Finally dynoing the Focus 5/2/12 - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-04-2012, 04:51 PM   #101
_RED_
Sonic's MK3 Crew #02
_RED_'s Avatar
Fan#: 10712
What I Drive: 2014 Fiesta ST
Points 41,372, Level 100
Points: 41,372, Level: 100 Points: 41,372, Level: 100 Points: 41,372, Level: 100
FF Reputation: 2 _RED_ Good Standing Member
Its normal for almost every stock vehicle
'14 Fiesta ST
234 HP / 274 TQ
SCT Tune & Injen Intake, Borla Catback
Moderator: Third Generation Ford Focus, DURATEC Ti-VCT GDI Performance Chat & Florida regional section
_RED_ is offline
Old 05-04-2012, 05:10 PM   #102
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
Points 4,360, Level 42
Points: 4,360, Level: 42 Points: 4,360, Level: 42 Points: 4,360, Level: 42
Level Up 5% Completed
Originally Posted by Ox-y-GenIII View Post
I don't think an intake or exhaust void Fords warranty so I'm not worrying about it.
It will if it was the cause of the failure, but they would have to prove that, so yeah it should be fine. and tuning will be available eventually and solve the problem.
Normal driving probably wont be a problem, but lean means more heat for the engine.
darkangelism is online now
Old 05-04-2012, 05:25 PM   #103
darkangelism
Sonic Crew #04
Fan#: 85425
Would running 91/93 octane help because that should allow a leaner a/f without causing problems
Old 05-04-2012, 05:37 PM   #104
Kabigon
Fan#: 88299
Points 4,575, Level 43
Points: 4,575, Level: 43 Points: 4,575, Level: 43 Points: 4,575, Level: 43
Level Up 13% Completed
Forum Activity 13%
Originally Posted by 1turbofocus View Post
It isnt the time delay to WOT fuel (openloop) that is causing that , it is actually set that lean in the tuning from ford and in my opinion it is WORNG but I know why there doing it and for a grocery getter its fine , intake causes a leaner condition
All that would have to be done with an intake is see the engine is lean stock and slightly larger maf hole to richen it up , this would keep the engine safe , make more power...
Yes I have had about 10 2012 on my dyno they were all lean
Tom
The front o2 is not used for WOT fueling
Tom
WTH?
1) Why would the front O2 not be used during WOT? I have never seen my car go open loop @ WOT.
2) I am getting a steady 12.4~12.5 (commanded and actual) AFR @ WOT.
Could this be attributed to PCM calibration differences or...?
Kabigon is online now
Old 05-04-2012, 05:40 PM   #105
_RED_
_RED_'s Avatar
Fan#: 10712
What are you using to log?
'14 Fiesta ST
234 HP / 274 TQ
_RED_ is offline
Old 05-04-2012, 06:03 PM   #106
gtp2focus
gtp2focus's Avatar
Fan#: 63959
What I Drive: 2012 Oxford White SE Sport
FF Reputation: 2 gtp2focus Good Standing Member
That would only happen if you were experiencing KR. If you arent then higher octane wont effect anything. It definatly wouldnt hurt though.
gtp2focus is offline
Old 05-04-2012, 06:03 PM   #107
Kabigon
Fan#: 88299
Forum Activity 13%
For direct monitoring, I have my own "black box" (similar in function to a DashHawk) that I developed a few years ago. It now has most of the 2012 Focus specific (mode 22) PID's.
For data logging, I use a PC with a Drewtech Mongoose (J2534) CAN interface and custom software.
I also have an IDS (which can do datalogging) as a reference.
Here is an example of a datalog (showing operation of the grill shutters) that I previously posted:
FWIW, I will post a WOT datalog tonight.
Old 05-04-2012, 07:20 PM   #108
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
What I Drive: 2012 Sonic Blue SE Sport 5 Spd
Points 19,028, Level 87
Points: 19,028, Level: 87 Points: 19,028, Level: 87 Points: 19,028, Level: 87
Level Up 36% Completed
Forum Activity 30%
FF Reputation: 43 Duffman355 Great Standing Member
so is my steeda intake going to destroy my engine?
ST Crew #11 / SSR #5
Official Mayo Hater #1
Randomie's Lover #8
Duffman355 is offline
Old 05-04-2012, 07:34 PM   #109
JSR84
JSR84's Avatar
Fan#: 87788
What I Drive: 2008 MazdaSpeed 3
FF Reputation: 1 JSR84 Good Standing Member
CSV format please.
2008 Victory Red MazdaSpeed 3 - Not stock and self tuned.
2012 Sterling Gray Focus Ti - K&N.
Smashing Internet ignorance one person at a time.
JSR84 is offline
Old 05-04-2012, 08:06 PM   #110
darkangelism
Sonic Crew #04
Fan#: 85425
while i am not as much of an expert as the others, under normal driving conditions, it is doubtful you will damage your engine. Running lean means that the engine runs hotter, which could lead to detonation of the fuel, causing you to blow or melt the engine, but you have to be pushing the engine to where it is running hot enough for that to happen, which would be hard driving conditions and not daily driving.
If the cars are running lean from the factory, we are losing HP because less fuel is being delivered and tuning would help this.
