Is engine vibration normal? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-27-2012, 01:34 AM   #21
TommyBoyMartin
Fan#: 95639
What I Drive: 2001 Black zx3
FF Reputation: 1 TommyBoyMartin Good Standing Member
Originally Posted by Shempi View Post
I have the same problem. I think I may be leaning towards fswerks poly mounts. They are more expensive, but should last.
http://www.fswerks.com/mounts.htm
Link not available.
TommyBoyMartin is offline
Old 04-03-2012, 07:29 AM   #22
Dodgezilla
Dodgezilla's Avatar
Fan#: 83977
What I Drive: 2003 Silver Focus Wagon
Points 833, Level 15
Points: 833, Level: 15 Points: 833, Level: 15 Points: 833, Level: 15
Level Up 33% Completed
FF Reputation: 1 Dodgezilla Good Standing Member
Looks like I will be doing this procedure this weekend. Car is vibrating at idle in gear. My kids can't stand to be in the car.....
03 Silver Focus ZTW wagon w/ only 58,000 miles. Mods: Tinted Windows,16" rims w/ 205/55s,Big3 Wiring update,Mac Air Filter,No Roof Rack, Factory heated cloth seats.
Dodgezilla is offline
Old 04-04-2012, 10:12 PM   #23
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,823, Level 76
Points: 13,823, Level: 76 Points: 13,823, Level: 76 Points: 13,823, Level: 76
Level Up 44% Completed
Forum Activity 100%
Since you have 2.0 motor you don't get balance shafts
Originally Posted by Lscman View Post
I just bought a 2007 zx3 with 5 spd manual and 65K mi. The engine buzzes and vibrates above idle speed about as bad as an old pinto 2.3L motor. It gets quiet at idle RPM once warm. Stuff in the interior tends to vibrate in sympathy and the rear view mirror is even a little blurry. The noise is fairly obnoxious in the interior and it's no quieter in a coast condition. It frankly sounds like it has a bad motor mount or the exhaust is touching the floorpan or frame, but this isn't the case from what I can see. The exhaust moves around like it's on rubber when moved by hand. The vibration is even worse when cold, but no missfire. It's hard to believe these motors have a counterbalance system because I've ridden in other modern 4 cyl cars and they are quite smooth.
Any advice appreciated.
Just to add= since you have a 2.0L motor you have no balance shafts like the 23 have. By the way I pulled my balance shafts out.
felixthecat is online now
Old 04-07-2012, 01:33 AM   #24
clnzx4
Keep It Classy.
clnzx4's Avatar
Fan#: 94624
What I Drive: 2007 ZX4 SAP, 2006 LJ Wrangler
Points 14,951, Level 79
Points: 14,951, Level: 79 Points: 14,951, Level: 79 Points: 14,951, Level: 79
Level Up 21% Completed
FF Reputation: 2 clnzx4 Good Standing Member
My '07 has vibrated since the day I drove it off the lot. Doesn't really make a sound, but vibrates really bad. I just thought that was how it was supposed to be. The Ford dealership never told me anything was wrong when I asked about it. But then again, they never want to look at my car when I would take it in.. So they will never get my business again.
Team Duratec #43 | Sedan Revolution #218
clnzx4 is offline
Old 04-07-2012, 06:11 AM   #25
WiscoGTI
Turböner
WiscoGTI's Avatar
Fan#: 70225
What I Drive: 2002 VW GTI
Points 163,254, Level 100
Points: 163,254, Level: 100 Points: 163,254, Level: 100 Points: 163,254, Level: 100
FF Reputation: 33 WiscoGTI Great Standing Member
Buy-Sell-Trade Rating: (9)
Talk to Steve at Tousley Ford for all your Ford OEM replacement parts. He has the best prices of anyone.
10% above cost ftw.
WiscoGTI is offline
Old 04-07-2012, 08:26 AM   #26
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
Points 1,224, Level 19
Points: 1,224, Level: 19 Points: 1,224, Level: 19 Points: 1,224, Level: 19
Level Up 24% Completed
Thanks, good to know the balance shafts are only on 2.3 motor.
Lscman is offline
Old 04-07-2012, 12:28 PM   #27
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Just to add= VF engineering lower mount, roll restricter aka dogbone is a great up great to have. It really helps restricting the motor from rolling around, whitch helps shifting & a putting the power down. Yes its going to a some nvh into the cabin at idle, but thats a small price to pay for what you get in return. Heck I've removed the balance shafts & add a VF engineering dogbone & yes it has some vibrations at idle w/ cams/udp's on the motor. It a 4 cylinder. If you want to see vibe's crank up a Hog.
Old 04-07-2012, 07:51 PM   #28
Lscman
Fan#: 95211
I'm a big believer in compliant bushings and stored energy in rotating mass. These sort of modifications feel fast but performance is generally unaffected. Lower rotating mass and firmer powertrain mounts encourage wheelspin which is never good unless you're trying spin (drifting). But then again, I have only 50K track miles under my belt so what do I know?
Lscman is offline
Old 04-08-2012, 01:59 PM   #29
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Poly dogbone is a great upgrade
Depends on what track your dealing w/ drags or road courses or even autoX's
Stored energy= drag cars. Lighten rotating mass= road racing Firmer power train mounts does encourage wheel spin= less power being used up. Thats where suspension set up comes in. Yes stored energy is great for DD's, say alloy flywheel vs a stock style flywheel. I was just saying a great upgrade is a poly dogbone vs the oem one, being FWD car's.
Old 04-14-2012, 07:32 AM   #30
Dodgezilla
Dodgezilla's Avatar
Fan#: 83977
Well, wasted money on this motor mount. Got it installed and nothing has changed. I guess I'll just live with that slight vibration in gear at idle. Or I'll just start flipping it into neutral when I'm sitting. It goes away then......
