Go Back   Focus Fanatics > Ford Focus Tech Discussions > ECU Tuning Chat
ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
Old 05-05-2012, 04:18 PM   #1
sporadic
sporadic's Avatar
Fan#: 12724
FF Reputation: 60 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Question Adjusting tune for aftermarket Duratec IM
I'll be installing a cossie knock-off manifold sometime this spring/summer and would like to know some things to anticipate changing in PRP.
I know I'll be changing the IMRC flag to 0 since that will be gone. What idle-related values should I expect to tweak? I plan on keeping the IAC to prevent stalling and A/C use.
I suppose this question is directed at Tom as he is already familiar with my car, but could also be valuable to others if they come across the thread.
Car is 2.0 Duratec turbo. Stock motor plus a little 11psi turbo. 55# injectors.
Thanks
sporadic is offline
Old 05-29-2012, 08:51 AM   #2
sporadic
sporadic's Avatar
Fan#: 12724
Bump. Looking to do this fairly soon, but the turbo will be a GT2871 instead of the IHI I have now.
sporadic is offline
Old 05-29-2012, 09:56 AM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
If you paid for your tuning through me just because you now have the PRP doesnt mean I would keep helping you , Just shoot me an log and I will help
Tom
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-29-2012, 10:40 AM   #4
sporadic
sporadic's Avatar
Fan#: 12724
Tom
Thanks Tom. I will take a stab at it myself first and then bug you if I get hung up. I was just curious about any obvious issues you knew off the top of your head that I'll need to work around.
sporadic is offline
Old 05-29-2012, 11:29 AM   #5
1turbofocus
FF Affiliate
Fan#: 1123
It should go smooth , just dont do anything crazy just adjust the basics , DO NOT try anything like changing the intake size , keep it simple , fuel , timing , idle and then turn off any CEL
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-29-2012, 11:30 AM   #6
sporadic
sporadic's Avatar
Fan#: 12724
Excellent, thank you.
sporadic is offline
Old 09-21-2012, 09:45 PM   #7
sporadic
sporadic's Avatar
Fan#: 12724
My Cossie knock-off IM is installed and 90% tuned after MUCH frustration due to one little flag.
Do NOT set the IMRC switch to "0". It will cause endless fueling problems!!
This is what I changed (or not) in my tune to compensate for installing a new intake manifold with no flaps. You may be able to get away with leaving the spark tables alone, but personally I like to know exactly where the total spark value is coming from without guessing whether or not the PCM is actually adjusting for IMRC.
1) leave the System Switches\Scalar\IMRC Switch at "1"
2) Add the IMRC\Spark Adder to Borderline for IMRCs values to the Spark\Borderline Knock\Borderline Knock Table
3) Zero-out the IMRC\Spark Adder to Borderline for IMRCs values
4) Add the IMRC\Spark Adder to MBT Table for IMRCs values to Spark\MBT Spark\MBT Spark Table
5) Zero-out the IMRC\Spark Adder to MBT Table for IMRCs values
6) leave IMRC\IMRC Opening RPM as-is. This seems to no longer have an effect, as the "imrc open" flag is always "1" now in the logs, even at idle.
There are some tables under "Transient Fuel" which I did not touch.
I will update this thread if I feel there is anything else to add.
In closing, I will say that I DO NOT KNOW exactly why the PCM 1) negates the load calculation at the IMRC Open RPM position and 2) pulls fuel like crazy by setting the IMRC Switch to "0". Until I hear an explanation I am going to assume it is a bug in the SCT software.
sporadic is offline
Old 09-23-2012, 09:43 AM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Set all your MBT tables to 60 vs 0
That is strange , I just looked at all the duratecs I have done and have set the IMRC switch to 0 with no issues
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
