2001 Ford Focus SE (SOHC) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-30-2012, 05:13 PM   #1
billjohnson
Fan#: 96819
What I Drive: 2001 Blue SE
FF Reputation: 1 billjohnson Good Standing Member
Another SPI hanging in there!! Car has 105,000 miles. Recently had a compression test done on the engine, and supposedly all cylinders right at 120 psi. Now I'm considering replacing the timing belt, water pump, etc.
I know this engine has had massive problems with the valve seats, and wondering if i should put more $$$ into this car, or cut her loose while she still going?? If I do change timing belt and water pump...is there anything else that would make sense to do at that time??
Things I've done over last year:
1) failed front springs...replaced.
2) failed ignition lock cylinder..replaced.
3) failed alternator....replaced.
4) failed O2 sensors...replaced.
5) failed DPFE sensor...replaced.
6) failed fuel pump...replaced via recall.
7) new green stuff pads and slotted rotors
8) new headlight assembly
9) new plugs, wires, and coil
10) new fuel filter
11) new tires
billjohnson is offline
Old 03-30-2012, 05:43 PM   #2
fakitol
Fan#: 63209
What I Drive: 01 zx3 mtx,04 svt,01 zx3 atx, 02svt
Points 725, Level 14
Points: 725, Level: 14 Points: 725, Level: 14 Points: 725, Level: 14
Level Up 25% Completed
FF Reputation: 1 fakitol Good Standing Member
Buy-Sell-Trade Rating: (11)
If you do timing belt + head change it will cost you $1000+. I would sell it.
fakitol is offline
Old 03-30-2012, 10:53 PM   #3
p58ff
p58ff's Avatar
Fan#: 25247
What I Drive: 2010 Red 4-Door SES
Points 1,535, Level 22
Points: 1,535, Level: 22 Points: 1,535, Level: 22 Points: 1,535, Level: 22
Level Up 35% Completed
FF Reputation: 1 p58ff Good Standing Member
My 2002 SPI LX is still going with mileage close to 160K. I've replaced a lot of stuff too and I figure I'll run it until it croaks. I've done the shocks, headlights, sway-bar links, alternator, timing belt, water pump, and other odds-and-ends. Just replaced the windshield too after it got busted. Bought a new Pioneer stereo too since the OEM unit is possessed. My car is practically new with all the new parts and it sounds like yours is heading that way.
I wonder just how wide spread the valve-seat issue is? Surely not every SPI is dropping valve seats.
I can do a lot of repair for what a new or newer vehicle is going to run me cost-wise. If it is dependable for your use, maybe a commuter, keep it. Don't feel confident...probably time to let it go.
PAv
p58ff is offline
Old 03-31-2012, 12:31 AM   #4
Elder
Points 12,807, Level 73
Points: 12,807, Level: 73 Points: 12,807, Level: 73 Points: 12,807, Level: 73
Level Up 90% Completed
Yup - It's a "keeper"
The work done recently adds up all at once, but it's all "normal" maintenance for the age of the car.
Most of the failures we hear about are on Higher mileage cars, and we ONLY hear about the ones that break! (as a rule) NOT the ones that keep chugging along....
There are still Escorts out there running the same engine.... Haven't seen 'em ALL by the roadside... (grin)
If it DOES go, it can often be repaired fairly inexpensively, IF you can pull the head yourself & take it in for reconditioning.... And from what you've fixed already it sounds like you could do it!
The GOOD thing, is that the SPI is the most economical Focus, you pay for that with a bit less performance, but a LOT of folks are happy with them...
Luck!
sailor is offline
Old 03-31-2012, 04:57 PM   #5
my_beautious_ZX3
Fan#: 32386
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
Originally Posted by billjohnson View Post
supposedly all cylinders right at 120 psi...I know this engine has had massive problems with the valve seats, and wondering if i should put more $$$ into this car, or cut her loose while she still going
That's always difficult math to do. If you replace your 2001 Focus with another older car, it's gonna need routine & unscheduled maintenance sooner or later anyway (like timing belt, struts, tires, etc). So, it boils down to sinking $$ into the proverbial "devil you know versus the one you don't".
I have a Zetec so I don't know what the nominal psi for an SPI is, but the consistent readings you got might mean that you dodged the valve seat bullet.
[QUOTE=billjohnson;4084699]
mmmm, not really a fair comparison. I drove an Escort for a decade, and I probably paid less for repairs in 10 years than in any one year of my Focus. On tires alone, I've probably spent 3x more on the Focus. BTW, when I finally junked the Escort (mechanically sound but dissolved by midwest roadsalt), it was still getting 41 mpg highway and burning zero oil. My mechanic laughed and said, "That's because it's a Mazda engine."
my_beautious_ZX3 is offline
Old 03-31-2012, 05:14 PM   #6
Elder
The SPI is the champ for Focus MPG, and the tire issue CAN be addressed with a good alignment...
"Backyard alignment" to Geezer's specs. in the wheels/Tires/brakes section does it...
Luck!
sailor is offline
Old 04-01-2012, 05:10 PM   #7
billjohnson
Fan#: 96819
Thanks for all the replies. So guess I will keep her and see what happens! Anything else I should do that's not on my list??
Old 04-01-2012, 06:17 PM   #8
Elder
Shucks, fix what's broken - keep up with maintenance - keep an eye on everything else & just drive and enjoy it!
The only things not on the list are Brake condition, ball joint/tie rod end boot condition, and CV boot condition....
Just things you ALWAYS keep an eye on B4 they become an issue 'cause you didn't notice they were failing....
sailor is offline
Old 01-04-2013, 06:04 PM   #9
billjohnson
Fan#: 96819
UPDATE: Well, valve seat three dropped at 108,000. Funny that I had stopped at my local Ford to order a motor mount, and the seat dropped right in the Stealership parking lot! Hoping to have a buddy pull a Lug Nut and bring her back from the dead...
Old 01-06-2013, 12:13 PM   #10
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
Buy a wrecked donor Focus with a Zetec engine, and replace your SOHC with the Zetec. I have a Focus LX that a prior owner did this to. The swap is easy to do, the Zetec bolts right on to the MTX transmission and you just need to take the engine computer and wiring and such from the donor car.
Don't just replace the head on the SOHC. When the valve seats drop metal particles are blown into both the intake and exhaust. All of those have to be cleaned out or the engine will fail again when those particles are sucked into the repaired engine.
There are aftermarket valve seats with a different metal formulation that won't fail, for the SOHC.
tmittelstaedt is offline
