#1 | ||||
GO Green
2012 Recalls and TSBs
Figured Id make this thread as it will be useful for potential buyers and owners, now and in the future. Also because I want to know what tsbs are out there right now so that when my parents get their focus it can have those addressed before it leaves the driveway. Would be nice if this got stickied too. So post up known Tsb's and recallls. All I got now is the TSB for MFT that just came out. And the steering one.
2012 Ford Focus Steering Service Bulletin 107553 NHTSA: ![]() ![]() Action Number: 10039118![]() ![]() Service Bulletin Number: 107553Report Date: May 04, 2011Component: Steering ![]() Summary: Ford: there may be steering assist warning lights as well as well as a stored trouble code. 2012 focus. *rm Posted via FF Mobile |
Remove Advertisements |
#3 | ||||
Some 2012 Focus vehicles equipped with electric power assisted steering (EPAS) and built on or before 04/19/2011 may exhibit a lack of power steering assist on vehicle start up and may exhibit a diagnostic trouble code (DTC) C102D. The customer will see Steering Assist Fault Service required message, the steering wheel icon, and a yellow dot in the instrument cluster, and hear the soft warning chime. Steering assist will remain for that key cycle. For the next key cycle at vehicle startup, the customer will see Steering Loss Stop Safely message, the steering wheel icon, and a red dot in the instrument cluster, and hear the hard warning chime. Steering assist will be removed for that key cycle and all future key cycles.
ACTION: Reprogram the power steering control module (PSCM) to the latest calibration using IDS release 72.04 and higher or 73.01 and higher. This new calibration is not included in the VCM 2011.5 DVD. Calibration files may also be obtained at www.motorcraft.com. NOTE: DIFFERENT MODULES MAY GENERATE DTC'S DURING REPROGRAMMING OF THE PSCM. FOLLOW IDS INSTRUCTIONS TO CLEAR DTC'S FROM ALL MODULES. |
#4 | ||||
Technical Service Bulletins
11-8-11 FRONT DOOR TO REAR DOOR CONTACT AT THE TOP WEATHERSTRIP 11-8-1 VISIBLE DEPRESSION IN HOOD SURFACE 11-7-29 VARIOUS FUNCTIONALITY CONCERNS WITH MYFORD TOUCH - BUILT ON OR BEFORE 7/25/2011 11-7-22 RPM FLARE OR ROUGH IDLE ON DECELERATION - BUILT ON OR BEFORE 6/28/2011 11-7-13 BATTERY LIGHT ON - DTCS MAY ALSO BE PRESENT U012D, U0140, B11DB, U0422, P2610, P06B8 OR U0257 11-6-23 DIAGNOSTIC TROUBLE CODES (DTC) P0010, P0012, P0013, P0014, P052A OR P054B - VARIABLE CAMSHAFT TIMING (VCT) OIL CONTROL SOLENOID 11-5-11 DTCS P068A, P2610, U0422 AND P00D2 - BUILT ON OR BEFORE 5/3/2011 11-5-1 LACK OF POWER STEERING ASSIST ON VEHICLE START UP - DTC C102D - BUILT ON OR BEFORE 4/19/2011 |
#5 | ||||
Thanks guys. I was hoping this was the one for the steering "wander" at highway speeds that has been posted at length on this forum. Mine isn't doing it but we have a customer that has complained about it. Bringing up the concern in the system does not show a TSB.
#6 | ||||
This thread deserves a sticky and maybe a moderator can add a post up top that can be updated with all the TSBs so we dont have to search through the thread?
2012 SGM SEL Sedan 303a w/o Nav Job 1 built 6/2011 |
#7 | ||||
#8 | ||||
FORD: 2012 Focus
This article supersedes TSB 12-1-2 to update the production fix date and Part List. ISSUE: Some 2012 Focus vehicles built on or before 12/12/2011 may exhibit a steering wander at highway speeds over 72 Km/h (45 MPH). Customers may indicate they have to frequently adjust the steering wheel slightly to maintain the direction of travel. ACTION: Follow the Service Procedure steps to correct the condition. Saw it a little late but it out there SERVICE PROCEDURE Replace the Steering Gear. Refer to Workshop Manual, Section 211-00. NOTE: FOLLOW THE RECOMMENDED TORQUE SEQUENCE AND TORQUE SPECIFICATION. IMPROPER TORQUE SEQUENCE MAY RESULT IN THE STEERING CONCERN REOCCURRING. Last edited by Imaruningbulseye; 05-16-2012 at 10:38 AM. Reason: adding info |
#9 | ||||
Found this:
http://www.ford-trucks.com/tsb/tsb.p...y-2012/d-FOCUS And this: http://www.automd.com/tsb/ford_m/ |
#10 | ||||
http://www.focusfanatics.com/forum/showthread.php?t=221339 <--- any bulletins for this problem ???
