2012 Focus custom CAI, now getting code 2227 MAP sensor - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-19-2012, 07:30 PM   #1
obvthrowaway
Fan#: 99231
What I Drive: 2012 Focus
FF Reputation: 1 obvthrowaway Good Standing Member
Hi all, I recently removed the stock airbox, bought a couple of silicone adapters and a cone filter, and made my own CAI. I am still using the stock MAF and rubber accordian tube piece from the throttle body to the MAF, the MAF is in the stock location and hasn't been rotated (you can't, it's keyed to the rubber elbow that connects to the throttle body). It sounds awesome, almost like a boxer motor. Not really noticeable until you get into it, but at WOT it's great. Haven't gotten any data on MPG increase and the butt dyno says it pulls harder but everyone knows how accurate those are.
Anyway, the problem is I've been getting a check engine light with the code P2227 MAP sensor voltage. I clear the code and it comes back sometimes, sometimes it goes away. The car seems to run fine. I've taken off the MAF and cleaned it with MAF sensor spray and it didn't seem to help. Any suggestions? I will probably put back the stock airbox and see if the code goes away, I'm sure it will. Just don't understand why it would pop up in the first place.
Thanks,
Anonymous 2012 Focus Driver
obvthrowaway is offline
Old 05-20-2012, 10:34 AM   #2
thenookie
thenookie's Avatar
Fan#: 89346
What I Drive: 02 Zx3
FF Reputation: 1 thenookie Good Standing Member
did you pop off the neg battery cable when you installed it to let the ecu relearn?
thenookie is offline
Old 05-20-2012, 12:15 PM   #3
Mucrammada
Mucrammada's Avatar
Fan#: 91537
What I Drive: 2013 Limited WRX Hatch, 2011 CTS
FF Reputation: 1 Mucrammada Good Standing Member
popping off that negative battery cable sucks, I can't even see it. They placed that battery in a terrible spot..
I can haz cheezburger?
Official Mayo Hater #5
Mucrammada is offline
Old 05-20-2012, 05:47 PM   #4
thenookie
thenookie's Avatar
Fan#: 89346
ya it does but got to do sometimes
Old 05-20-2012, 06:52 PM   #5
Mucrammada
Mucrammada's Avatar
Fan#: 91537
can you just pop off the positive cable instead? or is that bad for it?
Old 05-21-2012, 10:30 AM   #6
obvthrowaway
Fan#: 99231
I did remove the positive cable from the battery when doing the original install. I have also since added an amp + sub so I had to remove the positive cable to do that. So I would bet it has been reset at least twice.
I wonder if it is the size of the filter. I used a cheap parts store filter that is actually smaller than the stock paper filter, maybe it is restricting flow so much it's causing a code? I might just remove the filter altogether and take it for a spin.
I also think it could be a resonance or mounting issue. The stock setup is pretty well damped and solidly mounted, while mine only has a single strap of aluminum stock holding it in place. Maybe the MAF needs to be very solidly mounted and isolated from vibration?
Old 05-21-2012, 11:55 AM   #7
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,199, Level 96
Points: 26,199, Level: 96 Points: 26,199, Level: 96 Points: 26,199, Level: 96
Level Up 85% Completed
Forum Activity 54%
To pull the negative cable, you actually disconnect it from the car. The ground is located just behind the fuse box and has the post for jumper cables.
dyn085 is offline
Old 05-22-2012, 07:56 PM   #8
thenookie
thenookie's Avatar
Fan#: 89346
just pop off the neg battery cable for 15 min. it will reset the car and code. if the code pops again have it checked out.
Old 09-09-2013, 07:16 AM   #9
ReLeaseTheFocus12
Fan#: 107310
What I Drive: 2015 WR Blue WRX
Points 10, Level 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Level Up 19% Completed
FF Reputation: 1 ReLeaseTheFocus12 Good Standing Member
I currently have the same problem. I have the K&N Short Ram intake installed and recently got that code. The car seems to be getting "drowned" in air. I reset the code and the battery and haven't seen the code again but the car still isn't running completely right. I'm not sure what else I can do, I'm hoping to give it a couple of days/drives to re-evaluate the air/fuel mixture. Here's to hoping.
ReLeaseTheFocus12 is offline
Old 02-23-2015, 12:13 PM   #10
805SLOFocus
Fan#: 216322
What I Drive: 14 Sterling HB Ti
Points 10, Level 1
FF Reputation: 1 805SLOFocus Good Standing Member
@release did the battery reset fix this once and for all? Newmission mod with a green filter has got me this code with only 600 miles on the car.
805SLOFocus is online now
