HOW TO: Install VF-Engineering P/S Mount - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-03-2009, 08:05 PM   #11
HTPerformance
HTPerformance's Avatar
Fan#: 41307
What I Drive: 2002 SVT Focus
FF Reputation: 10 HTPerformance Great Standing Member
Buy-Sell-Trade Rating: (7)
Originally Posted by FocusedSlayer View Post
Scrammer, I've had the C-F-M rear motor mount done in mine for about 2 weeks and it still vibrates like crazy . So I can't imagine putting all the 3 in like you did .
I have narrowed my vibrations down to 2 points 1 is around my steering column somewhere and the other is in my arm rest ...
Originally Posted by liquidst07 View Post
Wow and to think I'd really like to do the "dogbone" mount with urethane bushings.
After hearing about this much NVH after going to more than 1 bushing I'll reconsider. My DD is too important to me and comfort is a big factor...don't think I can handle all that vibration on a daily basis.
Nice how to though!
THE NVH can be mostly cancelled out by properly aligning the motor in the engine bay. Ford has left some adjustment in the mounting plates on the PS and DS.
Try that out. That should significantly reduce any feedback you get to through the Steering wheel.
Another way to significantly reduce the NVH if you are very concerned yet NEED the poly mounts and comfort is to fill the front frame rails with 4 or 8lb density foam. I'll post up a link later, but this has been successfully done on a number of other vehicles and you couldn't tell it was using poly or solid motor mounts. (http://www.shopmaninc.com/foam.html)
If you are in need of mounts hit us up @ www.htperformance.net!
Cheers,
Brian
Last edited by HTPerformance; 03-03-2009 at 11:48 PM. Reason: Added link to Foam Manufacturer.
HTPerformance is offline
Old 04-30-2012, 11:05 PM   #12
djwrg04
djwrg04's Avatar
Fan#: 78546
What I Drive: 2000 Sangria/Torreador Red SE
Points 837, Level 15
Points: 837, Level: 15 Points: 837, Level: 15 Points: 837, Level: 15
Level Up 37% Completed
FF Reputation: 3 djwrg04 Good Standing Member
Question
I guess you can call me the thread necromancer, because I just brought this thread back to life!!
Which foam density would be better if you went and replaced all the mounts with the "Poly" ones?
djwrg04 is online now
Old 04-30-2012, 11:31 PM   #13
DoomsdayFAN
DoomsdayFAN's Avatar
Fan#: 92019
What I Drive: ~2006 ZX4 SE Sedan 2.0L~
FF Reputation: 1 DoomsdayFAN Good Standing Member
I want to get the other two mounts done. I dont mind the current vibrations at all. It makes it feel and sound (from the interior) more like a beast. I imagine with all three that it'll be even more beastly. Especially with cams/header/etc.
DoomsdayFAN is offline
Old 06-21-2012, 06:22 PM   #14
SVTF 03
SVTF 03's Avatar
Fan#: 99859
What I Drive: 2003 Pitch Black SVT EAP ZX3
FF Reputation: 1 SVTF 03 Good Standing Member
Over the weekend I installed the poly bushings into the stock lower trans dogbone. Little vibration....an I mean little. Far better shifting and more solid feel.
Just installed the VF Upper Driver and Passenger side poly mounts today. Wow, tons of vibration. Change rattles in cup holder and ash tray and other things in other places. It's not too bad at speed. But at idle and a little above it's a little much. I read all the reviews and all mostly said to stay with the dogbone only for street use and to only use all 3 mounts for racing, etc. I can attest to this. I'm going to run the mounts for now. I'm hoping they loosen up a little. I'm also going to try re-aligning the mounts to see if that will lessen the vibration. Otherwise, if you are really hardcore about getting all your power to the ground....then run these.
SVTF 03 is offline
Old 06-21-2012, 08:17 PM   #15
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
Points 28,322, Level 98
Points: 28,322, Level: 98 Points: 28,322, Level: 98 Points: 28,322, Level: 98
Level Up 98% Completed
Buy-Sell-Trade Rating: (29)
i had all 3 and ditched the passenger side one for those reasons. car was every bit as good with the dogbone and upper trans, but nowhere near the vibrations of all 3
==2012 Kona Blue Mustang V6==
==1972 Skylark==
Buickboy is offline
Similar Threads
How To: Install Saleen Spoiler mercuryinhell MK1 Focus 1 10-07-2008 11:21 AM
Lower mount install time? FULLBLOWN DURATEC Performance (2003-2007) 7 04-15-2007 03:39 PM
rear motor mount install on SVTF? funksilver04 SVT Performance (2002-2004) 6 11-09-2005 10:58 PM
Yet Another Custom Radar Detector Mount! FocAL MK1 Interior Mods & Upgrades 2 09-06-2005 10:23 PM
VF engineering rear motor mount install drewzx3 ZETEC Performance (2000-2004) 3 07-27-2004 08:20 PM
