Suspension fix - no more front end clunk - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-24-2012, 09:54 PM   #21
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,042, Level 96
Points: 26,042, Level: 96 Points: 26,042, Level: 96 Points: 26,042, Level: 96
Level Up 70% Completed
Forum Activity 58%
Activity: 58% Activity: 58% Activity: 58%
I firmly believe that the clunk in my suspension is related to the top-cap/bearing assembly. Everything else in my front suspension was pristine, short of the gouging that occurred when the techs replaced my left strut.
I'm not horribly worried about it as I listen to my music rather loud (wrong answer, I know), but when I order the parts and make the swap I will be sure to drop intel here and in the clunk thread.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 06-24-2012, 10:20 PM   #22
slowmazda3
Fan#: 58220
What I Drive: a rental
Points 683, Level 13
Points: 683, Level: 13 Points: 683, Level: 13 Points: 683, Level: 13
Level Up 66% Completed
FF Reputation: 0 slowmazda3 Newbie
Originally Posted by BigDandthegirls View Post
Wow! Thats a little rich for my blood. Guess you have to pay to play.
I agree. In the long run... there really isn't that much difference in cost between this replacement and 4 leaking front struts from Ford. There's a reason why they are so cheap.
Any particular reason you didn't go with Koni rears for a Mazdaspeed 3? They will fit.
I've been considering this option for some time now, good to see everything bolts up with minimal modification. Did you cut a hole in the cowl for adjusting the front struts, or do you plan to just set them and forget them?
I am running a 32mm rear bar in addition to stiffer rear springs that are progressive in nature. I wanted more compression damping than the Koni had do offer, and more consistency in damping force throughout the damper range of motion. There is alot of spring equivalent back there with the focus motion ratio and it needs a damper with a lot of compression and rebound force. (B8 >>> Koni in that respect).
No holes were cut. I set the rebound damping to "half" (1.25 out of 2.5 turns) and may bring that down to 1 turn depending on testing and the current alignment. I believe the chassis is still erring on the side of understeer, but without much more spring rate, I dont know how I could possibly reduce this. Keep in mind, this is at the extreme limit when the car is going in WAY hot.
Originally Posted by Dysan911 View Post
Thats awesome that you were able to resolve this issue on your own. Big time kudos for taking this issue head on!. You've done a big service to this community as far as im concerned.
I know you wanted to go aftermarket on the struts, etc. Just curious if you felt the clunk was mainly due to the strut bearings and that someone could fix thiers by changing just that part or was there failure on all the parts you replaced as well?
Thanks!
Thank you. Part of the clunk was strut bearings, part was the broken strut. It was clear that the strut would clunk at the end of its stroke.
See above. Both the strut and the bearing caused the problem IMO.
I bought a mazda and all I got was some crappy motor mounts and wheelspin.
slowmazda3 is offline
Old 06-24-2012, 10:32 PM   #23
Bimmer-Bob
Fan#: 98064
What I Drive: 2010 BMW 128i; 2012 Focus SE Sport
FF Reputation: 3 Bimmer-Bob Good Standing Member
How are you setting damping on the Bilsteins? Aren't the B8's just the Sport shocks, with a fixed damping rate? I thought the only adjustable Billies were the PSS series?
Bimmer-Bob is offline
Old 06-24-2012, 10:57 PM   #24
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
Points 126,755, Level 100
Points: 126,755, Level: 100 Points: 126,755, Level: 100 Points: 126,755, Level: 100
Nicely done... Let's see how it is in 5,000 miles or so... See if those Ford parts stay intact.
Sonic_HedgeHog is offline
Old 06-25-2012, 08:40 AM   #25
Rememo
Rememo's Avatar
Fan#: 95534
What I Drive: Was 2012 Focus. Now 2013 Impreza.
FF Reputation: 3 Rememo Good Standing Member
Yeah... I was kind of surprised to see that you went with the Motorcraft strut bearings, since they don't seem to be holding up very well. 'Course replacing them again would be a piece a cake compared to what you just did.
Rememo is offline
Old 06-25-2012, 09:08 AM   #26
slowmazda3
Fan#: 58220
They are fixed damping. I went with them because the native compression damping is valved "higher" and more digressively than a Koni Sport is capable of.
If there were an aftermarket part that fit, or if the mazdaspeed 3 part fit, I would have bought those instead.
Old 06-25-2012, 09:24 AM   #27
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Level Up 36% Completed
Have you had a chance to compare the OEM MS3 strut bearings and mounts to the OEM MK3 Focus bearings and mounts?
From what I can see in photos, they're identical, but I haven't had a chance to hold both in my hands yet.
Joined the dark side.
Zillon is offline
Old 06-25-2012, 09:38 AM   #28
slowmazda3
Fan#: 58220
ehh... they are the same part. for 3x the cost
Old 06-25-2012, 10:53 AM   #29
raptor1956
Fan#: 97725
Points 4,357, Level 42
Points: 4,357, Level: 42 Points: 4,357, Level: 42 Points: 4,357, Level: 42
Level Up 4% Completed
On the understear issue .. you could try running a bit more negative camber up front. It will tend to increase wear on the inside, but it should improve understear...
Brian
raptor1956 is offline
Old 06-25-2012, 11:12 AM   #30
slowmazda3
Fan#: 58220
Brian
Brian,
I am aware of this; however, camber is relatively fixed with the McStrut design the focus uses. Short of lengthening the control arm there is no possibility of increasing camber on the Mk3 platform (plates will not work as the strut tophat is boxed in.
I also am speaking relative to the OE dampers which leads me to believe I dialed in a bit too much rebound stiffness and in turn reduced weight transfer. The passive rear steer/toe gain on the control blade suspension setup relies on weight transfer for rotation.
The focus is surprisingly agile and gains little camber with steering input when compared to other McStrut designs (A La BMW).
Thank you for your input.
