NO indicator for winshield wiper fluid - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-03-2012, 09:33 PM   #41
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
TSB
12-4-13 LOW WASHER SOLVENT WARNING MESSAGE MAY NOT DISPLAY ON VEHICLES BUILT ON OR BEFORE 1/14/2012
Publication Date: April 30, 2012
FORD: 2012 Focus
ISSUE:
Some 2012 Focus vehicles built on or before 1/14/2012 may not display the low washer solvent message as detailed in the Owner's Guide.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Using the Ford Integrated Diagnostic System (IDS) start a new IDS session.
ID the vehicle; select the tool box at the vehicle screen.
Select module programing.
Select programmable parameter.
Select car configuration parameters.
Select vehicle configuration.
Retrieve professional technician society (PTS) delivered as-built data.
Follow the on-screen prompts.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
120413A 2012 Focus: Follow Service Procedure To Repair Concern (Do Not Use With Any Other Labor Operations) 0.3 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
14A068 04
Rat Fink is offline
Old 05-03-2012, 09:43 PM   #42
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
Thank you, Rat Fink!
BetaDnB is online now
Old 05-04-2012, 12:08 AM   #43
Kabigon
Fan#: 88299
Points 4,575, Level 43
Points: 4,575, Level: 43 Points: 4,575, Level: 43 Points: 4,575, Level: 43
Level Up 13% Completed
Forum Activity 13%
Originally Posted by BetaDnB View Post
Thank you...
You're welcome.
I'm more than happy to bring this TSB to your attention and provide you with the pertinent information.
Kabigon is offline
Old 05-04-2012, 08:52 AM   #44
MKorn
MKorn's Avatar
Fan#: 97610
What I Drive: 2012, SE, Sport, 5MT, Hatch -Silver
FF Reputation: 1 MKorn Good Standing Member
is this trim level specific?
i do not see the light on the dash at start up. 12-14-11 build.
MKorn is offline
Old 05-04-2012, 08:58 AM   #45
VelociRacer
VelociRacer's Avatar
Fan#: 97968
What I Drive: 12 BlueC SE Sport 5DR+5SP+201A+Wntr
FF Reputation: 1 VelociRacer Good Standing Member
Those who do this TSB, please take your LCD info screen into TEST mode and take a picture of your LED test. I am not seeing an LED warning icon for washer fluid. Which one is it? Maybe it should be at the 0 speedo position?
VelociRacer is offline
Old 05-04-2012, 09:05 AM   #46
MKorn
MKorn's Avatar
Fan#: 97610
+1 for me also
MKorn is offline
Old 05-04-2012, 09:10 AM   #47
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 7%
Somebody who has a working indicator said it shows on the info screen. There is not a dummy light.
Old 05-04-2012, 09:17 AM   #48
MKorn
MKorn's Avatar
Fan#: 97610
Aaaaah, that explains it!!
MKorn is offline
Old 05-04-2012, 11:10 AM   #49
raptor1956
Fan#: 97725
Points 4,363, Level 42
Points: 4,363, Level: 42 Points: 4,363, Level: 42 Points: 4,363, Level: 42
Level Up 7% Completed
There is no mechanism to detect a low coolant level directly (i.e. it could only be detected by a high coolant temperature).
It would be nice to have a coolant level alarm but I'd guess the engine coolant system is a bunch tougher to sensorize than washer fluid. First, it's hot. Then you have the water pump causing the fluid to be quite turbulent. Finally, it's pressurized so whatever sensor would need to be fully enclosed.
Should still be doable, but certainly not as easy as washer fluid.
A similar thing with motor and transmission oil levels.
Brian
raptor1956 is online now
Old 05-04-2012, 11:29 AM   #50
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Brian
Putting a sensor in the coolant overflow bottle would reduce those issues. As you mention, oil is also hot and pressurized, and most vehicles have oil level sensors.
Hatch Nation #90
TboneZX3 is offline
