02 ZX3 Dies after about 5 miles wont start for 10 min - Page 2 - Focus Fanatics
Old 04-14-2012, 10:36 PM   #11
I would clean an MAF that didn't through a complete fail code before I replaced it. Spray cleaner works great.
Old 04-14-2012, 10:43 PM   #12
shawnr
Fan#: 97721
What I Drive: 2006 Silver ZX-4 SES
FF Reputation: 1 shawnr Good Standing Member
Smile
I would too, and I did, but it didn't, so I did....replace it. lol
shawnr is offline
Old 04-15-2012, 02:21 PM   #13
evileyezzz
Fan#: 97658
What I Drive: 2003 Pitch Black ZX5
FF Reputation: 1 evileyezzz Good Standing Member
Ok, I have spark but not fuel. Also a 0302 code. I replaced the speed sensor when it first started and the crankshaft sensor about 3 months ago.
evileyezzz is offline
Old 04-15-2012, 04:02 PM   #14
302= misfire cylinder #2. Clear that code to see what comes up again. It might not be indicative of a problem in that cylinder if fuel is being cut to all cylinders that's just the first one that doesn't fire.
Try bypassing the fuel cutoff switch since you don't have fuel. Make sure your bypass is good- I'd use solid copper insulated wire that you can be sure is making the connection between the pins on the plug. I honestly haven't heard of this part going bad in many years, but it's cheap to check it. Make sure whatever you use there- if you use something like a paperclip- that you use electrical tape to hold it in place and prevent it from shorting. If that's the problem, then you'll know in 6 mins- right?
Old 04-15-2012, 04:43 PM   #15
evileyezzz
Fan#: 97658
Sorry, code was 320 not 302 typo. I just swapped my MAF sensors and it did not fix it either.
Old 04-15-2012, 04:51 PM   #16
Originally Posted by From Ford Focus Technical Chat Stickied Threads: DTC Codes and Meanings
P0320 - Ignition Engine Speed Input Circuit Malfunction The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred. Loose wires/connectors.
-Arcing secondary ignition components (coil, wires and plugs)
-On board transmitter (2-way radio)
-The DTC indicates that two successive erratic PIP pulses occurred.
Did you ever check the coil plug-in connector? Pull on the wires going to it and see if any were loose? This is not the spark plug wires, but the power plug to the coil. Sometimes those wires loosen inside the plug connector. It will look like the wire is going in there, but it won't be making a connection inside, and if you pull on the wire it will pull out.
Old 04-15-2012, 04:51 PM   #17
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
What I Drive: 97 Impreza coupe, 04 Mazda6
FF Reputation: 13 TheGlassMaker Great Standing Member
I would make sure where ever you go is less than 5 miles away and your going to be there longer than 10 mins.
On a side note, not with this car but with my old honda. I had similar issues but it was the distributor.
Do one thing every day that scares you. -Eleanor Roosevelt
TheGlassMaker is offline
Old 04-15-2012, 05:08 PM   #18
evileyezzz
Fan#: 97658
OK I think I may have finally figured it out! I looked up 320 code and one possibility was crank position sensor. I drove the car until it died and it wouldnt start again as usual. I checked the crank position sensor and realized there is no longer a retaining clip, I wiggled the clip and it started right up! Looks like I need to find a retaining clip. Thanks everyone for your help and ideas!
Old 04-15-2012, 06:35 PM   #19
LOL..... yeah, I would've gone there if you'd checked out the coil, but I didn't want you to be like some people who replace stuff without checking. I totally forgot about the clip. I have heard that on here before. Next time- right?
I'd rig something up for temporary- zip tie, tie wire- whatever, then go search salvage yards. Best of luck!
Old 04-15-2012, 08:16 PM   #20
"Elder"
FF Reputation: 67 sailor Excellent Standing Member
GREAT! You found it!
More often than not, it's something "stupid"(In this case a loose connector).
Glad you found the "cheap fix" B4 throwing bucks into things that weren't broken...
Roger
sailor is offline
