Full Build... blue smoke??? Ideas??? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-23-2012, 04:42 PM   #11
itbparada
Fan#: 31881
What I Drive: 03 fSVT zx3
FF Reputation: 5 itbparada Good Standing Member
Originally Posted by 1turbofocus View Post
What do you mean by all over the place on the wide band
Tom
sorry should have specified a little more... durring idle it will bounce from 12-18:1, when motor is cold it pins lean and idles with a lope until i tap the gas... then it evens out most of the time(normally bounces 15-17), anything more than part throttle load/cruise it shoots strait to lean 20+ : 1.. fyi - still havent gotten into more than 1-2psi of boost
Tom-what do you file your ring end-end gap to on the top two rings for boosted applications?
'03 Fsvt-JRSC/BBK/ODP/WMI/ZEX100shot/JEpistons/EAGLErods/ARP/P&PHead+1mm/CMtwindisk/FW/TorsenLSD/PolyMounts/67TB/CatDelete/3"SSExh
'98 Csvt Hybrid-3L 248whp/'97 SableWagon-DD
'03 R1-Built/'89 Sportster-14:1 1340cc
itbparada is offline
Old 03-23-2012, 05:16 PM   #12
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
FF Reputation: 9 drunkyoda Good Standing Member
sir you need a tune now! stop driving...
under WOT you should be at 12.5-13.2
idle should be around 15-16
cruising should be around 14.5-15
being that lean is terrible and you could blow your engine any second...
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 03-23-2012, 06:21 PM   #13
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,787, Level 100
Points: 51,787, Level: 100 Points: 51,787, Level: 100 Points: 51,787, Level: 100
Forum Activity 32%
Buy-Sell-Trade Rating: (28)
WOT should be 10.8 to 11.1 on 93 and 10.6 to 10.9 on 91
Idle and cruise shoulf be 13.8 to 15.8 target is 14.7
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 03-23-2012, 06:25 PM   #14
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
I would check that tune good it could be part of the issue
As for the rings .004 to .0045 x bore on the top ring and .005 to .0055 on the second ring x bore depending on what level of boost and performance and its very important to have the ring square with the deck , you can use one of the old pistons with all but the second ring off to pust the rings square in the bore , some know this but adding it for others that dont
Tom
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-23-2012, 11:30 PM   #15
itbparada
Fan#: 31881
Well i know i need to adjust my tune but datalogging with this burning oil issue is giving me very erratic a/f's from my wideband and my factory o2 sensor is doing the same...
I havent done any damage to the motor since i havent even taken it into boost... or past 1/4 throttle for that matter, soon as I saw where it leaned out I never took it past that again. I added a little fuel/timing to the tune this morning and a/f & are alot better (drivability is PERFECT) but im still smoking.
Old 03-23-2012, 11:44 PM   #16
itbparada
Fan#: 31881
Tom
Well the windage/pan/blower/head are comming off 2maro... going to take a look at piston #3's rings. I used a cylinder bore square from my sr20det build a while back when I was setting rings up. Using a piston definatly works just as great to.
Finishing up my contourSVT 3l hybrid durring all this ughh hate having both SVTs down.
Ill be posting up the pics/specs as soon as I pull everything appart.. and we can figure this out...
as always, thanks a millions guys
-Rick
Old 03-26-2012, 12:54 PM   #17
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
Tom
ahhhh ok so FI is wayyyyy different. lol
Old 03-26-2012, 07:06 PM   #18
inis
Fan#: 32050
What I Drive: 00 Zx2 s/r (yellow)
Points 2,837, Level 32
Points: 2,837, Level: 32 Points: 2,837, Level: 32 Points: 2,837, Level: 32
Level Up 58% Completed
FF Reputation: 1 inis Good Standing Member
Pull the header, see how the exhaust ports look. If they're dry, your ok. If they're wet or oily...you have issues.
inis is online now
Old 03-26-2012, 08:21 PM   #19
itbparada
Fan#: 31881
well if i have a oil wet spark plug... im sure there will be plenty of crap inside my header primary/exhaust port itll be super evident with my fresh jet-hot coating inside & out ughhh =/ its all comming out this weekend neway
Old 03-26-2012, 09:47 PM   #20
inis
Fan#: 32050
Wet coating on plugs doesn't mean much, if you have alot of oil..then well ya.
It took several hundreds of miles to get mine broken in. If your not smoking at idle...I would look at the turbo and see if oil is on the cold side.
inis is online now
