#61 | ||||
I'm an A55
#62 | ||||
#63 | ||||
They had then told me they put in a call to Detroit to consult with them about what the issue might be, and they came back saying that the ability to enable DRL had to be set up at the factory. The service guy who was telling me this said that it's most likely because I don't have the correct module installed, but he wasn't too sure about that. My Focus wasn't ordered as a fleet vehicle, so that makes sense. However, when you (03rubicon) said that you were able to turn them on, that got my attention! Was your car built as a fleet purchase? If it was, then you may have this module that makes it possible to turn on your DRL without your IDS spitting out an error. Were you able to verify that the DRL were in fact working by doing a light check when you had turned them on? Any more details about what you had done would be greatly appreciated! :-) BTW, I wonder where I can get a hold of an IDS in order so I can see for myself how it works... Russ |
#64 | ||||
Bring your car out to PA and ill turn them on for you
#65 | ||||
Yeah, I'll hop in my car and hit the road to PA right now!
![]() I was wondering if you can do something for me... Can you plug in the VIN of your Focus into this website? http://www.etis.ford.com/vehicleRegSelector.do Check out the results, and make sure you pull down the "minor features" list, and see if you can find what it says about "Daytime Running Lamps." What shows up when I pull up the data from the VIN of my car is this: Less Daytime Running Lamps That makes sense because it wasn't a fleet vehicle. I was curious what the details of your Focus shows concerning DRL. Thanks! Russ |
#66 | ||||
Copy/paste from the service manual: NOTE: Do not change Car Configuration Parameters except those listed below. •Seat belt warning ( Belt-Minder® ) •English/Metric •Language •Courtesy wipe after wash •Rear reverse gear wipe |
#67 | ||||
#68 | ||||
#69 | ||||
#70 | ||||
Like I said in the other reply, I get stuck with most of the "interesting" problems at our shop and am no stranger to having to change parameters in these cars and trucks to add or remove systems that customers want/need or dont want/dont need. Although it was different then older vehicles, it still was not to hard to figure out.
