#71 | ||||
That Guy
Rolling won't be necessary at this height. A 1.5" drop with spacers or smaller puffer smaller offset rims probably would. Focusboy would be one to verify that. There is no real 'need' for spacers, but I will take a pic of my car at roughly the same angle as Zillon's and post both here for visual comparison. That will be tonight after work. The wider spacing of the wheels will give it a more confident feel, but the actual weight of the spacers isn't what throws off the handling (when too excessive), it's the overall rotational mass in relation to the fulcrum of the spindle. Arm, I believe? Ok, back to work me
HN Member #161 *155 hp / 143 lb ft (DCT)* Moderator for- DURATEC Ti-VCT Performance (2012-2013) ST Performance (2013) MK3 Focus ST Focus Sonic's MK3 Crew |
#72 | ||||
The Professor
Even with 10mm of spacers on each side, the wheels will looked tucked. Stock not so much, but lowered you will still be tucked.
Here are pics of mine before the drop with spacers (15mm per side rear, and 5mm per side front. My wheels are 17x7 with a +50mm offset). Before drop: ![]() After drop: ![]() Quote:
#73 | ||||
The Professor
No fender rolling needed. Ford has gone away from the enormous fender lips thankfully. They are as "rolled" as you will probably ever get right from the factory.
#74 | ||||
That Guy
Do you have a drivers side 1/4 shot?
#75 | ||||
I'm an A55
#77 | ||||
That Guy
#78 | ||||
Sonic's MK3 Crew #02
Still has the broken endlink which is on order (thank god its only $12) and no alignment
Dyno numbers: 177hp/163tq Mods: Steeda Intake, STS Kit, Rear sway bar, Lowering springs, Steeda RMM, F2 Header, Magnaflow catback, SCT Tune Moderator: Third Generation Ford Focus, DURATEC Ti-VCT GDI Performance Chat & Florida regional section |
#79 | ||||
I'm an A55
Red's pics show me what you guys mean. I'll be keeping an eye on you lowered guys and see how things are looking before I make a decision next spring.
#80 | ||||
That Guy
