needs to know cheap way to gain 20+hp - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-09-2012, 08:55 PM   #11
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,036, Level 66
Points: 10,036, Level: 66 Points: 10,036, Level: 66 Points: 10,036, Level: 66
Level Up 97% Completed
Forum Activity 45%
Activity: 45% Activity: 45% Activity: 45%
Buy-Sell-Trade Rating: (41)
20 hp thats easy sell your car buy somthing with more h/p
pasta is offline
Old 03-10-2012, 12:21 AM   #12
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 7,994, Level 60
Points: 7,994, Level: 60 Points: 7,994, Level: 60 Points: 7,994, Level: 60
Level Up 22% Completed
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
Originally Posted by 1turbofocus View Post
Please tell me you dont believe that ?
Tom
Hell yes I believe it, I've done it twice already! It feels like when you add a K&N cold air system; just a slight difference in performance... and probably more of a mental upgrade. No error codes, no pending codes.
Let's work out the logic: If the PCM is told it's running a few (and that's VERY important, if you eff-up your math and get it wrong by twenty degrees = not good) degrees cooler than it's been programmed to run 'optimally', it does what?! adds air and fuel to warm it all up; the net result is more power and a slight loss of mpgs.
I'm working with a friend to solder up a few different resistances on a few different ECT sensors and pulling with each on a dyno to get concrete numbers... to prove to everyone else what I've already realized.
Mile30 is offline
Old 03-10-2012, 12:26 AM   #13
Red Jay 918
Red Jay 918's Avatar
Fan#: 79277
What I Drive: 2010 Focus SE
Points 9,331, Level 64
Points: 9,331, Level: 64 Points: 9,331, Level: 64 Points: 9,331, Level: 64
Level Up 94% Completed
FF Reputation: 7 Red Jay 918 Good Standing Member
lightweight flywheel?? that'll free up some HP but not alot... but every little bit helps!
Red Jay 918 is online now
Old 03-10-2012, 12:32 AM   #14
Mile30
Mile30's Avatar
Fan#: 74686
Originally Posted by UnbridledCarnage View Post
just sounds like a bad idea
You can't go crazy and tell it a number that's WAAAAAY off, or your asking for trouble, but if you have access to alldata or the factory charts; it's just a matter of math.
A few degrees is all you need.
You can 'smh', facepalm, or whatever you want, but before you quickly brush me off as insane; do some thinking!
1)The sensor detects a range
2)the real-time 'measurement' is reported to the PCM
3)based on it, and other sensors, the computer reacts to change a/f ratio to suit for the optimal setting in the stock maps (STOCK MAPS, a tuned car is different, and a different conversation!)
4)a cold engine creates more NOX and other pollutants, Ford engineered efficiency into the system for emissions sake, not power
5)because the actual temperature is normal, nothing detrimental is occurring inside the engine
6)because the signal sent from the ECT sensor is only a few degrees off, the PCM doesn't make a radical enough change to hurt anything
-it just allows a little bit more air and fuel into the equation-
Mile30 is offline
Old 03-10-2012, 12:35 AM   #15
Mile30
Mile30's Avatar
Fan#: 74686
It'll free up rotating mass, which makes it rev up a whole lot faster than stock... I did it a few years ago, and the difference is night and day! It usually scares someone that's not expecting it.
Mile30 is offline
Old 03-10-2012, 01:30 AM   #16
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
FF Reputation: 2 bespurcell Good Standing Member
The computer has nothing to do with adding air. That's done by the throttle body.
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
Old 03-10-2012, 01:38 AM   #17
PowerFocer
PowerFocer's Avatar
Fan#: 61706
What I Drive: 2010 Sedan SE
Points 4,602, Level 43
Points: 4,602, Level: 43 Points: 4,602, Level: 43 Points: 4,602, Level: 43
Level Up 26% Completed
FF Reputation: 2 PowerFocer Good Standing Member
And also if you put a potato in the tail pipe the exhaust will build up enough pressure in the cylinder to where it compresses the air and builds boost. Waalla...boost without the hassle of the turbo system.
Originally Posted by WeeAsp View Post
Rule of thumb:
NEVER trust anyone with your car or your girl.
Either way, you could get a rod thrown in both.........
Fast cars make smart people do dumb things
PowerFocer is offline
Old 03-10-2012, 05:45 PM   #18
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,937, Level 74
Points: 12,937, Level: 74 Points: 12,937, Level: 74 Points: 12,937, Level: 74
NOS= simple enough.
felixthecat is online now
Old 03-10-2012, 06:27 PM   #19
Mile30
Mile30's Avatar
Fan#: 74686
True facts on the throttle body, however fuel trim is computer work. If you add more fuel, it cools the burn in the cylinder, which gives you more power.
Mile30 is offline
Old 03-12-2012, 04:05 AM   #20
PowerFocer
PowerFocer's Avatar
Fan#: 61706
I think it will just run rich, but if you can show it works then awesome.
Rule of thumb:
