2012 5-Door tail lamp scratching body - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-10-2012, 03:06 PM   #1
silenthill
Fan#: 85671
Points 2,483, Level 30
Points: 2,483, Level: 30 Points: 2,483, Level: 30 Points: 2,483, Level: 30
Level Up 22% Completed
I've been having a strange recurring problem with my hatchback. On only the right side of the rear turn signal cluster, the fixture has been rubbing paint off and squeaking. Here's the original damage from the original cluster:
IMG_4102 by silenthill2011, on Flickr
The Ford dealer did replace this cluster, but it's chipping again. It's not visible in this picture because the cluster is pressed tightly against the body (which is causing the chipping):
IMG_4367 by silenthill2011, on Flickr
Has anyone else seen this problem? I don't have a problem with the lefthand cluster--there's plenty of clearance between the plastic housing and the fender. There's not on the right, and the dealer says there's no adjustment. They're looking into options, but I thought I'd see if anyone else has seen this.
silenthill is offline
Old 05-11-2012, 11:48 AM   #2
FordService
FordService's Avatar
Points 3,495, Level 36
Points: 3,495, Level: 36 Points: 3,495, Level: 36 Points: 3,495, Level: 36
Level Up 97% Completed
Forum Activity 28%
Originally Posted by silenthill View Post
I've been having a strange recurring problem with my hatchback. On only the right side of the rear turn signal cluster, the fixture has been rubbing paint off and squeaking...
Silenthill,
Iím glad the dealer is working to have this fixed. We can add another layer of assistance by contacting the Customer Service Manager for your area. To do so, please send a PM with your contact information, dealer name/state, approximate mileage, and VIN.
Take care!
Noemi
FordService is offline
Old 05-11-2012, 12:18 PM   #3
MKorn
MKorn's Avatar
Fan#: 97610
What I Drive: 2012, SE, Sport, 5MT, Hatch -Silver
FF Reputation: 1 MKorn Good Standing Member
Can the tail light assembly be removed and then sand some of the plastic off to allow a better fit?
i am going to check mine when i get home ...
MKorn is offline
Old 05-11-2012, 07:04 PM   #4
journeyforce
Fan#: 82098
What I Drive: 2005 Silver ZX4
FF Reputation: 1 journeyforce Good Standing Member
What about adding a small foam pad to the affected area or at each of the corners so as to keep it from being so tight and rubbing?
journeyforce is offline
Old 05-12-2012, 07:41 PM   #5
Ocysp
Ocysp's Avatar
Fan#: 87283
What I Drive: TuxBlk '13 ST3 & '12 SE HB
FF Reputation: 1 Ocysp Good Standing Member
That's amazing. I have the same exact problem:
Ocysp is offline
Old 05-13-2012, 06:42 AM   #6
Dick W
Fan#: 91695
What I Drive: 2012 5dr SGM Ti/09 135i/07 CR-V
FF Reputation: 2 Dick W Good Standing Member
Hmmm.
Ours was loose right there--it would wobble maybe 1/32 or 1/16" when pressed. (L Side was rock solid.) I had the tighten it. Maybe that was a mistake?
Dick W is offline
Old 05-13-2012, 10:09 AM   #7
silenthill
Fan#: 85671
Well, it's somewhat reassuring to know that it's not just me. I've got an appointment tomorrow with the dealer and they're going to see what they can do about this (since they already replaced the tail lamp once). They might be consulting with the body shop.
I did send Noemi a message on here as she requested, maybe you should too?
Old 05-13-2012, 01:14 PM   #8
mcdiv
Fan#: 94558
What I Drive: 2012 titanium, kona blue
FF Reputation: 1 mcdiv Good Standing Member
Went and checked mine, and while it's not as bad as the ones posted it's still a noticeable chip. Another thing to bring up next time I'm in for work.
It'll be fun to see all the 5 door focuses five years from now with the patch of rust by the passenger side tail light.
mcdiv is offline
Old 05-13-2012, 09:00 PM   #9
pozi240
Fan#: 94835
Went out and checked mine....same thing! The left side is fine and has a small gap, the right side is very tight against the body and rubs the paint. I wonder if it has to with the gas filler door?
pozi240 is offline
Old 05-13-2012, 09:57 PM   #10
silenthill
Fan#: 85671
I'll report back what I hear from the dealer tomorrow. I've had great service experiences with them so far.
Noemi, when you start to seeing a trending issue on the forums, do you get to report things directly to the product groups? I've always been curious if links to threads on Focus Fanatics ever make it back to the Focus team.
