Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus > MK3 TSB, Recall & Problems Archive
Old 03-28-2012, 02:09 PM   #871
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: 2012 Red Candy Metallic SEL Sedan
FF Reputation: 9 kam327 Good Standing Member
Originally Posted by st falcon View Post
Likely transmission fluid getting into the clutch assembly...
That's not encouraging. I leak that you can't possibly detect without tearing apart the transmission.
kam327 is offline
Old 03-28-2012, 02:13 PM   #872
TboneZX3
TboneZX3's Avatar
Fan#: 90494
What I Drive: 2012 SE Sport 5Dr
FF Reputation: 5 TboneZX3 Good Standing Member
If the technician said "leaking from the clutch assmbly", then I would assume that it was brake/clutch fluid from the slave cylinder. There was a parts list I saw here on FF from a DCT repair that included the slave cylinder. Of course, replacing the slave cylinder should always be done when replacing a clutch, so that doesn't mean it was necessarily the culprit.
'12 SE Sport 5Dr |╠╬╝|Sterling Grey Metallic|203a|Moonroof|17" Mach/Paint Whls|K&N Typhoon|MS3 RMM|Steeda STB, RSB
TboneZX3 is offline
Old 03-28-2012, 02:50 PM   #873
me2000
me2000's Avatar
Fan#: 85106
FF Reputation: 1 me2000 Good Standing Member
Parts:
W705448 S441: Nut (6)
YS4Z 3N342 AA: Retainer - Bearing
W520102 S442: Nut - Locking (2)
AE8Z 1S177 A: Seal (2)
AE8Z 7052 A: Seal Asy - Oil
AE8Z 7048 A: Seal Asy - Oil
BV6Z 7B546 B: Clutch Asy
AE8Z 7064 A: Snap Ring
XT 11 QDC: Fluid - Transmission (2)
Replaced Clutch Assembly
me2000 is offline
Old 03-28-2012, 03:02 PM   #874
TboneZX3
TboneZX3's Avatar
Fan#: 90494
Well, maybe not, then.
TboneZX3 is offline
Old 03-28-2012, 04:29 PM   #875
Sonic MK3 Crew #06
The car is shifted using electronic servos not the hydraulics like on a normal manual gearbox, at least as far as I'm aware, and that if the fluid was leaking it was likely coming from the gearbox itself through a failed o-ring seal. In such an event it would be difficult to detect until the fluid started to seep past the clutch housing, but the clutch plates would be damaged before that time due to being coated in oil.
suss6052 is online now
Old 03-28-2012, 05:07 PM   #876
hoffmanr09
Fan#: 89468
What I Drive: 2012 ford focus se
FF Reputation: 1 hoffmanr09 Good Standing Member
I wish I had the newer clutch in my car. Still does not run smooth after TSB 1,2,3.... blah blah. My dealership wont know what to do and Noemi (no offense) will tell me to pm and it will "escalate" to the service manager when the SM does not even know how to fix the problem himself because he knows nothing about the new clutch! didnt even know about every TSB we had durrr. Focus fanatics has been my savior in helping fix my issues! ;) We know more on here then they do at the dealership ha
hoffmanr09 is offline
Old 03-28-2012, 05:09 PM   #877
hoffmanr09
Fan#: 89468
I would like to know why your vehicle health report or the dash that there was a leakage and fluid or w.e is low
Old 03-28-2012, 05:40 PM   #878
Sonic MK3 Crew #06
Huh? Are you saying you would like to see some sort of warning on the dash or the vehicle health report saying there is a leak? This would require additional sensors either to measure the fluid, or to detect leaks, and as far as I'm aware its not quite as simple as it sounds.
Old 03-28-2012, 07:30 PM   #879
BigFuzzyArchon
Fan#: 87167
What I Drive: 2012 SE Hatch Sport Package
FF Reputation: 1 BigFuzzyArchon Good Standing Member
Just got the updates done to my car build date march 22 2011 and it definitely improves the low speed smoothness and and deceleration issues I was encountering. I got it done at maroone ford in ft lauderdale. they said they have not ever done this on any car.
they also told me they had to drive it on the highway at 70mph plugged into their computer. Has anybody heard of this?
BigFuzzyArchon is offline
Old 03-28-2012, 07:58 PM   #880
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
No but it doesn't surprise me. After mine was done it had around 20 more miles on the clock.
kam327 is offline
