General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
Old 04-12-2010, 08:11 PM   #41
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
I only ran 96lb Inj and stock ECU with my tune and a Diablo chip , why not run just 4 Inj and loose the second Inj ?
Tom
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-13-2010, 07:10 PM   #42
inis
Fan#: 32050
What I Drive: 00 Zx2 s/r (yellow)
FF Reputation: 1 inis Good Standing Member
are the stock injectors running when going into boost? if so this is a bad idea, if one injector fails your afr will change but not enough to stop you going..you'll end up with a melted piston. With 4 larger injectors, you drop one you'll know right away.
I'm running ID1000's, so far so good.
szabyk, are you still fwd? I'm also running a dry sump.
inis is offline
Old 04-13-2010, 10:42 PM   #43
szabyk
szabyk's Avatar
Fan#: 61298
What I Drive: Ford Fiesta Zetec Turbo
FF Reputation: 1 szabyk Good Standing Member
Yes I still fwd
Yes, I looked at your project ...the first time I bought Titan dry sump...but I realize that the small pump....I change a Weaver...just buy an even bigger 4 stage
9.3@151 FWD Ford
www.stefanzorst.com
szabyk is offline
Old 04-14-2010, 09:22 AM   #44
Ricci_BR
Ricci_BR's Avatar
Fan#: 55484
What I Drive: 2001 Blue Focus LE Turbo
FF Reputation: 2 Ricci_BR Good Standing Member
Tom
When i was building my setup, i looked some alternatives for the ECU tune... but my ECU has the serial number is diferent from you guys, nobody (CFM, Focus Sport,...) confirmed if diablo ou sct would worked on my ECU..... So I decided to use this brazilian stand alone (Fueltech)..... thats give me the opportunity to run with 8 inj, so i keep the 4 stock injection to tune economic use of fuel without pressure......the other 4 injector are the ford racing 150 lb/h with peak and hold because they are low impendance.... this 4 ford racing feed the engine when its going into boost
This 4 stock injector also keeps feeding with pressure, but they runing less percent of flow.... because if i stop the stocks and tune to start only the ford racings when its getting pressure, this transaction is not healthy to the engine......
Bruno RICCIoppo
Turbo Zetec Focus
451whp
*Brazil*
Ricci_BR is offline
Old 03-14-2012, 06:45 AM   #45
georgekirollos
Fan#: 96362
What I Drive: 1999 blue mondeo mk2
FF Reputation: 1 georgekirollos Good Standing Member
hi, Im doing a similar build in my ford mondeo, but using HX35 with a 14cm housing, did not run it yet but I'm really concerned about lag with the 14cm, I'm going to do a twin scroll header for it, can u please tell me what size of exhaust housing are you using?? 12 14 or 16cm ???
georgekirollos is offline
Old 03-15-2012, 09:17 AM   #46
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Hyundai Sonata
Buy-Sell-Trade Rating: (13)
Hey George, this is an old thread , check out the date. Try starting your own thread, you will get a lot of answers to you questions. Good luck with your build...
iroc34 is offline
Similar Threads
Ford considers bringing 305-hp Focus to U.S. market Tom Ford Focus & General Car Chat 221 09-07-2009 07:34 PM
The Ford Focus - General History and Information S2 Ford Focus & General Car Chat 1 11-14-2008 02:04 PM
SPA Turbo Ford Focus DIY turbo package deal! cfmfocus2 Group Buys & Hot Deals! 6 09-20-2008 09:02 PM
2008 Focus TimHickey Ford Focus & General Car Chat 5 01-11-2007 12:51 PM
Ford Focus: Parts Links hotfocus Member FAQ's & How-To Information Archive 0 10-21-2003 09:34 AM
