%
I was considering making headlights last week but decided it would probably be a bad idea considering I know next to nothing about this electrical system... or molding plastic... or headlights in general.
PratoN is offline
Old 07-11-2012, 04:32 PM   #18
shane_99ta
Fan#: 97206
What I Drive: 2012 SE Sport Hatchback
FF Reputation: 1 shane_99ta Good Standing Member
Definitely interested.... :)
2012 Focus SE Sport Hatchback (stock)
2002 Trans Am WS6 (not stock) :)
http://www.texas-som.com
shane_99ta is offline
Old 07-11-2012, 05:30 PM   #19
JL330
Fan#: 99616
I was right where you are when I opened up the lenses on my sable. That didn't turn out to be the best decision, but it was my first shot. I want to put projectors in all my cars.
JL330 is offline
Old 07-11-2012, 06:02 PM   #20
Chaddz3
Fan#: 96992
What I Drive: 2012 Ford Focus S Ingot Silver
Points 1,795, Level 24
Points: 1,795, Level: 24 Points: 1,795, Level: 24 Points: 1,795, Level: 24
Level Up 95% Completed
FF Reputation: 17 Chaddz3 Great Standing Member
Figured I would help out here.. Since thats what we do here..
Heres some wiring info on the Headlamps/Park lamps circuits...
If it helps, great.. if not, well its worth what ya paid for it <grin>
All lights are run off the Body Control Module.. each bulb has its own dedicated circuit except the high beams. . The Headlight switch is digital and send commands to the BCM using Pulse Coded Modulation..
Wires of note...
Drivers Side....
Low Beam - Circuit Number CLF04 Brown/Blue Stripe.. Driven off BCM Connector #C2280D POS# 2... FET driven and BCM monitors current on this circuit and has short circuit reset protection...
High Beam - Circuit Number CLF02 Gray/Brown Stripe - BCM Connector #C2280D position #11 (Internally Relay Driven From BCM and Fuse Protected (Fuse F74 in BCM). Passenger side High beam is also driven from this same circuit but has its own wire coming off the BCM. (Purple/Orange Circuit # CLF03 From Connector C2280D position #10)
Passenger Side Low Beam -
Circuit Number - CLF05 (blue/Green) BCM Connector C2280D position #1 Also FET Driven and has current monitoring and short protection..
Since the low beams have current monitoring, you may have to compensate for the current draw of your HID's if they draw more or less current than the factory lights do...
There IS a GOTCHA to watch out for... The pass side low beam uses a Blue/Green Striped wire.. and there is a Blue/Green stripped wire at the drivers side headlight but it is for the left turn signal.. not the low beam headlight... so besure to take note of that...(Most people, myself included would see the common wire colors from side to side and assume its the same circuit.. but this is not the case here..
Other than that, good luck with your project.. I'm interested to see how it goes...
If the BCM for some reason freaks out on your HID's and detects a higher than normal current load (not sure how HIDs work in this regard).. the BCM will shut off the affected circuit(s) until the excess load (or short) is removed and the ignition key is cycled... I know when i did my fog lights I tripped the FET protection on the park light circuit and it took me about 20 minutes to figure out what the hell happened.. I thought i fried my BCM for a bit...
Chaddz3 is offline
