2008-2011 suspension kits (Photo's included) - Page 4 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 06-16-2012, 10:43 AM   #31
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
FF Reputation: 8 st12131 Good Standing Member
looks good to me.
Posted via FF Mobile
st12131 is offline
Old 06-17-2012, 10:26 PM   #32
Mumford
Mumford's Avatar
Fan#: 99437
What I Drive: 2009, Sangria Red, SE Coupe
FF Reputation: 3 Mumford Good Standing Member
Originally Posted by yomanwill View Post
For me a good spring and damper set is more appropriate, overall I have been satisfied with the stock ride. After putting it on the lift I noticed that the suspension/brakes needs some TLC: Front sway bar bushings are clicking, front brakes are getting worn down, ride feels a little softer than "new" etc.
Also for the ~$1,000 I would spend I coil overs I can get this instead:
Ford Damper kit
P/N M-18000-ZX3B from
($159.50 + $25 shipping Tousley Ford)
H&R Sport Spring Set
P/N 51662
($206 +16.83 shipping Tire Rack)
Moog front sway bar links
P/N K80066
($17.97 x 2 = 35.94 + 11.75 shipping Rockauto)
Energy Suspension front poly bushings
P/N 9.5158G
($20.90 Amazon)
Energy Suspension rear sway bar grommets
P/N 9.8105G
($13.90 Amazon)
Alignment at local shop (~$75)
Total For suspension upgrade/fix:$564.82
Not related, just needs to be done:
AKEBONO Front Pads
P/N ACT1339
($53.79 + 11.75 shipping Rockauto)
CENTRIC Rotors
P/N 12061093 (120.61093)
($51.79 x2 = 103.58 + 11.75 shipping Rock Auto)
Tires on hold for now, I think I will wait until I'm finish installing above / do more research. Also, I was not able to find 20mm rear bushings w/ zerk fittings for the rear sway bar, only 20.5 mm, but they seem to be in good shape, so I will hold off.
Edit: Updated with prices and P/N's (hopefully it helps others to build / price out their own systems)
ok question that clicking noise does it sound like a heatshield rattle kinda sound as you drive over some bumps? i replaced my sway bar end links and still get a rattle kinda sound lol...also damn you and ur moog for only $17+ lmao if it wasnt for the short notice i pb would have looked more lol
have you been mumfed yet
FF14 2nd place winner non-hatch 00-11 sponsored by focus power
Mumford is offline
Old 06-17-2012, 10:49 PM   #33
focusZX505
FOCUS REVOLUTION
focusZX505's Avatar
Fan#: 19251
What I Drive: 08 Black Coupe
FF Reputation: 4 focusZX505 Good Standing Member
No need for greasable bushings just use the right grease to start and you'll never need to lube again
focusZX505 is offline
Old 06-17-2012, 11:01 PM   #34
Mumford
Mumford's Avatar
Fan#: 99437
synthetic grease? or red and tacky?
Mumford is offline
Old 06-18-2012, 11:39 AM   #35
berndern15
Fan#: 95771
What I Drive: 14 focus st
FF Reputation: 1 berndern15 Good Standing Member
nice but needs to be little lower
berndern15 is offline
Old 06-18-2012, 04:25 PM   #36
yomanwill
Fan#: 61429
FF Reputation: 1 yomanwill Good Standing Member
It is as low as I want to go for Michigan snow / potholes / DD.
I use Mobile 1 SPH-1000 and re-grease with my oil change intervals if applicable (between 10-15k).
It is the sway bar bushings for sure, while on the lift I grabbed on the bar rocked it fore/aft left/right and was able to recreate the noise. The links are probably ok, I had the dealer replace them @ 22k (warranty) because they were clicking, but since I am "in the neighborhood" I thought it would be a good idea.
I am paying for the Moog name I'm sure. In hindsight, I could have picked up master pro at O'reilly's for $25.00 vs $50.00 and still have gotten a quality product.
yomanwill is offline
Old 06-18-2012, 10:15 PM   #37
Mumford
Mumford's Avatar
Fan#: 99437
so how hard would it be to change them out with out a lift and could you do it with out taking the end links off and the tires cuse i got blocks i can just drive up on lol??
Mumford is offline
Old 06-20-2012, 09:06 PM   #38
yomanwill
Fan#: 61429
Well, I made a mistake. If I read correctly the M-18000-ZX3B dampers while spec'ed for 06-07 focus should fit on the 08-11 focus. What I did wrong, was I bought the 08-11 (H&R P/N 51662) springs. In this spring set the front springs go down to a 4" coil on both ends, but the M-18000-ZX3B front struts have pockets spaced for ~6" coils on both ends. To fix this I believe that I should return the H&R P/N 51662 and go with H&R P/N 51666 that is made for the 06-07 focus.
Any thoughts?
Even with this fix, I haven't been able to find any data about how the H&R spring rates compare to the M-5560-ZX3B springs that have been discontinued but I'll find out when I drive it. Ahh, details...
Spring
Seat (strut seat similar)
Old 06-20-2012, 10:01 PM   #39
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
What I Drive: 2011 Blue Flame SES
FF Reputation: 7 indy_11 Good Standing Member
dont use that seat. that is for the 06-07 spring. use the seat that comes with your car which looks like this.
and end up like the one on the right. the one on the left is the one with the 06-07 spring with the top hat in the pic you posted
if you think about it, if you buy 08-11 springs, it should be a direct replacement for your stock springs. everything made for a specific year should be a direct replacement. idk where you got those seats from but send them back. you're good
2011 Blue Flame Focus SES #011
December 2011 ROTM Winner! :)
I always take a poo before driving to reduce weight and increase performance
you tell me your auto is fun to drive, I laugh in your face.
indy_11 is offline
Old 06-20-2012, 10:42 PM   #40
Mumford
Mumford's Avatar
Fan#: 99437
and the springs with that top will stay center and not slide off??
Mumford is offline
