2012 5-Door tail lamp scratching body - Page 6 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 05-31-2012, 04:54 PM   #51
burn0gas
Fan#: 98574
What I Drive: 2012 Red Candy Ford Focus Titanium
FF Reputation: 1 burn0gas Good Standing Member
Hi Noemi,
I'm trying to send you PM, but for some reason in my private messages sent items I don't see anything. Are you getting it?
Thanks
burn0gas is offline
Old 06-01-2012, 08:14 AM   #52
FordService
FordService's Avatar
Originally Posted by burn0gas View Post
Hi Noemi,
Thanks
Morning burn0gas,
Yup! I received your message yesterday. Since there are a couple of PMs ahead of yours, Iíll respond Monday afternoon.
Have a great weekend!
Noemi
FordService is offline
Old 06-06-2012, 12:19 PM   #53
jerry1
Fan#: 94735
What I Drive: 2012 Focus Ti w/ MT & Alloy Wheels
FF Reputation: 1 jerry1 Good Standing Member
Got mine back yesterday. 5 things I reported:
1. Taillight alignment:
they say - "not much adjustment available. We adjusted what we could. All other focus on our lot have the same issue so it is normal. "
I see - no improvement. I will check this out myself. If my car is going to be a guinee pig, I will be the surgeon.
2. Rear plastic body panel severely miss aligned. Seems fixed.
3. Front end rattle - can't duplicate.
4. Surging in higher gears during light acceleration. - can't duplicate (I will say this is subtle and intermittent so I'm not surprised. )
5. MFT Glitches - can't duplicate (intermittent so I'm not surprised. )
jerry1 is offline
Old 06-06-2012, 12:53 PM   #54
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
FF Reputation: 48 dyn085 Great Standing Member
For the tail lamp, it's easy. Two plastic wing nuts (that can also accept a wide flat-head screwdriver) and you can pull the light away from the body. Disconnect ture harness at the grey plug if you want to get it completely away from the body, if not, that connection is on a small piece of plastic. You can pull thr connection off to give slack in thr harness to flip it over. The stud is near the front and takes a small wrench (10mm? I forget). Loosen it to push the lamp away from the body. Test fit, check for gap, adjust as required.
I had the problem too and just fixed it when I pulled the lamp to test plasti-dip. If you aren't secure with leaving the nut loose, measure the gap you create between the stud and tail lamp and find a washer of similar thickness so that you can install on the stud.
dyn085 is offline
Old 06-06-2012, 06:46 PM   #55
jerry1
Fan#: 94735
Thanks. I don't expect it will be be too difficult but you gave me a good head start.
jerry1 is offline
Old 06-06-2012, 07:03 PM   #56
me.awesome
Fan#: 96215
What I Drive: 2012 Candy Blue Titanium hatchback
FF Reputation: 1 me.awesome Good Standing Member
mine is having the same issue. It hasent chipped the paint but i can clearly see it rubbing and scratching the paint. If i push the taillight back and let it go i can hear it squeek as it rubs the paint.
me.awesome is offline
Old 06-06-2012, 08:28 PM   #57
paul21
Fan#: 87707
What I Drive: 2012 SEL Hatchback
FF Reputation: 0 paul21 Newbie
The service writer looked at me and said there's nothing she can do, that there's no adjustment. I told her there was, but she didn't even look at it at that point.
paul21 is offline
Old 06-06-2012, 08:35 PM   #58
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Ask her if they will re-paint it if you can prove that there is an adjustment. I hate people like that.
I don't expect them to know everything about my car, because then they would have to know everything about every model and trim of the last 3-5 years. But they should be able to at least look.
dyn085 is offline
Old 06-07-2012, 10:46 PM   #59
Mykal
Mykal's Avatar
Fan#: 96521
What I Drive: 2012 Focus HB Tuxedo Black SEL
FF Reputation: 1 Mykal Good Standing Member
Going to the dealer to have the paint chipping issue looked at tomorrow.
Mykal is offline
Old 06-08-2012, 10:03 AM   #60
Mykal
Mykal's Avatar
Fan#: 96521
Dealer took pictures and is contacting Ford. Should know more by Monday. They were concerned which is great is great to hear!
Mykal is offline
