Traction - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Old 07-02-2011, 07:01 PM   #1
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
FF Reputation: 2 bespurcell Good Standing Member
Traction
I have probs with wheel hop on hard launches. What do you guys do to solve this prob? I've seen the Lakewood traction bars are these any good? Is there anything else I can do to help with this prob? I'm fixing to be running nitrous and would really like to be able to get off the line good. I know I need drag slicks I just want to solve the wheel hop problem. Do the poly lca bushings help much?
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
Old 07-02-2011, 09:14 PM   #2
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Yes Lakewood trac bars work. Polly bushings also help. But slicks will also help get rid of wheel hop
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 07-02-2011, 09:44 PM   #3
bespurcell
bespurcell's Avatar
Fan#: 60917
Thank you. I had no idea slicks would help with wheel hop. What have you done to your car for traction off the line besides tires?
Old 07-03-2011, 08:35 AM   #4
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 15,038, Level 79
Points: 15,038, Level: 79 Points: 15,038, Level: 79 Points: 15,038, Level: 79
Level Up 38% Completed
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
all the poly bushings you can think of. definitely poly control arm bushings are a must.tires obviously. if you dont want to go to a full slick just yet then look into some BFG G-force drag radials. its basically a street legal slick. they are very good tires and for the record only need a very brief hazing through the water box to get them heated up. heat them up too much and you will get little grease pits in the tires which will make you blow the tires off on launch every time.
lakewood traction bars and a good controlled launch that pre-loads the suspension before launch will help alot too. this is how i pre-load and launch myself. ive netted 1.9 second 60ft times on regular crap brand street tires with this method and very rarely get wheel hop
when you stage and the lights are about to come down, pull the e-brake.
start giving it some gas and get it up to your launch rpm, 2-step helps ALOT here.
when the first light comes on to start on its way down start slipping the clutch.
keep the e-brake locked
slip the clutch to the point where it is just about to drag the back tires.
when the time comes, release the e-brake and goose it.
this will cause the ass end of the car to squat before you actually take off and will make the front raise up a bit. it will reduce the amount of energy lost by being spent to compress the suspension in the rear when you launch and will also help reduce wheel hop.
do NOT start slipping the clutch too soon. try to slip the clutch for as short a period as possible. otherwise you could seriously overheat the clutch. this will cause you to wear it out really fast and or literally explode the clutch. you dont wanna do that, trust me. the clutch is almost directly lined up with the driver seat just so you know. ive been launching like this for years but i only slip the clutch for a maximum of 2-2.5 seconds before launch.
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 07-03-2011, 10:22 AM   #5
bespurcell
bespurcell's Avatar
Fan#: 60917
Thank you for help. Rep added
Old 07-05-2011, 02:26 PM   #6
AllOutZX2
AllOutZX2's Avatar
Fan#: 80930
What I Drive: 1998 Ford Escort ZX2
FF Reputation: 1 AllOutZX2 Good Standing Member
Motor Mounts / Transmission Mounts that limit forward or reward motion will mostly eliminate wheel hop. You may also want to pay attention to what air pressure you are running on your tires. A good rule of thumb is to start at 25psi on street tires and go down as needed. I would try those before going to traction bars and slicks. If you have the money though to spend on the items mentioned then go for it.
Shawn
Full Bolt-On's, SCT VCT Tuned ECU, 3500rpm Edge Racing Stall, 205/60R13 M&H D.O.T Street Slicks
AllOutZX2 is offline
Old 07-05-2011, 06:41 PM   #7
bespurcell
bespurcell's Avatar
Fan#: 60917
I have the poly lower rear motor mount bushings. I'm going to have a 75 shot of nitrous so, I'm pretty sure I'll need slicks to get off the line.
Old 02-20-2012, 06:07 PM   #8
DoomsdayFAN
DoomsdayFAN's Avatar
Fan#: 92019
What I Drive: ~2006 ZX4 SE Sedan 2.0L~
FF Reputation: 1 DoomsdayFAN Good Standing Member
Do the Lakewood Traction bars work well with coilovers?
DoomsdayFAN is offline
Old 02-20-2012, 10:23 PM   #9
Roushturboedzx3
I Fab Too Much
Fan#: 42814
They work well on my car
Old 02-28-2012, 10:27 AM   #10
daveyboy
daveyboy's Avatar
Fan#: 61480
What I Drive: 06 Mustang GT, 09 Focus SE
FF Reputation: 7 daveyboy Good Standing Member
Dont for get about a good set of shocks. stiffer springs will help too
daveyboy is offline
