Very frustrated! - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-13-2012, 08:19 PM   #71
spiller
spiller's Avatar
Fan#: 75607
What I Drive: 11 Sangria SE sed, 01 Wht SE Wagon
FF Reputation: 1 spiller Good Standing Member
Originally Posted by Mother Focus View Post
I bet there is still a vac leak, possible cracked intake manifold but that's a guess, tap the throttle with a cutted tire tube fitting the valve over and seal it do 3-4psi and spray soapy water all over the IM, IAC, vacuum hoses, booster, etc. it will bubble right up.
I like this possibility, but I don't understand your testing procedure... Could you explain again?
spiller is offline
Old 06-13-2012, 08:59 PM   #72
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Is adding air through the throttle and checking for leaks like it was a tire, I cutted a tire tube piece with the valve and fitted in place, clamp it to seal it and add 3-4psi, in some cases you will hear the leak but if sprayed with soap and water it will bubble wherever the leak is, IAC may leak a bit through the top but not on the flange.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 06-13-2012, 09:10 PM   #73
cma8302000
cma8302000's Avatar
Fan#: 99700
What I Drive: 2000, silver SE SPORT
FF Reputation: 1 cma8302000 Good Standing Member
Originally Posted by spiller View Post
Fuel pressure on the ZETEC is regulated by the ECU, Fuel Pressure Sensor and the Fuel Pump. (Unlike the SPI which uses an pressure regulator controlled by vaccum.) If the Fuel Sending unit was replaced due to recall, there still could be trash in the line clogging the fuel flow dampener or fouling the sensor. A reduction in fuel flow can occur while pressure is maintained.
Each of these parts are over $100 each. But may be on your inspection list.
this is just so much information to absorb and I don't really understand it...I am hoping the guy/mechanic who has my car is reading all of this.......
cma8302000 is offline
Old 06-23-2012, 09:04 AM   #74
oshoguno
Fan#: 45853
What I Drive: 2012 Focus SE Hatchback
Points 661, Level 13
Points: 661, Level: 13 Points: 661, Level: 13 Points: 661, Level: 13
Level Up 22% Completed
FF Reputation: 1 oshoguno Good Standing Member
Any updates? I wouldn't mind knowing how the new guy did.
oshoguno is offline
Old 06-23-2012, 01:18 PM   #75
cma8302000
cma8302000's Avatar
Fan#: 99700
[QUOTE=oshoguno;4227597]Any updates? I wouldn't mind knowing how the new guy did.[/QUOTE
Well, he tried changing the computer but that wasn't the problem...He was working on it in between working on other cars...not sure if he checked the timing ..he said if it was the timing it would throw a code..anyway, he did change the tps but no change and now the shifting is all messed up but he said the old tps just about crumbled when he took it out...bottom line is , I am going to pick the car up and just park it in my garage until I can figure out what to do with it...he has been very very fair money wise and I will continue to use him for my other vehicles...he actually said he was not gonna let this car defeat him but I decided to let him off the hook...I guess I will just park it in my garage until I can decide what to do with it....
Old 06-23-2012, 01:38 PM   #76
oshoguno
Fan#: 45853
Too bad, I hope you find a way to fix it. Good luck.
oshoguno is offline
Old 06-24-2012, 07:58 PM   #77
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
The pressurized intake idea won't work if any intake valve is open, the intake needs to be off motor and port face sealed.
amc49 is online now
Old 06-24-2012, 08:02 PM   #78
Forum Activity 55%
Actually that's not even true, the cylinder would pressurize up too, unless you just happened to be on overlap. Then it would never seal at all.
amc49 is online now
Old 06-24-2012, 09:56 PM   #79
Mother Focus
Fan#: 73292
It does work, that's how I find vac leaks in mine...of course I'm not the only one...also has to be putting 3-4psi constantly.
PTE 6262CEA
Old 06-24-2012, 10:56 PM   #80
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,548, Level 100
Points: 52,548, Level: 100 Points: 52,548, Level: 100 Points: 52,548, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
[QUOTE=cma8302000;4227823]
Sounds like your guy is a parts changer not a Mechanic , A Mechanic would check with a scan tool and find out what is wrong before randomly changing parts that are not bad with your hard earned money
Find some one with a xcal2-3 and do some datalogging , I will be glad to look them over and I dont charge for this
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
