FI Duratec fuel requirements - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-31-2012, 01:23 PM   #1
sporadic
sporadic's Avatar
Fan#: 12724
Points 13,034, Level 74
Points: 13,034, Level: 74 Points: 13,034, Level: 74 Points: 13,034, Level: 74
Level Up 46% Completed
Forum Activity 7%
FF Reputation: 62 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Question FI Duratec fuel requirements
I've asked around, used some calculators, but I can't get a straight answer.
I currently have 55# injectors, stock returnless fuel system and it works perfectly at 220whp (approximate).
At what point should a BAP be added? When should I make the jump to 80# injectors? How about ripping that out for a return style system?
The (max) goal of my next build is 25psi on a D20 with a GT2871R. That should be right around 400whp judging by dynos I have seen.
I've been told the 55# injectors and a BAP will be sufficient for 400whp. I've also seen where CFM is trying to sell a 300whp kit that includes 60# injectors and a BAP. Seems overkill if the previous statement is accurate.
Pardon my rambles. Lots on my mind planning the build.
sporadic is online now
Old 05-31-2012, 03:14 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,570, Level 100
Points: 52,570, Level: 100 Points: 52,570, Level: 100 Points: 52,570, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
I would add the 60lb and watch the fuel psi , if you see it dropping then add the BAP , My opinion is to add the return system about 350HP for safety
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-31-2012, 03:31 PM   #3
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
Tom
What is the main benefits of going return style vs. just bigger injectors like 80lb?
Edit: OK so I have learned that general fuel control is simplified with a return style with less ramp-up in fueling.
At the moment I'm assuming the maximum output of the stock fuel pump is what is the limiting factor when we're talking about moving to a return-style system.
At some point the stock fuel pump just can't flow anymore, regardless of injector size. THAT is when I figure a return style fuel system is required.
Old 05-31-2012, 07:13 PM   #4
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 57%
You are correct , its the fuel pump not the Injectors
Idealy you want 1psi fuel psi fro each psi of boost with base fuel at 41psi , so 10psi boost you would want 51psi fuel , this is hard to do with the tuning software we have to use and the returnless fuel system , so what happens is as you go up in boost the injectors do x amount of dutycycle as the fuel psi falls off the dutycycle goes up to make up for the loss/lack of fuel psi to maintain A/F this is why it is best to always run larger injectors then needed because you burn up a lot of injector dutycycle just from not having enough fuel psi
With a return system you put a Vac line on the fuel psi regulator so every psi of boost adds 1 psi of fuel psi , makes life easier
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-31-2012, 09:30 PM   #5
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 7%
Tom
That does sound simpler to tune for. Know where I could find a list of parts necessary to convert to a return system?
Old 05-31-2012, 09:52 PM   #6
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 57%
Fuel cell , lines , fuel psi regulator , fuel rail
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
