Solution to cooling fan resister failure??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-10-2012, 09:47 AM   #1
winterbeater
Fan#: 93035
What I Drive: 2001 blue wagon
FF Reputation: 3 winterbeater Good Standing Member
Getting warmer here in Michigan. The old Focus I bought over the winter is starting to overheat. All good when moving (runs at 94C), but idling at a stop, it gets up to about 114C before the fan kicks on. I've read a lot of threads here (thanks for the help all) and I'm confident that the problem is the famed resister. Some of the threads have been asking for cheap work-arounds, etc., as the resister costs about $50.
Why not just solder a jumper wire into the burned out resister to bypass the burned out element? Or even cutting off the plug (drastic) and connecting the two wires together. A lot of vehicles don't have two speed cooling fans. Either on or off. The fan will be noisier on high and kick on and off more often, but to me that is not a problem.
Has anyone tried this?
winterbeater is offline
Old 04-10-2012, 10:55 AM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,393, Level 61
Points: 8,393, Level: 61 Points: 8,393, Level: 61 Points: 8,393, Level: 61
Level Up 81% Completed
Forum Activity 30%
Not sure if any one has tried it, but thoughts...
With them on High all the time you may have higher current spikes and possibly blowing fuses if your always jumping from static off to full speed...
The life of the fans may drop or fail sooner as they are working at a higher duty cycle for a longer period of time
longer warm up time = longer time of the motor running on a non "optimal" fuel chart
what vehicles are you referring to when "lot of vehicles don't have two speed cooling fans."? Those that don't that I know of have a mechanical clutch fan which is the "low speed" fan....
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 04-10-2012, 01:13 PM   #3
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Points 4,699, Level 43
Level Up 75% Completed
The engine would still maintain operating temperature in the lower range but.....
The fuse may be your number one problem (30A), followed by melting your wire harness 'somewhere' if you try replacing a 30A fuse with a 50A fuse.
Wouldn't recommend it.
Would recommend fixing the original problem correctly.
60k+ miles.
a_2000_se is offline
Old 04-10-2012, 04:06 PM   #4
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Forum Activity 7%
Look at the supplied schematic, the system is already able to take the power, just more noise and fan wears out faster. Possible idle quality issues with bigger current spike from standing start off.
Simply wire direct to miss the resistor will do it.
amc49 is offline
Old 04-10-2012, 04:10 PM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
^^^ that assumes that the wire gauge through the low speed relay is the same gauge as that through the high speed relay. what I would do instead is wire it in a "OR" configuration so the low speed relay is actually just turning on the high speed fan relay. that would be the correct way to bypass the low speed.
Hatch Nation #42
Old 04-10-2012, 06:37 PM   #6
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,063, Level 34
Points: 3,063, Level: 34 Points: 3,063, Level: 34 Points: 3,063, Level: 34
Level Up 9% Completed
If you're worried about using a 50amp fuse, replace the 30 amp fuse with a 30 amp circuit breaker..........
Ed
emsvitil is offline
Old 04-10-2012, 06:39 PM   #7
emsvitil
Fan#: 50210
Also, the resistor is usually fine; it's the spade connectors that get burnt up from the POS connector. Just dremel them clean.
Ed
emsvitil is offline
Old 04-10-2012, 09:00 PM   #8
winterbeater
Fan#: 93035
Thanks for all the feedback. I researched a little more and agree that most of the OEM fans are two speed.
Wire gage in the current low speed circuit would be important. I didn't realize that low speed had it's own fuse. I'll check that out and verify juice to the plug. I was thinking that when I pulled the resister out, it would be fried. Time for the VOM. And clean connectors.
Seems like wearing out the motor would be the biggest negative.
Old 04-10-2012, 09:06 PM   #9
a_2000_se
a_2000_se's Avatar
Fan#: 62964
I think we're missing something here.
The Fan Resistor is a current limiting resistor/ dropping resistor. That may be why the 'low speed' circuit only needs a 30A fuse.
The high speed circuit has no series resistor, the Fan Resistor, and needs a 50A fuse.
If you short out/bypass the Fan Resistor you may exceed the 30A fuse value.
If you replace the 30A fuse with a 50A fuse you may exceed the wires current rating associated with it if it is not the correct gauge wire.
60k+ miles.
Old 04-11-2012, 04:51 AM   #10
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
FF Reputation: 10 Paladin Great Standing Member
ive found tht msot of the resistors fail on my car after a couple years of being blasted with rain and whatever else makes it through the radiator. i jsut make sure i have one NIB at home waiting for the next one to fail. 50 bucks every couple of years isnt so bad. (its more like a preventative maintanence thing. i jsut do it by habit now. )
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
